VWVortex.com - DIY, Seat removal instructions
    Results 1 to 25 of 25
    Thread: DIY, Seat removal instructions
    1. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      2016 GTi AutoBahn; 2016 Tiguan R-Line; Gone but not forgotten: 2006 Audi A3 3.2T
      12-15-2008 11:51 AM #1
      As requested...but quick and dirty!
      Front:
      1) If you don’t have a VAG-COM, you should disconnect the Ground connection to your battery to prevent the AirBag error light from staying on.
      2) Put seat as far back as possible
      3) Remove 2 front bolts using triple square (size to be posted once checked again)
      4) Put seat as far front as possible
      5) Remove 2 rear seat rail covers. Remove 2 rear bolts using triple square
      6) Disconnect connectors on front side of seat
      7) Remove seats.
      Rear:
      1) Remove rear seat bench. One side at a time, pull up on the front of the seat, then push the seat bottom towards the rear, unlatching it from the rear hooks.
      2) From hatch, remove floor cover, exposing a black plastic cover in between both seats. This cover is pretty hard to remove. You want to try and slide your finger, or some object, under the bottom and pry outwards to the sides gently. If this breaks, you won't die...its just a cover, not a necessity except for looks.
      3) Once cover is off, remove the screw and a securing clip.
      4) Lift the seat back out of the center mount and pull the back towards the center of the car, removing it from a pin hole.
      5) When removing the larger seat backing, there will be a bolt holding the center seat belt down. Remove that.
      Reinstall everything.
      Tightening torques: For the center bolt under plastic cap, its 15 Nm. For the seat belt bolts, its 55 Nm.
      Pics can be taken upon request.
      Modified by krazyboi at 9:59 AM 4/1/2009
      Modified by krazyboi at 10:06 AM 4/1/2009
      722 pages, 25255 posts, and 1,015,739 views later... R.I.P. LoL Bump thread 03/27/2008 ~ 02/16/2011.
      Link to my build: Audi A3 3.2 VR6 BT
      CleanAudi.com feature
    2. 12-15-2008 12:49 PM #2
      Great instructions....
      OK....I have to ask...what on earth is a 'triple square'? Most seat bolts I've seen are Torx or tamper Torx.
    3. Member yoonskim's Avatar
      Jun 8th, 2003
      Amsterdam, NL & NY, USA
      2008 Audi A3 2.0T / 2011 BMW Z4
      12-15-2008 12:58 PM #3
      ABS error light?? Airbag lights right?
    4. Member terje_77's Avatar
      Dec 19th, 2005
      SF, CA
      2009 TT, 2008.5 A3
      12-15-2008 01:10 PM #4
      Quote, originally posted by mcowger »
      It looks like a Torx but with more teeth.
    5. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      12-15-2008 01:25 PM #5
      Quote, originally posted by yoonskim »
      Whatcha talkin about?
      Quote, originally posted by terje_77 »
      Correct...there's 12 teeth. Basically 3 squares placed together making up the tool.
    6. Member
      Feb 2nd, 2006
      South Central KY
      15 Golf TDI 14 F150
      12-16-2008 01:38 AM #6
      added
      If you can't take the HEAT be a COP
      2B1 ask 1
    7. 12-16-2008 08:23 AM #7
      Quote, originally posted by krazyboi »
      Front:
      7) Remove seats.
      Rear:
      Reinstall everything. Pics can be taken upon request
      Modified by krazyboi at 12:23 PM 12/15/2008
      we should have taken a video to show hot to do it in 15 minutes
    8. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      12-16-2008 01:58 PM #8
      Quote, originally posted by angryrican66 »
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] agreed! perhaps another time
    9. Member terje_77's Avatar
      Dec 19th, 2005
      SF, CA
      2009 TT, 2008.5 A3
      12-16-2008 02:01 PM #9
      I'm sure it would hit the top of the charts on youtube!
