VWVortex.com - HELP!WHERE TO GET PARTS FOR VR6 SCHRICK INLET MANIFOLD?
    Results 1 to 11 of 11
    Thread: HELP!WHERE TO GET PARTS FOR VR6 SCHRICK INLET MANIFOLD?
    1. 11-07-2008 05:16 AM #1
      Recently my friend corrado vr6 schrick inlet manifold actuator vacuum pump leaking so now the flab is not working,we already looking up and down for the parts can't get it just hope thge member in this forum can assist!(becuase my vw golf mk3 vr6 also fitte with schrick inlet manifold,i think i better get the spare ready before it break down)
    2. Banned VRsuper6's Avatar
      Jul 8th, 2007
      11-07-2008 07:43 AM #2
      http://autotech.com/prod_engine_intake.htm
      calm down [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 11-07-2008 08:13 PM #3
      I had the same problem. If you look closely at the vac actuator, it's a Ford part (small wonder it breaks ). IIRC, it's off of an Explorer. I ordered a new one through a Ford parts place, but I had to cut and thread the shaft to make it work. You'll see what I mean if you go the same route. HTH.
      Edit: Found a pic.
      Modified by benny_mech at 4:20 PM 11-7-2008
      For best results, experience reality in moderation.
    4. 11-14-2008 01:09 AM #4
      I check aototech webpage but can't get the schrick parts i want.
    5. 11-15-2008 10:55 PM #5
      Which part do you need? Post a picture or something.
    6. 11-16-2008 12:09 AM #6
      HI Benny!
      Thanks for reply,the part i want is the exact phto you post but i can't get it here please help.
    7. 11-16-2008 01:57 AM #7
      You can't get it from the Ford dealer? The part number is right on it. You have to cut the shaft, which can be done with a Dremel tool, and then you need to thread the shaft with an M3 x 0.5 thread die, if I remember correctly. Take it to a machine shop if you can't buy the die and do it yourself. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      11-16-2008 02:03 AM #8
      http://www.ford.net.my/ford_my.asp
      Sime Darby Auto Connexion SDN BHD (Jalan Ipoh)
      No. 468-11A, Batu 3, Jalan Ipoh
      51200 Kuala Lumpur
      Tel: 03-4043 3664 / 4043 4232 / 4043 0121
      Fax: 03-4041 5859
      PIC: Edward Lim (014-666-1628)
      edward.lim@simedarby.com
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    9. Member mk2vrooom's Avatar
      Oct 15th, 2003
      Nashville, tn
      06 330i, 2011 gti
      11-16-2008 02:06 AM #9
      vac motorsports in canada can get whatever...
    10. 11-16-2008 06:00 AM #10
      I am in the same boat as you are but I need to fix the flapper my just rattles and sounds like crap however the body of my car looks like crap right now.(no job for a while so no moneys to make it pretty. When I get said job it will look pretty again eventually)
      I was told that I had to send it to Schrick in Germany to get it repaired is there way that I can have it repaired here in the states without jamming it open permanently? I kind of like the job it was meant to do. Wow I can't believe it has gone up $1000k since I bought mine in 2003. Crazy shyte.
    11. 09-08-2009 04:04 PM #11
      I want to refresh the topic
      I'm looking for a service number in Ford Explorer because I don"t know where is it placed and I've lost mine during redecoration of my flat
      I'd be very glad if someone could tell where to look for this number. A friend of mine has a Ford Explorer for parts so I could take it from him
