VWVortex.com - pin out diagram for the cluster
    Results 1 to 19 of 19
    Thread: pin out diagram for the cluster
    1. 12-07-2008 07:16 PM #1
      doing a mk4 dash swap into my mk3,
      So if you guys can help me and post the pin out will help me a lot.
      Thanks in advance
      P4c
      well right now it looks like this,I start putting it on tomorrow
      Modified by 2.8dohcvtach at 3:56 PM 12-7-2008
    2. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      2002 Bora TDI, 1994 2.0 16v Corrado, 1991 MK2 Golf, 1983 MK1 Golf Driver, MK4 Golf, 1971 Fastback
      12-07-2008 07:47 PM #2
      best thing to do is to get elsawin and figure it out yourself. I could do it easily but it would take me 3-4 hours of trawling through diagrams to get you all the pin outs. Sorry but I ain't doing it.
    3. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      12-07-2008 07:49 PM #3
      Quote, originally posted by 2.8dohcvtach »
      Buy the Bentley manual for the MK4; you'll need it.
      That has the complete pinout for the ECU, the cluster, and everything else...
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    4. 12-07-2008 07:49 PM #4
      Quote, originally posted by Bazmcc »
      I just need the cluster pin out...
    5. Member pdxbora's Avatar
      Sep 22nd, 2008
      Oregon
      2012 Audi A5 2.0T
      12-07-2008 07:50 PM #5
      i have no DIY skills or experience whatsoever, but i just wanted to say good luck and keep us posted!
    6. Member Bazmcc's Avatar
      Jan 10th, 2005
      Northern Ireland
      12-07-2008 07:58 PM #6
      I know, but.....
      The elsawin system doesn't show a single diagram for the cluster. You'd have to search every section for all the wires going to the T32a and T32 connectors. That's 64 different wires and I have no idea how many different diagrams it would be though. I'd need to be pretty bored to just dig them up for someone.
      I'm sure someone somewhere has already done it though.
    7. 12-07-2008 07:59 PM #7
      I know, but.....
      oo because the mk3 is simple,And i only need to wire 14 wires out of those 64...
    8. 12-07-2008 08:03 PM #8
      Quote, originally posted by bluefox280 »
      Instrument CLuster 32-pin Connector (Green) Terminal Identification
      #1-#16 right side from up to down
      1.) open
      2.) open - reading coil for immobilizer 1 (from 05.99 prod.)
      3.) open
      4.) open - data bus (CAN), shielding for input (from 05.99 prod.)
      5.) W-wire (where applicable)
      6.) low level washer fluid
      7.) brake pad indicator
      8.) external buzzer - open from 05.99 production
      9.) open
      10.) fuel reserve warning - open from 05.99 production
      11.) signal for vehicle stationary
      12.) air conditioning system cut-off - ECT signal
      13.) parking brake indicator light (K14)
      14.) warning light for traction control / vehicle stability
      15.) open
      16.) open
      #1-#16 left side from up to down
      17.) open - reading coil for immobilizer 2 (from 05.99 prod.)
      18.) open - oil temperature and oil level warning signals
      19.) open - data bus (CAN), high input signal (from 05.99 prod.)
      20.) open - data bus (CAN), low input signal (from 05.99 prod.)
      21.) open
      22.) open - input signal from hood alarm switch (from 05.99 prod.)
      23.) MFI call up button - top (display switches forward)
      24.) MFI call up button - bottom (display switches backward)
      25.) MFI memory switch - reset
      26.) ambient air tempertature sensor
      27.) open - data bus (CAN), high output signal (from 05.99 prod.)
      28.) open - data bus (CAN), low output signal (from 05.99 prod.)
      29.) open
      30.) output signal 2 from electronic speedometer - open (from 05.99 prod.)
      31.) selector lever display - open (from 05.99 prod.)
      32.) fuel consumption signal - open (from 05.99 prod.)
      you think you can get me the blue connector pin out?
      because mk3 doesnt have any of those options above,and thanks in advance
    9. 12-07-2008 08:11 PM #9
      Now which of these power the little red trip? because mine seems to be fading away im guessing the wire is getting a bad connection?
