Closed Thread
Results 1 to 35 of 35
Thread: Discuss all MFA Cluster Tricks (For the FAQ)...
  1. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    2008 Passat 4Mo 3.6L Wagon, 98 VRt, 2010 Routan/Caravan :)
    12-05-2008 07:55 PM #1
    Original quote from FAQ.
    Please discuss and keep it on topic. Please report any off topic discussion as this is currently linked-to in the FAQ.
    Thanks guys!
    Quote, originally posted by MJA311 »
    The Hidden Tach
    This is for people who don't have a tach or just a cool little trick.
    1. Push in the button that is right beside the mileage on the cluster and hold it in.
    2. Turn the key to the on position, (Don't start the car, just do it so that the electronics come on, and keep holding the button down).
    3. Turn the key back to the off position (still holding down the button).
    4. Start the car, let go of the button.
    5. You should now see a "1" in the little display, cycle through by pushing the button until you hit 7, you now should have a digital tach.
    Worked on my car but when i did this my gas gauge went screwy. After I turned the car off and back on the gas gauge went back to normal?
  2. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    12-05-2008 07:59 PM #2
    Quote, originally posted by jonbaker »
    to expand...
    MKIII Display diagnostics how to...
    1. Turn your key to the on position (do not start the car).
    I waited until all the lights and beeping calmed down and the gas gauge registed
    2. Push down the trip computer button
    3. Turn the key off while still holding the trip button down
    Again I waited until all the lights stopped and the gas gauge went back to "E"
    4. With the button still supressed, start the car.
    5. Release the button and cycle through the different functions.
    Mine reset to regualr speedo/trip functions the next time I started the car.
    I don't know what all the functions do I put the what my car read out below.
    Hopefully somebody who knows will post and tell us what everything is reading out.
    Function = Read out
    1 = 6214 (no idea what this is)
    2 = 4 (no idea what this is)
    3 = 31470 (for some reason I have seen this number before, maybe on my ECU)
    4 = 6
    5 = Lights all the LCDs in the gauge to see that they work
    6 = 0 (this counts either distance or revolution of front axles. not sure)
    7 = Digital tackometer (also plays with your feul gauge)
    8 = Trip counter
    the display will reset after you turn off your car...
    Oct 26th, 2007
    KIND
    95 - dusty vr, 96 - black beast trek
    12-06-2008 02:55 AM #3
    Quote Originally Posted by rlsib16 View Post
    as for me, the worst ive been caught doing was crashing and almost flipping golf carts at a town park i worked at. that high center of gravity catches you offguard sometimes.
  4. Member yeayeayea's Avatar
    May 29th, 2005
    md
    89 GTI 16v with carbs, 99 528i, 95 gsx600
    02-23-2010 08:54 PM #4
    i did the same thing but instead of holding the trip button i held the mfa button and it did wierd things with my mfa. can anyone explain this?
    Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
    my "build" thread: 16v+carbs FOR SALE!!!
    My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
  5. Member envy.'s Avatar
    Jul 27th, 2009
    Charlotte
    2011 Golf 2.5 5MT
    02-23-2010 08:59 PM #5
    SEARC.... oh wait... nvm.
    i'm glad this came up. anybody yet figure out why the digital tach makes the fuel gauge all screwy? i've noticed that it sort of acts like a vacuum gauge in it's behavior at times. it's probably just a coincidence.
  6. 02-23-2010 10:14 PM #6
    it takes the buffer away so it reads real time
  7. Member XVR6wagonX's Avatar
    Jul 26th, 2009
    Carolina, RI
    B4 passat(rip), 96 Jetta(rip), 99 Oldsmobile 88
    02-23-2010 10:30 PM #7
    I wanna try.
  8. Member wolfyy98's Avatar
    Aug 27th, 2008
    GTA
    '97 GTI VR6 Concept, '98 Golf Wolfsburg
    02-23-2010 10:55 PM #8
    tried this today with the digital tachometer feature. Its a neat thing to have, made my gas gauge act like the rpm gauge though
    PM ME FOR ALUMINUM SHIFTER BUSHINGS FOR YOUR VW/AUDI
    My Build Thread: The-Concept-Windsor-Progression-Thread
    http://www.vr6coilbracket.com : MSD IGNITION
  9. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    Jahre ABF, A4 B6, R6
    02-24-2010 05:13 AM #9
    The fuel gauge acts weird because it measures the fuel in "real-time" while in that "service-mode".
    When not in that mode, it has a delay so it won't bounce around.
