VWVortex.com - Whats the best upgrade turbo for my 2004 jetta GLI?
    Results 1 to 18 of 18
    Thread: Whats the best upgrade turbo for my 2004 jetta GLI?
    1. 11-09-2008 10:34 PM #1
      i hear people talking about t3 and t4 but also about gt30r whats the best for my 2004 Jetta GLI?
    2. 11-09-2008 10:40 PM #2
      It all depends on your definition of "best." Some say the best would be a GT28RS where you have quick spool with decent top end power. Others aren't satisfied until they can break traction in 5th with something much larger like a GT35R.
      You need to start by establishing your power goals, and then work from there.
      It also helps to know what your car is going to be used for (Drag, Street, Auto-x, Dyno-queen, etc.)
    3. 11-09-2008 10:43 PM #3
      also depends on how much you wanna spend.
    4. 11-09-2008 10:50 PM #4
      Yes, if you want to break it down into more variables, you can include price and even get into reliability. But a good place to start is to look into a realistic power goal (dependent on your application) and to work from there.
      Do some looking in the FAQ and some searching to give you some ideas.
    5. Member bjtgtr's Avatar
      Dec 13th, 2006
      MD
      2001 A6 2.7T 6sp
      11-09-2008 10:55 PM #5
      K03S
    6. 11-09-2008 11:02 PM #6
      well i want a good spool and good peak not to much power but enough to kick some a** (i dont really have a power goal)
    7. 11-09-2008 11:04 PM #7
      3076r and Unitronic.
    8. 11-09-2008 11:14 PM #8
      ok 3076r and Unitronic from wat company?
    9. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      11-09-2008 11:25 PM #9
      Quote, originally posted by XOPMike »
      3076 is going to put you in the 400 numbers and is a nice sized turbo. You will need a built bottom end at the least to run that turbo. A built aem/intake mani would be the way to go to properly utilize the turbo. Look up arnold at pag parts, hes "AL@pagparts" on here i believe. Thats where i bought my kit, great guy and EXCELLENT quality hardware.
      what made you choose the 3076?
      STROKED 35r
    10. 11-09-2008 11:43 PM #10
      well i dont want to much power but enough to kick some A** and someone told me that this would do the job but wats ur word in it? wats the best for u?
    11. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      11-09-2008 11:47 PM #11
      well the 3076 will make your 1st through 3rd silly stupid... thats the power its capable of making. If your looking to just keep it on the street but have more power than stock... i would look into the gt28rs... spool is a little later than stock but not to bad... and you would gain a lot of top end... compared to stock.. do you have a specific power goal?
      STROKED 35r
    12. 11-09-2008 11:49 PM #12
      No one knows what your definition of "kick ass" is. At least throw out some number.
      Stock internals are good till about 300whp. The torque spike is what will throw rods.
      Road Farmin'
    13. 11-09-2008 11:53 PM #13
      so i mean u think a 3076 is to much for street use or can it be daily driven?
    14. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      11-09-2008 11:56 PM #14
      no, it can be a daily... thats what I have and alot of other guys on here. But its not a turbo you just throw on and drive with. the kit plus all the connections components you have to replace/upgrade will put you in the 6-7k easilly and thats if you do all your own work.... and that isnt with a built aem head/mani or lsd... it gets expensive real fast.
      How deep are your pockets for a bt an whats your power goal?
      STROKED 35r
    15. 11-10-2008 12:04 AM #15
      well my pockets are good but im trying to get anything from 350 to 400 with out spending to much i do go to skool
    16. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      11-10-2008 12:08 AM #16
      I would look either look into the cheaper options then... look to grab up a t3/t4 50 trim .63 hotside. That will make 350 wheel all day long and a little more if you want. Its a rather cheaper kit, not hardware wise but the turbo is a journal bearing vs the ball bearing. You could grab up a kit from arnold for around 2500 I would assume.. don't quote me.. but it would be around there. If you didn't want to do rods right away and build the bottom end.. you could keep the boost moderate.. until you got the cash/time to do it.
      STROKED 35r
    17. 11-10-2008 12:29 AM #17
      iight man thanks i got alot to think about then lol
    18. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01 S4, 02 996TT, 04 A4, 12 Golf R, 15 GTI, 12 TTRS
      11-10-2008 02:42 AM #18
      I am a fan of the GT3071R 63ar. Good turbo for daily driving, good spool, and good top end. If you want more power a GT3076R, and if you're on a budget a T3T4E 50trim.
      This is a GT3076R on the kinetic kit:
      You probably also want to consider drop in rods if you're gunning for more than 325~350+whp
      Clay
