Page 1 of 2 1 2 LastLast
Results 1 to 35 of 52
Thread: Who has experience with ball joint extenders?
  1. Member rabbitarmy's Avatar
    Nov 16th, 2006
    raleigh, nc
    1980 2.0T Scirocco
    12-02-2008 04:48 PM #1
    Specifically those sold by Performance Machine Works Ltd (www.pmwltd.com)
    Quote »
    Volkswagen Lower Ball Joint Extender:
    For All Models Using The 17mm Or 19mm Ball Joint
    Fits pinch clamp on stock VW upright, and stock ball joint shank. Returns lower control arm to proper angle to improve front suspension geometry on cars that have been lowered. Machined from 4140/4142 steel and heat treated to a tensile strength of 150,000 PSI. Standard extender drops ball joint 1.5 inches. Can be machined to special lengths. $265.00 (pair)
    Everything looks good in theory, but I have heard stories that they'll break. Obviously that could be catastrophic & of course I don't want to piss money away on them if they won't last.
  2. Banned
    Dec 2nd, 2007
    12-02-2008 04:50 PM #2
    ask
    all vw all the time (steve)
  3. 12-02-2008 05:05 PM #3
    I got them from Dave. He is not crazy about selling them for non race cars. Why I cannot say. Race cars would put way more load on them. But his concern I think is that they would be neglected more. As in not torque checking the bolts.
    I'm quite happy with mine. They are going to be properly painted this winter when I dig into the whole front suspension.
    Nice horizontal A arms though!
    Oh, don't forget to flip the tie rods too, to complete the geometry picture.
    There are some good hybrids.... The ones that burn gasoline and rubber!
    http://forums.vwvortex.com/showthrea...v-build-thread
    DCI until I die
  4. Senior Member Muffler Bearing's Avatar
    Apr 4th, 2004
    54 green, 67 yellow, 77 gold, 84 brown
    12-02-2008 05:08 PM #4
    boludito and WackyWabbitRacer to name a few
    A Rabbit is not to be wasted on the tentative or weak. Only the worthy are invited, and then only at your own risk. If you have even a modicum of hesitation, DO NOT buy one of these cars. Instead, leave it for a worthy soul who has already matriculated to the sublime ecstasy of what those in the know refer to as a "MK1"
    OLDSKOOLVW.COM Custom MK1 parts.
  5. Banned boludito's Avatar
    Apr 3rd, 2008
    12-02-2008 05:10 PM #5
    I gots em. They cool.
  6. Junior Member
    Jan 12th, 2006
    Adelaide, Australia
    1979 mk1, 1994 VR6T, 2000 A4BTQ
    12-03-2008 04:53 AM #6
    For those who have them, have you noticed any new handling problems as a result? eg, heavy or lighter steering, more front end push, or less feel in the steering?
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, APR stg 1, APR Bi-pipes, ABT coilovers, BBS CH, RNS-E
  7. Banned boludito's Avatar
    Apr 3rd, 2008
    12-03-2008 05:20 AM #7
    Um, no problems. Uses stock balljoints so you don't have to worry about replacing spherical bearings. Why would the front push more?
    You understand what these do right? Their purpose in lowering the control...
    Oh, you say that you heard stories of them breaking. Now, have you heard any stories of the pmw specifically? Cause only one that I heard was from dave and that was an early one.
    Modified by boludito at 2:22 AM 12-3-2008
    Modified by boludito at 2:23 AM 12-3-2008
  8. Junior Member
    Jan 12th, 2006
    Adelaide, Australia
    12-03-2008 06:12 AM #8
    No i haven't heard of any breaking, just the question about changing the steering geometry (kingpin inclination and scrub radius) causing handling issues.
  9. Banned boludito's Avatar
    Apr 3rd, 2008
    12-03-2008 06:19 AM #9
    I confused you with the OP.
    As for scrub radius and handling issues, all I can say is my car turns in better and feels better than before when it was at the same height but without the spacers. Make a noticeable positive change.
  10. Junior Member
    Jan 12th, 2006
    Adelaide, Australia
    12-03-2008 06:26 AM #10
    ok cheers mate exactly what i was looking for, i could have been abit more specific first up.
  11. Member rabbitarmy's Avatar
    Nov 16th, 2006
    raleigh, nc
    1980 2.0T Scirocco
    12-03-2008 09:09 AM #11
    Quote, originally posted by boludito »
    I should have specified, I haven't heard anything bad about the PMW extenders specifically, just that no ball joint extender is going to hold up.
    Thanks for sharing everyone
    Quote, originally posted by All VW All the time »
    Thats the whole reason I'm doing this actually. With the extreme angle my tie rods are at they have gotten a bit short & I don't have enough tie rod in the rod end to be totally comfortable with things. Going to use these:
    http://www2.cip1.com/ProductDe...13-11
  12. Member goosler's Avatar
    Feb 11th, 2002
    hunterdon nj
    12-03-2008 10:42 AM #12
    maybe you should try centering your rack again first?
  13. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    East of the Mountains, WA
    77' Rabbit 16v, '92 Passat Syncro Wagon1.8t
    12-03-2008 11:13 AM #13
    installed these this past summer and did one autox on them. car felt much better with front end grip and also pretty much eliminated the bump steer i was having. PMW also sells a tie rod flip kit for $35, i highly recomend them
    this car does see stints as my daily driver, and its probably had a few thousand miles on the road including two road trips 3hrs each way. I didnt buy them with the intent of running them on the street as much as i have, but they have worked perfect and show no signs of wear.
    being as this is my toy/track car in the summer time, i do go over the nuts and bolts in the car much more frequently then your average street car
    i have never heard of a quality ball joint extender breaking. if you look a little more into that rumor you will find that people have attempted to make these pieces in their garage, without proper knowledge of what they are building. that is when it gets dangerous
    Modified by -RalleyTuned- at 8:14 AM 12-3-2008
  14. Member rabbitarmy's Avatar
    Nov 16th, 2006
    raleigh, nc
    1980 2.0T Scirocco
    12-03-2008 04:36 PM #14
    Quote, originally posted by goosler »
    I'm pretty sure the rack is centered, I've got the newer style tie rods with adjustment on both sides.