    Quote Originally Posted by dankvwguy
    They toed my car to the toe yard
    THE CBOX KREW ----Mk3 16V club--------www.AWOL.tv---- STANCE|WORKS
  10. Member Davis.'s Avatar
    Jan 7th, 2010
    MKE
    '98 8v rolling scrap heap
    02-24-2010 08:59 AM #10
    I believe this is only on obd2 mk3's. I tried it in my '95 2.0 with no luck That's all I know on the matter
    Lower Standards
    Scooter's GTG 2013
    Canibeat - Cars | Culture | Lifestyle
    I don't belong to a club, I belong to a community
  11. Member dubbinway's Avatar
    Apr 24th, 2007
    Brea, CA
    1995 Jetta 2.0
    02-24-2010 09:09 AM #11
    worked on my 95 2.0 Maybe gauge cluster is bad?
    Cinnamon Toast Crunch!
  12. Member Davis.'s Avatar
    Jan 7th, 2010
    MKE
    02-24-2010 09:34 AM #12
    Quote, originally posted by dubbinway »
    nope, my gauge cluster worked just fine
    Doesn't matter now, unless it would work on my '88 16v
    Lower Standards
    Scooter's GTG 2013
  13. Member 91GolfGL's Avatar
    Feb 17th, 2005
    1994 Jetta 2.0L
    02-24-2010 10:03 AM #13
    I going to see if this works on my 94, I kind of hope it does i want to see the digital tach and my gas gauge go crazy lol.
    Quote Originally Posted by VW_Jake View Post
    Can anyone tell me what's up with the MKIII and the ABS light (air bag system).. This is the second one I've had recently that the light comes on and stays.
  14. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-24-2010 10:49 AM #14
    wen you hold the maf button instead of the trip button, it does only 3 functions, the instant mpg, oil temp, and something i dont know (mine said -40)
    and when you do the trip i thought that was the car doing instant mpg, reminds me of the ECONOMY gauges found in older mercedes benz's
  15. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    02-24-2010 10:56 AM #15
    Quote, originally posted by yeayeayea »
  16. Member mAyZa b 3 a t s's Avatar
    Nov 4th, 2009
    Canadensis, PA Shippensburg, PA
    A Yugo and a mule
    02-24-2010 11:53 AM #16
    to expand...
    Function = Read out
    4 = 6
    8 = Trip counter
    I'm pretty sure I've read somewhere that either #2 or #4 is the number of cylinders your car has, and the other ones have something to do with production. I can't find that article again though...
    Quote Originally Posted by Sodomythical Frostgoat View Post
    **** off Timmy, I'm trying to break someone's spirit here, jesus.
    If you use the term "hater," I'm just going to assume you came out with the cord wrapped around your neck.
  17. Member 91GolfGL's Avatar
    Feb 17th, 2005
    1994 Jetta 2.0L
    02-24-2010 05:43 PM #17
    I did it today worked great. I used the digi tach it was cool, It didnt make my gas gauge go all crazy either.
  18. 02-24-2010 06:16 PM #18
    Quote, originally posted by 91GolfGL »
    Did you have a full tank or nearly full? That could be why it didn't go nutz on ya.
  19. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    02-24-2010 06:25 PM #19
    Quote, originally posted by dubtech001 »
    Mine does it anyway
    And thanks yeayeayea, I was driving my car the other day, and wondered why there wasn't a way to show the instant mpg
  20. Member 91GolfGL's Avatar
    Feb 17th, 2005
    1994 Jetta 2.0L
    02-24-2010 06:36 PM #20
    Quote, originally posted by PettR »
    Mine does it anyway
    Nope just under a quarter tank. I think my gas gauge is a little screwy anyways so maybe thats it lol.
  21. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-24-2010 07:21 PM #21
    Mine does it anyway
    no problem, i found it on accident really. i couldnt remember if the mfa trick was done holding the mfa button or the trip button, but was surprised to see both worked! any clue what the mfa button trick means in the outside temp position? last night it said -40 on mine, and now it says 110
  22. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    02-24-2010 07:36 PM #22
    No, not sure, I think mine said -40 or something too
  23. Member yeayeayea's Avatar
    May 29th, 2005
    md
    02-25-2010 01:11 AM #23
    my mfa button rarely works so its hard for me to figure out what it means. my intermitten wiper also rarely works and my cruise rarely works. previous owner had one of those DUI breathalizer things installed so im guessing something isnt wired correctly.
  24. Member
    Mar 27th, 2010
    Oakland, CA
    2001 Cabrio GLX
    05-01-2010 05:00 AM #24
    4 = 6
    8 = Trip counter
    From elsawin:
    1= Distance Impulse number - the number of speedo sender pulses required to +1 the odometer. for miles the number is in the 6000 range, for kilometers the number is in the 3000 range.
    2 = Clock display mode - 1: Europe (24 hour time) 2: Canada? 3. UK (12 hour) 4. USA (12 hour) 5. South Africa?
