VWVortex.com - got 2 codes what do they mean?
    Results 1 to 14 of 14
    Thread: got 2 codes what do they mean?
    1. Member Quattro A4's Avatar
      Oct 20th, 2007
      Clifton, NJ
      1999 Audi A4 1.8T Quattro
      12-28-2008 09:43 PM #1
      16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
      P0238 - 35-00 - -
      16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
      P0106 - 35-00 - -
      and the car is in limp mode
      Thanks!
      EDIT:Got these codes from my friends 01.5 audi a4 1.8t quattro AWM motor
      Modified by Quattro A4 at 8:50 PM 12-28-2008
    2. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      12-29-2008 12:56 AM #2
      Basically the MAP sensor is on the fritz.
      Either do to bad wiring or the sensor is dying.
      Check wiring to sensor; replace / swap sensor if need-be.
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    3. Member Quattro A4's Avatar
      Oct 20th, 2007
      Clifton, NJ
      12-29-2008 08:23 PM #3
      thanks man
    4. 01-09-2009 05:46 PM #4
      I have the same codes and a couple more.....
      P0238
      P0106
      P0300
      P0301
      P0302
      P0303
      Cleaned the MAP sensor and put new plugs in just to be safe. But it didn't fix the issue!
      It is intermitent, hesitation from the go always around 3000 rpm. MAP sensor makes sense since it feels like the motor is choking due to air or fuel shortage.
      Did the new MAP sensor adress your problems?
    5. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      01-09-2009 06:00 PM #5
      Quote, originally posted by sca »
      P0300, P0301, P0302, P0303
      Because you also have misfires on Cylinders 1, 2, and 3.
      Have you checked plugs? Ignition components?
      - Erik
    6. 01-09-2009 06:04 PM #6
      Put new plugs in and checked all wiring, no issues as far as I can tell.
      Problems are intermittent, I drive sometimes a couple days without issues and for what ever reasons it comes back again. Mostly when it is very cold outside.
    7. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      01-09-2009 06:09 PM #7
      What plugs? Brand, model, and gap spec please.
      Have you data-logged anything with a VAG-COM?
      - Erik
    8. 01-09-2009 06:14 PM #8
      Champion Irridiums, have to check what model # they are. Should be a stock replacement as per manufacturer recomendations.
      Haven't done any data logging, don't have the capabilities (tools) to do that on my VW since it is not OBD compatible.
      I still lean towards the MAF sensor but don't want to replace it based on a guess.
    9. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      01-09-2009 06:25 PM #9
      Why not a Bosch, or NGK?
      And why not copper (much cheaper!)?
      What scanner tool are you trying to use?
      Not with misfires; the MAF doesn't produce an electrical problem.
      You've got other things stemming to the issue.
      - Erik
    10. 01-09-2009 07:38 PM #10
      I have an Innova 3110 scan tool for my other vehicles, for the VW I have just a code reader and reset tool without any data logging capabilities.
      About the misfire I just wonder why it works for a couple days without issues and for unknown reason comes back after a while. Since it is on all cylinders it really can't be the coils since the chance is very slim that they all go at the same time.
      Especially since we make the coils at the company I used to work
    11. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      01-09-2009 07:41 PM #11
      You're not missing on all cylinder; just the first three. Cylinder #4 is unaffected.
      Plugs can be a culprit; so can ignition coil wiring, and even a fuel pump relay.
      - Erik
    12. 01-09-2009 09:29 PM #12
      Just cleaned the TB and the IAT sensor, looked pretty clean.
      Will see if it makes a difference....
    13. Member Dave928's Avatar
      Feb 11th, 2000
      Seattle - it's not Hell, but you can see it from here!
      88 928 S4, 13 Boxster S, 03 Silverado 2500HD
      01-10-2009 02:52 AM #13
      besides the fact that you're in the wrong forum, Champion plugs are crap. those are the worst plugs you can put in a VW...
      Porsches are not built to be something for everyone, but rather everything for someone.
    14. Member Quattro A4's Avatar
      Oct 20th, 2007
      Clifton, NJ
      01-14-2009 12:41 AM #14
      wow i havent checked this thread out since i last posted
      thanks for jacking my thread and i found out why i got those codes..when my friend was installing his intercooler he had to connect his intercooler sensor back in so he has to do a custom mount for it on the intercooler piping
