VWVortex.com - Anyone know what a "Transmission Range Sensor (F125)" is?
    Results 1 to 8 of 8
    Thread: Anyone know what a "Transmission Range Sensor (F125)" is?
    1. Member mrgreek2002's Avatar
      Sep 30th, 2002
      Toronto, Canada
      MKVI Jetta & MKIV Golf
      11-28-2008 07:56 PM #1
      Hi, my transmission has a mind of it's own and goes into neutral on it's own when it wants. After 5 seconds, it goes back into "D" though. I got this code right now in my ECU:
      17091 - Transmission Range Sensor (F125): Signal Too Low
      P0707 - 35-00--
      Any ideas what it means? I tried searching but couldn't find anything.
    2. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
      11-29-2008 12:53 AM #2
      Its like a neutral switch only it has more functions. Its sometimes called a multifunction switch.
      I assume you have a passant since your signature says,"Das PassatWerks"????
      Range sensor is on the side of the trans under the mount, under the exhaust, under the heat sheild.
      I replaced a couple lately. Man they are high from the dealer.
      Oh, here's a thread regarding range sensors, different code though, for same part.
      http://forums.vwvortex.com/zerothread?id=4044055
      Modified by CoolAirVw at 9:02 PM 11-28-2008
      Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
      ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
      www.KansasCityTdi.com
    3. Member CoolAirVw's Avatar
      Mar 8th, 2007
      11-29-2008 01:08 AM #3
      Quote, originally posted by mrgreek2002 »
      Actually your symptom sounds like low fluid, but I guess the range sensor might cause it?????
    4. 11-29-2008 04:37 PM #4
      The F125 can cause his symptons. The multifunction switch tells the computers what gear the car is in (also controls the gear display). If the switch is telling the TCM that it's in neutral, than the TCM will shift the trans into neutral. There are no sensors or switches at the gear selector lever, so all of the gear select info comes from that sensor.
      With the "low signal" code, I'm going to place my bets on a corroded or loose connector. With a newer passat, I believe you should have a round 10-pin connector that's notorious for corrosion. With an older passat, you would probably have an 8 pin connector that plugs directly into the sensor, which would be located at the rear of the transmission.
      Modified by z261994 at 12:39 PM 11-29-2008
    5. Member CoolAirVw's Avatar
      Mar 8th, 2007
      12-01-2008 09:13 AM #5
      Quote, originally posted by z261994 »
      I think what he's saying is, "What year, make & model."
      If thats not what he's saying then its what I'm saying.
    6. Member mrgreek2002's Avatar
      Sep 30th, 2002
      Toronto, Canada
      12-02-2008 12:44 AM #6
      1999 Passat 1.8T tiptronic.
      I went to the local VW dealer and had it checked out. They said my multi-function switch is fine and that's it's a wire somewhere between my ECU and tranny. Makes sense because I had a water leak right around the time the problem started happening. They needed extra time to get into checking all the wires, etc. I'm going to make a new appointment with them soon and hope to have this fixed as soon as possible!
    7. Member mrgreek2002's Avatar
      Sep 30th, 2002
      Toronto, Canada
      03-01-2009 12:41 AM #7
      I found out that it was low on tranny oil. Once it was fully filled, the problem went away and it's back to normal now.
    8. Member CoolAirVw's Avatar
      Mar 8th, 2007
      03-03-2009 08:53 PM #8
      Quote, originally posted by CoolAirVw »
      Wow! I nailed that one, eh?
