VWVortex.com - APR Stage 3+ ....upgrade to GT2871R Turbo?
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 72
    Thread: APR Stage 3+ ....upgrade to GT2871R Turbo?
    1. Member iae21's Avatar
      Feb 8th, 2002
      Staten Island, New York
      11-09-2008 11:48 PM #1
      I just blew my GT28RS turbo from my APR Stage 3+ kit and need to either rebuild this turbo or get a new one. I was thinking about getting an GT2871R .64 A/R with a GT28 housing. I am pretty sure the turbo will bolt right up.
      I know that APR uses this turbo for their Audi TT 225 kits.
      Do I need to change anything else with the kit (Fueling/Timing/etc) besides bolting up this turbo?
      Thanks!
      Modified by iae21 at 10:59 PM 11-9-2008
    2. 11-10-2008 12:41 AM #2
      Yea, you defenitely should change software, go bug APR about TT sw and let me know if you get it, I haven't tried yet tho'
      You would need new injectors, 3bar map sensor, TT stage 3+ sw and GT2871R ( which you can get ...anywhere: http://www.atpturbo.com/Mercha...e=GRT )
      Oh...and an added inline fuel pump or something.
      Modified by mescaline at 8:44 PM 11-9-2008
    3. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01 S4, 02 996TT, 04 A4, 12 Golf R, 15 GTI, 12 TTRS
      11-10-2008 02:34 AM #3
      whizbang18T did this about 3 years ago to a stage 3, he might be a good guy to talk to.
    4. Banned 20aeman's Avatar
      Jun 7th, 2006
      ///M Roadster
      11-10-2008 03:07 AM #4
      If they refuse to give you the 2871 software, talk to pag parts about a 3071 t25 and unitronic/eurodyne software.
    5. 11-10-2008 06:00 AM #5
      only thing i can see you should change is your software, injector can pump enogh gas out, apr injectors arrent they 550cc, if so, you will be good with those... but in my view, step it up and throw a 3071 on instead. i have the 2871 on mine and im running 440cc on 4 bar so we are running close to the samme in injector sizes.
    6. Member DK_GTI_racer's Avatar
      Oct 4th, 2007
      Denmark
      2000 mk4 1.8T - AGU
      11-10-2008 07:29 AM #6
      Go with a GT2871r, its bolt on and easy to fit - you need to reuse your GT25 housing that APR has modified to fit elbow pipe, but its bolt on after that, and i would contact APR to see if they can load the file from GT2871r stage 3+setup, but it might be to aggresive seeing its made for a 9.0:1 compression - or you could buy uni sw for this setup, or even modifie with lemmiwinks to advantage of the new turbo...fuel supply with 550cc injectors are plenty to make 350-400whp, i believe if you look at igotaprestent4u he lemmi a GT3076r to work with APR stage3+ sw, but he made his own elbow pipe, and also a solution - i my self would go for the GT2871r.
      APR stage 3+ 393bhp & 466nm at 24psi - baby GT2860rs 0,64
      APR intake manifold, Aquamist 1s, milltek 2,75" with VES cutout, HGP IC - software by RH motorsport of denmark - EBC with remote and 2 boost settings for high low boost run.
      Goapr if you want your fast to be faster then everyone else
      www.goapr.com, www.inaengineering.com, www.qedpower.com, www.jvk-tuning.dk
    7. Former Advertiser
      Apr 25th, 2007
      Somewhere Within
      11-10-2008 07:33 AM #7
      T25 GT3071R with a set of 630's injectors and call it a day...provided you upgrade the rods
    8. Member DK_GTI_racer's Avatar
      Oct 4th, 2007
      Denmark
      2000 mk4 1.8T - AGU
      11-10-2008 07:37 AM #8
      Quote, originally posted by DonR@Unitronic.ca »
      Agree on the 630cc, and the GT3071r if you dont mind making a different elbow pipe, but for bolt on the GT2871r can produce quite a bit of fun
    9. Former Advertiser
      Apr 25th, 2007
      Somewhere Within
      11-10-2008 07:53 AM #9
      Quote, originally posted by DK_GTI_racer »
      The Comp housing is available for the the GT3071R so it's a direct swap
    10. Member DK_GTI_racer's Avatar
      Oct 4th, 2007
      Denmark
      2000 mk4 1.8T - AGU
      11-10-2008 08:00 AM #10
      i did not know that, out of curiosity who sells it with that comp housing?ATP, pag or garrett?
