VWVortex.com - 1995 Jetta 2.0 - oil leak between oil cooler - oil filter bracket?
    Results 1 to 3 of 3
    Thread: 1995 Jetta 2.0 - oil leak between oil cooler - oil filter bracket?
    1. Semi-n00b
      Dec 17th, 2008
      Aurora, Colorado
      1995 VW Jetta III GLS 2.0
      12-17-2008 04:04 PM #1
      I just developed a huge oil leak (up from an occasional drip) - which _looks_ like it originates between the oil cooler and the oil filter mount/bracket.
      For anyone who has had this issue, how common is it for the O-ring to disintegrate? The service manual says to use the AMV 188 100 02 sealing stuff (which is expensive). Any suitable alternative?
      I have not noticed any oil in the coolant, or vice versa. Yet.
      Thanks in advance for any help.
      Kirby
    2. 12-19-2008 09:37 AM #2
      http://www.autohausaz.com/sear...81402
      a new oring is 2 bucks. It's very easy to change. Grab a filter and any other maintenance parts while your at it and get free shipping.
    3. Semi-n00b
      Dec 17th, 2008
      Aurora, Colorado
      12-21-2008 10:13 PM #3
      I changed out the O-ring and everything was fine (no leaks).
      Those Jetta coolant hoses were the worst things to work with. The easy part was trimming part of a hose, but those pesky VW hose clamps were a pain. I changed several of the clamps to the regular screw-type hose clamps.
      Thanks for your reply. I'll keep your link on file!
      Kirby in Colorado
