VWVortex.com - BFI PEM Software Upgrades for ABA & VR6
    Page 7 of 10 FirstFirst ... 345678910 LastLast
    Results 151 to 175 of 231
    Thread: BFI PEM Software Upgrades for ABA & VR6
    1. 05-12-2011 09:23 AM #151
      hey im running obd 1 trying to run spray,cams and a chip is there anythingout there aviable ifnot for obd1 maybe for obd 2
    2. 05-16-2011 12:55 PM #152
      Quote Originally Posted by Baked GLX View Post
      There are options out there for OBD-1, but we do not offer one. We do however have OBD-2 options.
      May 23rd, 2010
      Somewhere in the 610
      97 2.slow RIP, 97 vr jetta SOLD, daily 98 vr jetta
      06-01-2011 05:39 PM #153
      If I'm running JE forged pistons 8.5-1 with 262 autotech cams, which chip should I use for my SAI delete and for the low compression pistons.? The car idles around 650-700rpms( sometimes lower) and that's when the car has been driven. On a cold start, it will only hold an idle unless my foot is on the gas for a few mins. It's been fully rebuilt top and bottom but this is my only problem. Any advice?
    4. Junior Member chrismacuser's Avatar
      Feb 27th, 2011
      Audi B6 1.8T
      06-20-2011 02:33 AM #154
      Just ordered the BFI PEM Stage II High Compression chip to go along with the 262 cams and MK4 headgasket I ordered.
      I'll let you know how I like my new setup when it arives
      Anyone know about how long does BFI usually take for shipping?
      P.S. BFI, what is the difference between "stock" and "high compression" on your website??
      X2 I have the same question
    5. Member ia13x's Avatar
      Jan 17th, 2007
      Mount Arlington NJ
      03 GLI 24v VR6
      06-22-2011 10:12 PM #155
      I just got a 96 VR6 obd2, the P/O claims its has 268 schrick cams but I'm unsure how to tell if it really does. So now im stuck, i want to chip it but idk what way to go. if I go with the stage 2 and it really doesnt have the cams will it hurt my car? or vice versa, if i go with the stage 1 and i do have the cams. i think i need help with this
      LoW-N-SloW
      **Don't forget your rubbers!**
      Wheel and Tire mounting and balancing services available.
      PM for more Info
    6. Member less.than.jeff's Avatar
      Sep 1st, 2008
      PNW
      '97 Black GLX
      06-24-2011 04:02 PM #156
      I still have the BFI PEM chip in my car. I'm extremely satisfied with it! I've been CEL free for a year now and the powerband is AWESOME!
      I *think* high compression is if you are running a MK4 headgasket (not positive)
    7. Member ia13x's Avatar
      Jan 17th, 2007
      Mount Arlington NJ
      03 GLI 24v VR6
      06-24-2011 10:28 PM #157
      Ok so I did a little research. Which meaning spent a good 30mins on the phone with BFI technical support trying to find the answer to my question. He gave me alot of good information so I felt the need to share it for the others that may run into this dilemma. If you're unsure about what cams you have in your VR and don't have the means and/or time to find out, the stage one chip is the way to go. It wont do any damage. And let's say later down the road you find out that you do have cams or your ready to have cams installed, BFI has a service to take that stage one chip and turn it into a stage two with all the information you give them for 25$. Pretty sick I'd say.
      LoW-N-SloW
      PM for more Info
    8. 07-03-2011 11:24 AM #158
      pm seeeeeeeeeeeeeeennnnnttttttt
    9. 07-11-2011 02:01 PM #159
      I have a '97 GTI 12v Vr6. Engine is pretty stock, aside from a cone filter.
      Stage 1 vs Stage 2? Explain it to me like im a 5 year old...
    10. 07-11-2011 11:56 PM #160
      Stage 1=stock cams....stage 2=not stock cams....that's pretty basic dude lol
    11. 07-12-2011 12:07 AM #161
      Quote Originally Posted by gtiswapped96 View Post
      What can I say, I'm a pretty basic dude.
      Thanks for the clarification though!