    3 = Speedometer and rev. counter code
    4 = number of cylinders, or ratio for alternator/engine revolutions. (for tach calibration)
    5 = Segment test (lights all LCD segments)
    6 = Speedomenter sender impulses - each wheel revolution adds 7 to this count.
    7 = RPM counter - momentary engine speed
    8 = program version
    I actually dumped the ROM image from my cluster one afternoon while I was bored and did a little experimentation. Turns out you can recode the cluster from miles to Km and back by changing 3 bytes. You can change the clock display mode by changing 1 byte. And you can change the number of cylinders by changing another byte.
    Also editable is the smoothing for the fuel and temp guages, as well as the values to trigger the low fuel and temp lights, although I haven't quite figured them out yet.
    One day I'll do a writup/DIY for all of that, however there are different cluster versions which undoubtedly have different ways of organizing that data in ROM, so what works for me may not work for others. So, I need to find me a few different junkyard clusters to tinker with before a writeup to warranted.
    Modified by ikerpup at 2:07 AM 5-1-2010
  25. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    05-01-2010 08:12 AM #25
    Very good post
  26. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    05-01-2010 09:08 AM #26
    wish i had the MFA, stupid base line GL
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
  27. Member mkIIIVDUB's Avatar
    Feb 23rd, 2004
    Ocean City, MD
    95 surf 20vt
    05-01-2010 10:53 AM #27
    a trick i use when the lights shut off in my cluster is to hit the dashboard above the cluster really hard a few times. it seems ti do the job
    *2011 MkIII Kickball Champions*/OCVW/DJR MK3 HELP PAGE/Never Forget/MkIII.net
  28. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    05-01-2010 11:03 AM #28
    If you have the car running, or the igniton on while you're filling the gas tank, and your fuel gauge needle still sits where it did before you filled it with gas, you can just put it in diagnostics mode, and it will show up correctly immediately.
  29. Member oh noes! cars!'s Avatar
    Apr 24th, 2007
    Mississauga, Ont.
    '07 Mazda 3s GT, '13 Subaru Impreza Sport
    05-01-2010 11:58 AM #29
    Quote, originally posted by sk8too »
    No 2.0 cars had it, but you can still do the cluster tricks
    Quote Originally Posted by MK420TH92 View Post
    Now b/c of this im fkn paranoid about mines. For for theifs out there u better watch out... cuz im nockturnal....i dont go to sleep till 4am either.... and i bought a machette a ago... if i see u near my car im running out there and ima chop ur ass up.... real shiitt
    http://www.trailburn.ca
    We are giants, with stars at our fingertips
  30. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    05-01-2010 12:28 PM #30
    Quote, originally posted by oh noes! cars! »
    No 2.0 cars had it.
    A few in Europe does
  31. Member Yugoslavia!'s Avatar
    Feb 7th, 2010
    Scandinavian Venice
    '98 JB Cabby
    05-01-2010 03:24 PM #31
    Haha love when someone in NA state a fact and then some Euro Trash pop by and ruins it all.
    Seriously though, Petter Northug is absolutely right. AFAIK all GTIs (8V & 16V) have MFA.
  32. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    05-01-2010 03:27 PM #32
    Quote, originally posted by Yugoslavia! »
    I always do that
  33. Member oh noes! cars!'s Avatar
    Apr 24th, 2007
    Mississauga, Ont.
    05-01-2010 03:27 PM #33
    Since the discussion was primarily based with NA users, I feel it was a correct statement since no NA 2.0 cars had mfa.
    It's irrelevant that EU cars had it, as it wouldn't work in an NA car without serious modification.
  34. Member
    Mar 27th, 2010
    Oakland, CA
    2001 Cabrio GLX
    05-01-2010 03:27 PM #34
    They did in the UK, which makes for a perfect swap to a US vehicle since its already in miles. Although you still have to do wiring. I recently came up on a MFA cluster from a VR6 jetta which I'm planning to put in my cabrio once I get the wiring all figured out. (again, you can change the tach from 6 to 4 cyl by editing the rom)
    http://cgi.ebay.co.uk/ws/eBayI...%3AIT
    Kinda wish I had seen that before getting mine, I'm not a big fan of the silver faces on mine. But at least the face will be correct for an american car (miles, and temp in F)
    Modified by ikerpup at 12:31 PM 5-1-2010
  35. Member Yugoslavia!'s Avatar
    Feb 7th, 2010
    Scandinavian Venice
    '98 JB Cabby
    05-01-2010 03:45 PM #35
    Sure but saying no 2.0 had it isn't absolutely correct.
    Never mind, I'll go and carry on hunting polar bears and eating lutfisk.
Closed Thread