    10. 12-16-2008 03:03 PM #10
      Thanks.
      Dammit, another new tool to buy
    11. Member terje_77's Avatar
      Dec 19th, 2005
      SF, CA
      2009 TT, 2008.5 A3
      12-16-2008 04:37 PM #11
      Thanks.
      Buy or borrow mine if you're only going to use it one.
    12. 12-16-2008 11:12 PM #12
      Sometimes autozone has triple square sets for cheap, but your best bet is ebay. VIM is the brand i use at my dealer. Inexpensive and reliable. This is the most common sizes you'll need for audi's/Vw's.http://cgi.ebay.com/ebaymotors...Tools
      Modified by live2skate4me at 7:13 PM 12/16/2008
    13. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      12-17-2008 09:17 AM #13
      ^^^ that's the same set I purchased, but from another site.
      Also, I know of a triple square set that also comes w/ the strut spreader we need for our front suspension. Not sure what brand it is, but I know it exists.
    14. Member skotti's Avatar
      Sep 27th, 2005
      Charlotte
      2006 A3 2.0T MT w/ Lots of Mods
      04-01-2009 09:59 AM #14
      BIG thanks and to krazyboi for his telephone assistance with my seat removal! It was as easy as he said- I'm just paranoid and had to ask him a few questions...
      Friends don't let friends drive stock.
      2006 A3 2.0T 6MT with LOTS of mods
    15. Member
      Mar 24th, 2008
      2008.5 A3 2.0T FWD (RIP), 2013 A3 2.0T quattro
      04-01-2009 10:33 AM #15
      Anyone know what the specified torque is on the bolts that retain the seats?
      I have to remove mine sometime in the coming months to install some tactile transducers, but I'd like to know what the fastener torque is when reinstalling.
    16. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      04-01-2009 11:05 AM #16
      Quote, originally posted by Audi'sRevenge »
    17. Member
      Mar 24th, 2008
      04-01-2009 02:39 PM #17
      Thx
    18. Member skotti's Avatar
      Sep 27th, 2005
      Charlotte
      04-01-2009 02:41 PM #18
      FWIW, I was able to remove the black plastic center cap with minimal damage (cracked a little)- best to use fingers and pry, trying from different spots.
    19. Member skotti's Avatar
      Sep 27th, 2005
      Charlotte
      04-02-2009 10:01 PM #19
      Additional information (FWIW): If you are changing your non-powered driver's seat to a powered seat, you will have to run an additional harness for power (3 wires/pins). If there is a harness already installed and taped up somewhere, I couldn't find it
    20. 07-09-2009 10:23 AM #20
      Anyone remember the size triple square required to remove the front seats?
    21. Member krazyboi's Avatar
      May 19th, 2004
      NoVA
      07-09-2009 10:38 AM #21
      Eh, its been a while, but my guess is 12 or 14. I don't have my car so I can't check.
    22. 07-20-2009 09:31 PM #22
      10MM was the size
    23. 04-22-2013 04:26 AM #23
      I have removed the front seat in my 2007 A6 avant to get to my bluetooth module as per instructions i.e disconnect ground on battery to prevent the airbag light staying on, having put everything back together the airbag light is STAYIN ON !!!! does anyone have any idea how to rectify this without a VAGCOM.
    24. Member Ponto's Avatar
      Jan 11th, 2012
      Edmonton, AB
      2007 Brilliant Black A3 3.2
      04-22-2013 12:38 PM #24
      Quote Originally Posted by wingsous View Post
      Did you clear all the codes once reconnected? I know some cars when the battery is disconnected it sets off a lot of codes...
      2007 A3 3.2vr Lava Grey S-line / Killed in Action
      2007 A3 3.2vr Brilliant Black S-line
    25. Member Ponto's Avatar
      Jan 11th, 2012
      Edmonton, AB
      04-22-2013 12:42 PM #25
      Also.. In for Pic request...