    11. Former Advertiser
      Apr 25th, 2007
      Somewhere Within
      11-10-2008 08:07 AM #11
      ATP, Pag or CTS.
    12. Member DK_GTI_racer's Avatar
      Oct 4th, 2007
      Denmark
      2000 mk4 1.8T - AGU
      11-10-2008 08:49 AM #12
      ATP, Pag or CTS.
      Maybe CTS could chim in on this, because all i cant find is that it comes with same turbine housing, and according to CTS it comes with its own larger compressor housing? its not that im doubting but i have always just tought the only upgrade solution with same flange as APR uses is GT2871r like what you can read on ATP and garretts hp, so knowing a GT30 option is possible would be great news...
    13. Member munky18t's Avatar
      Aug 30th, 2004
      Nova Scotia, Canada
      2005 Jetta GLI
      11-10-2008 09:16 AM #13
      reeeeeeally???
      I've only ever seen a gt2871 with the gt25 comp housing
      need more info!!
    14. Former Advertiser
      Apr 25th, 2007
      Somewhere Within
      11-10-2008 09:31 AM #14
      The GT3071R has the same comp wheel as the GT2871R making it a direct swap.
    15. 11-10-2008 11:05 AM #15
      but honestly i would first bug the hell out of APR for software, they make constant 400hp with gt2871r on VVT engines, something you can't say for any other software available.
    16. Member munky18t's Avatar
      Aug 30th, 2004
      Nova Scotia, Canada
      2005 Jetta GLI
      11-10-2008 11:42 AM #16
      Same comp wheel, but different housings
      GT2871r w/gt28r style comp housing
      http://www.atpturbo.com/Mercha...e=BCS
      GT3071r
    17. Member iae21's Avatar
      Feb 8th, 2002
      11-10-2008 01:50 PM #17
      Quote, originally posted by mescaline »
      I think that route has already been exhausted by many people on here. I do agree that it makes no sense at all for them to release that software to APR customers that already have a kit and want to build the bottom end up to handle the extra power.
      Although I'd be curious to see if the S/W for the 28RS vs the 2871R would be significantly different. They appear to use the same exact hardware for both kits.
    18. 11-10-2008 04:44 PM #18
      injectors are obviously different, there for sw gotta be different. Significantly? Well, perfection is obviously what you are after if you go that route... or else you can get some of those universal software (uni, tapp etc.)
    19. 11-10-2008 05:13 PM #19
      the apr software works perfectly with my 3076r, increased fueling 5% with lemmiwinks and have 11.9 a/f
    20. 11-11-2008 01:05 AM #20
      whats spool times on that setup
    21. 11-11-2008 04:20 AM #21
      Quote, originally posted by igotaprestent4u »
      Your software and injectors are very different from latest versions they are selling. There just isn't enough fuel to support anything bigger than GT28RS probably...
    22. Member
      Jul 24th, 2003
      2014 Sportwagen TDI 6MT, 2009 Tiguan-S 6MT
      11-11-2008 08:30 AM #22
      Very true. The "old style" injectors flow a lot more than the 510cc of fuel that the gray Bosch ones deliver.
    23. 11-11-2008 09:13 AM #23
      you can run on 630's with the "newer software" get the duty cycles down and run a bigger turbo. Idle is lumpy though
    24. 11-11-2008 09:21 AM #24
      Quote, originally posted by nowalk »
      25psi right around 4400revs.
    25. Member iae21's Avatar
      Feb 8th, 2002
      11-12-2008 10:27 AM #25
      Would a GT2871R from an APR Stage 3+ kit for an Audi TT bolt right up to my kit without any other mods?