    10. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      12-07-2008 08:11 PM #10
      Was working on it... hold your horses:
      Instrument Cluster 32-pin Connector (Green) Terminal Identification
      1.) open
      3.) open
      9.) open
      15.) open
      16.) open
      #17-#32 left side from up to down
      21.) open
      29.) open
      Instrument Cluster 32-pin Connector (Blue) Terminal Identification
      1.) terminal 15, positive
      2.) right turn signal indicator light (K94)
      3.) output signal 1 from electronic speedometer
      4.) open
      5.) fuel gauge (G1)
      6.) airbag malfunction indicator light
      7.) terminal 31, sender ground (GND)
      8.) engine coolant temperature gauge (G3)
      9.) terminal 31, ground (GND)
      10.) oil pressure switch (F1)
      11.) RPM signal - open from 05.99 production
      12.) generator warning light (K2), terminal 61
      13.) glow plug indicator light (K29 - diesel only), control light for rear seat backrest lock from 05.99 production (only certain countries)
      14.) open
      15.) open
      16.) warning light for rear lid open (only certain countries)
      17.) headlight high beam indicator light (K1), terminal 56a
      18.) left signal indicator light (K54)
      19.) ABS warning light (K47)
      20.) instrument cluster illumination, terminal 58b
      21.) signal for open driver's door
      22.) engine coolant level (ECL) sensor (G32)
      23.) terminal 30, (B+)
      24.) terminal 31, ground (GND)
      25.) on-board diagnostic (K-wire)
      26.) parking light right, signal for "lights on" warning buzzer
      27.) parking light left, signal for "lights on" warning buzzer
      28.) speedometer vehicle speed sensor (VSS) (G22)
      29.) warning light for brake system fluid level
      30.) ignition key warning buzzer, terminal 86s
      31.) seat belt warning system
      32.) emission workshop lamp (only certain countries) - open from 05.99 production
      You're welcome. Paypal me!
      - Erik
      Modified by bluefox280 at 5:16 PM 12-7-2008
    11. 12-07-2008 08:15 PM #11
      thank you very much man,I see theres a few nice ppl on the mk4 forum =]
      maybe ill join you guys soon,but my idea is kinda questioned by me,if i ever get a mk4 but hey,maybe is doable.
    12. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      12-07-2008 08:20 PM #12
      Oooh, there are... between all the muck, we exist.
      Just need to ask / bribe the right tech-guru's.
      - Erik [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. 12-07-2008 08:22 PM #13
      One thing im wondering is,If my cluster is going to be looking like xmas since im not going to be using many features.
    14. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      12-07-2008 08:28 PM #14
      ...[will] my cluster is going to be looking like xmas since im not going to be using many features...
      Yes, but you can easily create powered "by-pass" circuits.
      - Erik
    15. 12-07-2008 08:30 PM #15
      - Erik
      good to know,Ill look for that later,I still have a lot of work to do
      tomorrow im swapping the whole mk4 heater and a/c core...
    16. 12-10-2008 05:42 PM #16
      for some on of you that wanted updates.
      mk3 heater box out
      mk4 heater box in
      And where im at right now.
      Modified by 2.8dohcvtach at 1:43 PM 12-10-2008
      Modified by 2.8dohcvtach at 1:45 PM 12-10-2008
    17. Member ryannorris16's Avatar
      Apr 7th, 2008
      Static in the 864
      05 4Motion Passat, 82 VR6 Jetta
      12-10-2008 05:49 PM #17
      wow, thats a lot of work. hope it goes well.
    18. Member Tdotdub's Avatar
      Nov 14th, 2008
      Toronto ON
      99 Beetle (past and present), 94 golf was TD now 1.6D FML, 87 Audi 5000 x2
      03-04-2010 01:10 AM #18
      so anything new happened?
      I am thinking on swapping my mk3 cluster with an mk4 one.. I already test fitted it.. and with a bit of modification you can make it fit
    19. 03-04-2010 01:40 AM #19
      wow i like