    Quote, originally posted by -RalleyTuned- »
    I didn't see anything about a tie rod flip kit on their site. I'll give them a call & inquire about it. I don't have a problem periodically checking torque on them, its something I do with all suspension components regularly anyway.
  15. 12-03-2008 04:52 PM #15
    Quote, originally posted by rabbitarmy »
    Going to use these:
    The bugpak bushings are only 19.95
    Drill a 5/8" hole in the steering arm, press in the bushings, flip the rod ends. Done!
    Modified by All VW All the time at 4:53 PM 12-3-2008
    DCI until I die
  16. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    12-03-2008 04:54 PM #16
    when you order it just ask, comes with the insert and washers and all that jazz. just nice to get it all in a bundle. definetly replace the ball joints at this time if you have not already
  17. 12-03-2008 06:26 PM #17
    http://forums.vwvortex.com/zerothread?id=3770238
    Good info in there
    Anyone ordered them in larger lengths? I think SCCH makes 2" ones as their max.
    Modified by Danno13 at 10:39 PM 12-3-2008
  18. Banned boludito's Avatar
    Apr 3rd, 2008
    12-03-2008 08:11 PM #18
    scch's cost twice as much and need to welded onto the old knuckle, plus it's a spherical bearing. I wouldn't run that for too long on the street. The nice thing about PMW"s is that you use an oem balljoint.
  19. 12-04-2008 02:22 AM #19
    I can't leave this thread without commenting on the high price of these two pieces.
    I don't see these making a huge difference with bump steer. With the Mk 1 suspension anyways.
    Although I will say I've never used them on a Mk 1.
  20. Banned boludito's Avatar
    Apr 3rd, 2008
    12-04-2008 02:28 AM #20
    If you are complaining about the prices, you don't understand the time involved in producing these pieces. There are 13 setups just for the piece and they are solid and very well machined. I used to work in fabrication, and I'd rather pay 265 dollars for these than make them myself.
  21. 12-04-2008 02:45 AM #21
    I'm no machinist so I can't comment on the work involved.
    It was an immediate response to seeing these made for other cars with a much lower cost.
    I should just be happy someone makes them for the Mk 1.
  22. Banned boludito's Avatar
    Apr 3rd, 2008
    12-04-2008 03:05 AM #22
    Quote, originally posted by Autocross83gti »
    Many of the ones I've seen at lower costs have been know to fail.
    As far as PMW's reputation goes, I haven't heard of any failures except for one, which was due to not being installed properly.
  23. 12-04-2008 03:09 AM #23
    I was refering to ball joints made for other cars than the Rabbit. Just to clarify.
  24. 12-04-2008 10:56 AM #24
    I have always found this way to extend the ball joint a little bit to much in the machine work aspect and have always had in my mind a simple block type to move the factory ball joint up(such as my quick sketch) but i am unsure if the benifit of this is caused by the level control arm or the lengthening of the ball joint pivot point. please feel free to comment
  25. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    12-04-2008 12:04 PM #25
    exactly
  26. Senior Member Muffler Bearing's Avatar
    Apr 4th, 2004
    12-04-2008 01:23 PM #26
    Quote, originally posted by toplessvw »
    i have no idea what your ms-paint drawing is, but the benefit comes from moving the ball joint pivot away from the steering knuckle. pay no attention to whether or not the control arm itself is parallel with the ground, look at its two pivot points and the imaginary line drawn between them.
  27. Senior Member Muffler Bearing's Avatar
    Apr 4th, 2004
    12-04-2008 01:27 PM #27
    these are not ball joints.
  28. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    12-04-2008 01:32 PM #28
    Quote, originally posted by Muffler Bearing »
    i was tryin to figure out what he was saying! haha
    yes these are not ball joint replacements, they are EXTENDERS
  29. 12-04-2008 04:20 PM #29
    The public school system failed you.
  30. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    12-04-2008 04:24 PM #30
    i dont think im the only one confused by your statements...
    are you saying other ball joint extenders for other cars are much cheaper? can i see them?
    or are you saying these ARE ball joints and are too expensive? cause rabbit ball joints are like $20
  31. 12-04-2008 04:52 PM #31
    They're obviously not ball joints.
    I might be wrong about the prices I've seen for like parts. It's been a while since I've looked for them.
    But it doesn't really matter because those that need them and are willing to pay for them will do so without care for others opinions on price.
  32. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    12-04-2008 04:58 PM #32
    im curious as to what other cars these are made for?
    ive been looking at these for several years and have never had them at this price and proven performance. id like to see the other parts you are referring to
  33. Banned boludito's Avatar
    Apr 3rd, 2008
    12-04-2008 06:27 PM #33
    ep3 civics. They use macpherson front setups,
  34. Member
    Mar 26th, 2005
    Maine
    95 bmw 318ti
    12-04-2008 07:30 PM #34
    i'm curious about the added stress these would add on the ball joint.
    due to the increased torque produced by the lengthened arm do the
    ball joints wear more quickly?
  35. Banned boludito's Avatar
    Apr 3rd, 2008
    12-04-2008 07:44 PM #35
    I've been running them since September, and I personally have not experienced any issues. As for the rate of wear of the actual balljoint, I haven't noticed anything yet, but I am keeping an eye on it.