    12. 07-12-2011 06:20 AM #162
      Very nice ::said with borat accent::
    13. 07-12-2011 01:21 PM #163
      Quote Originally Posted by IT Guy View Post
      So Timmy, you see here, theres a SCROLL bar.
      Now if you use that SCroll bar to, SCROLL UP...
      you'll see that your question was THOROUGHLY explained ALREADY!!
      I'm a jerk...
    14. 07-16-2011 08:37 PM #164
      OK here's my question i just recently bought/installed your 268 cam and stage 2 chip(cam specific) and new Tbelt and tensioner(mech timing and ignition timing are spot on) and it
      keeps throwing Code when rev-ed over 4500-5500rpm (DTC) P0327 Knock Sensor Circuit Fault .....why ? any insight? we tried n
      a new knock sensor ,then we used a spacer kit o
      for the knock sensor, cleaned MAF, ran 91 octane with an octane booster
      anyone....
      could it be the my ignition timing is still off slightly????If it were a wiring issue, the CEL would come on immediately after starting the car, right? I thought we set the ignition timing correctly but maybe not , But it needs be at running temp, and no CEL on when the timing is being set so the ECU dosent set it itself. Will the ignition timing being off, set off the knock sensor?
    15. 07-18-2011 10:27 PM #165
      Quote Originally Posted by bluntman220 View Post
      anyone....
      NM it ended up being one broken wire on the car side of the knock sensor wire which caused the ecu to advance timing and trow a code and the car into limp mode...works A-1 now
    16. 07-19-2011 07:17 AM #166
      Just installed my 270 cam and stage 2 pem right before waterfest and she was haulin assssss...good thing I didnt catch on fire cause I didn't inst the injectors all the way after rep the head....faaaaaiiilllll!!!! But no CEL with no cat means passing inspection so kudos to you BFI!!!! BTW where was ur booth at wf? Couldn't find it at all prob cause I'm blind tho lol anyways sick module
    17. Member cm123's Avatar
      Jun 3rd, 2010
      Westchester/Long Island NY
      98 mkIII Jetta Wolfsburg(sold), 2005 Volvo s60R
      08-26-2011 11:55 AM #167
      The stage1 chip for the ABA is the street or race file?
    18. Member Vagilia's Avatar
      May 24th, 2010
      Silver Spring, MD
      09-11-2011 02:38 PM #168
      It just plugs right into the computer.. once taken the stock one out right? no saudering
    19. Forum Sponsor pete@blackforest's Avatar
      Aug 18th, 2011
      Raleigh, NC
      VW/Audi/BMW
      09-13-2011 12:45 PM #169
      Quote Originally Posted by cm123 View Post
      Sorry, this slipped through the cracks.. Stage I is a street file. Stage II is cam specific.
      Quote Originally Posted by Vagilia View Post
      Yeah, OBD-II cars plug right in.
    20. Forum Sponsor pete@blackforest's Avatar
      Aug 18th, 2011
      Raleigh, NC
      VW/Audi/BMW
      09-15-2011 11:41 AM #170
    21. Member cm123's Avatar
      Jun 3rd, 2010
      09-15-2011 01:12 PM #171
      If the front o2 sensor goes bad, will that cause the car to shut off on me while driving/idling? I've changed the ignition coil distributor and spark plugs and front o2 sensor within the last year.
      Also I'm not getting any codes at all regarding the front o2 sensor.. Only code im getting is P0172.
    22. Forum Sponsor pete@blackforest's Avatar
      Aug 18th, 2011
      Raleigh, NC
      VW/Audi/BMW
      09-15-2011 05:11 PM #172
      Have you checked your MAF?
    23. 09-15-2011 09:05 PM #173
      hey i just wanna drop my 2 cents about the famous p0172 dilema...ive been chasing it since waterfest..
    24. Member cm123's Avatar
      Jun 3rd, 2010
      09-15-2011 09:12 PM #174
      Quote Originally Posted by pete@blackforest View Post
      wouldnt a code come up for that MAF if there were a problem with it?
      ill take out the MAF and clean it.
    25. 09-15-2011 10:06 PM #175
      i swapped in a brand new bosch maf and still got the code
    « Back
