Last week we had the chance to do back to back runs on the same car on the dyno to get a comparison with our ABA Stg1 PEM vs Nuespeed which was in the car:
#1
Introducing Black Forest Industries' latest release for the VW community, the new PEM or Performance Enhancement Module. Developed with C2 Motorsports exclusively to Black Forest Industries specifications for the ABA, the PEM is programmed, stocked and shipped in-house from BFI. The PEM is a collaborative success between two of the leading aftermarket names in the industry.
The PEM is designed specifically to not only increase power and throttle response, but to also smooth out the power as it is delivered throughout the RPM range. Additionally , the PEM does not require a secondary oxygen sensor reading for mapping, nor is it affected by secondary air injection.
Carefully mapped adjustments to the fueling and timing allow the most to be extracted from VW's bulletproof powerplant. All tuning was dyno-tested to ensure real world increases in performance and power. This file is tuned on 93 octane, however the ECU will pull enough timing if you had to run 91 or even 89.
Available for both ABA and VR6 OBD2 motors in Stg1. Camshaft specific Stg2 files are also available for both motors as well.
ABA Stage1 - Click Here
ABA Stage2 - Click Here
VR6 Stage1 - Click Here
VR6 Stage2 - Click Here*In stock and ready to ship
ABA Stage1 vs Stock
ABA Stage2 vs Stock
Modified by adam@blackforest at 3:01 PM 12-12-2008
#2
#3
any dyno results for the VR?
#4
As for VR6 specific dyno, we did just have the chance to do a back to back comparison on a mk2 vr6 swap with our Stg2 PEM and the GIAC cam file chip that was in the car already:
The overall numbers seem a bit low, as the car still had the MK2 8v cat and catback exhaust on it. But the gains of the PEM can still clearly be seen.
#5
Is there anything that can be done with regards to the evap system? I seem to have misplaced mine...
My all motor build: http://forums.vwvortex.com/showthrea...th-real-butter!
#6
Sorry not from us
#7
for a obd2 VR, does this chip ignore the SAI pump?I have a failed pump, and looking at deleting the system and plugging the hole. If the software doesn't use the pump, I could avoid the CEL from "incorrect flow"
I have to laugh when someone calls me an a*****e. I've been called far worse than that.
- Gordon Ramsay
#8
Yes both motors' PEM dont require SAI to function fully
#9
Quote, originally posted by adam@blackforest » Yes both motors' PEM dont require SAI to function fully W/ Software, no CEL from SAI delete?!?!!? :yippee:
- Gordon Ramsay
#11
off topic but adam do you guys have rear bilstein sport shocks in stock for a mk3 vr dont think vr6 matters. i am looking to order a pair asap lol
#12
also want to say i have the c2 chip on my ob2 vr not sure if its the same its stage 1 and ill tell you the idle is perfect, car pulls good even with 242k and best thing is no need for a rear o2 or sai and still passes emissions . definitly the best chip out i think
#13
Quote, originally posted by KnightRider200sx » off topic but adam do you guys have rear bilstein sport shocks in stock for a mk3 vr dont think vr6 matters. i am looking to order a pair asap lol Yes they are available on our website
#15
OBDII ABA swap into a MKII. Not going to run into any problems right?
#16
The PEM's are for MK3 ECU's and harnesses, so as long as its a full swap with the MK3 set up yes no problems
#17
What kind of performance numbers should be expected with an autotech 270 cam on an OBD1 ABA?
#18
We only offer software for OBD2 at this time
#20
THOROUGHLY impressed with this chip!
#22
Do you ever plan on making an obd1 chip?
#23
I see that you state that it requires 93 octane, but can pull enough timing to run 91 or 89. I have a 97 vr and would be interested in running this chip, but out here in CO, you can only find 91 at the pump. There are specialty places that sell 93, but few and far between. What do you suggest?
~I love thunder red!!!~
#24
yes you can run 89 or 91 octane. its in BFI's first post.
#25
Correct![]()
#26
i purchased a giac cam chip a while back and it caused bucking issues that where never solved even with a replacement chip i was sent.if i would try your chip would i be able to return it if it doesnt work either.
It's his right to go off on whoever he wants. Etiquette isn't a requirement in America. It's his right as an American to be a douchebag. :-) You don't hate America, do you?
#27
Sounds more like there is an issue with your specific car, than the software. We check all our PEM's before they go out to make sure they were flashed properly and fully functional
#28
Quote, originally posted by steve-o 16v GLI » i purchased a giac cam chip a while back and it caused bucking issues that where never solved even with a replacement chip i was sent.if i would try your chip would i be able to return it if it doesnt work either. You probably had an issue with your car that was independent of the chip. I experienced an issue when I installed my PEM....after speaking with Adam and trouble-shooting, turns out it was the MAF I replaced last August that was the culprit. Car ran 100% once I fixed the MAF issue.
#29
were does the chip go in the ecu exactly? i have your pem just cant figure it out. i know it most likely is super easy to install, i just dont wanna mess up my ecu!!!
#30
It replaces the stock ECU's EPROM chip, which when you open up the ECU looks like the square chip thats inset on the top of our PEM
#31
#32
your the man thank you very MUCH!!!![]()
#33
is there a difference between the c2 chip u guys sell vs the c2 chip reflex tuning sold awhile back?
#34
Quote, originally posted by adam@blackforest » Last week we had the chance to do back to back runs on the same car on the dyno to get a comparison with our ABA Stg1 PEM vs Nuespeed which was in the car:
what other mods on car??? just wondering
#35
None really, it had a cone filter and thats about it
