VWVortex.com - 2006 Passat - Replacing Headlight Bulb
    Results 1 to 12 of 12
    Thread: 2006 Passat - Replacing Headlight Bulb
    1. 12-17-2008 12:52 PM #1
      My headlight bulbs need replacing. I know this is a relatively simply fix, but would like some instruction. Does anyone have a picture diagram or step by step instructions on how to replace the headlight bulbs? Thanks in advance.
    2. Angry Turtle Administrator nater's Avatar
      Apr 10th, 2000
      2008 3.6L Passat 4Mo, 98 O2M 3.0L VRT, '04 .:R32, 2010 Routan
      12-17-2008 10:46 PM #2
      Email me:
      (email removed, solution seen below)
      and I'll send you the PDF's from the Bentley.
      As a moderator I'm usually able to add attachments to posts w/o hosting but for some reason the lighting forum isn't allowing it right now (and I'm a bit lazy to host it on my website right now).
      <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/grinsanta.gif" BORDER="0">
      Modified by nater at 9:48 AM 9-15-2009
    3. Angry Turtle Administrator nater's Avatar
      Apr 10th, 2000
      12-17-2008 11:08 PM #4
      Quote, originally posted by GT17V &raquo;
      if you hellas (it will say on the assembly)
      http://forums.vwvortex.com/zerothread?&id=2706234
      and...
      http://forums.vwvortex.com/zerothread?id=4161259
      Thanks Tan (for the second link)...
      Don't email me - as I'm going to email you the PDF's that are in the second thread mentioned above.
    4. 12-18-2008 09:21 AM #5
      Thanks for the links. I was able to replace them without any instruction. But I will keep them for future reference.
    5. Angry Turtle Administrator nater's Avatar
      Apr 10th, 2000
      09-15-2009 10:43 AM #6
      l
    6. Angry Turtle Administrator nater's Avatar
      Apr 10th, 2000
      09-15-2009 10:47 AM #7
      Here is a thread I made in the testing forum where I'm able to put attachments into a post....
      http://forums.vwvortex.com/zerothread?id=4564892
      That thread will give you the factory repair manual for replacing your halogen bulbs whether you have the Hella or Valeo variety.
    7. 08-28-2010 01:55 PM #8
      where did you get the pdf or video
      Thanks in advance Ron
    8. 06-08-2011 10:40 PM #9
      Hi,
      Can you please send me the pdf for replacing the passat's headlight.
    9. 08-07-2011 01:08 AM #10
      Does anyone still have one of the pdfs with directions and pictures they can send me? Thank you.
    10. 01-05-2012 12:23 PM #11
      Does anyone have the PDFs? I need to do this TODAY or get pulled over.
      vwkaferfan
    11. Member
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      01-09-2012 10:43 AM #12
      here's the instructions:
      1. Open hood
      2. Locate headlight low beam cover (it's the biggest rubber cover) & pull it off.
      3. Reach in, grab the bulb connector, twist counter clockwise to remove (Hella & Late Valeo). Early Valeo just pulls out. Take note of the position of the tab that sticks out of the bulb.
      4. Separate Bulb from holder:
      4a. Hella: pry off the metal cover holding the bulb to the plastic connector
      4b. Late Valeo: pry bulb off of plastic connector
      5. Install is reverse of removal.
