VWVortex.com - Loss of Cruise Cntrol after fitting MFSW
    Results 1 to 9 of 9
    Thread: Loss of Cruise Cntrol after fitting MFSW
    1. 01-05-2009 04:02 AM #1
      HI all, I know this has happended to a few people so I know I am not alone. My car (2005 MKV Golf GT 2.0TDI), came with the midline dash display and Cruise control as standard from the factory.
      I recently fitted a MFSW, and had to change the steering wheel module from my standard 1KO 953 549 F to the newer 1KO 953 549 AL. All went well and the MFSW works perfectly, and I managed to use the Wiki to reset the stering angle sensor etc and get all the dash lights off.
      Now as I say everythin works eecept the CCS. When I flick the little rocker switch (it's the CC that's integrated into the indicator stalk not a seperate stalk), the light comes on on the dash but the cruise dens't actually kick in.
      I've used VCDS to check the measuring blocks and when I press the main control rocker up or down, I get a reponse from the measuring blocks. The cruise worked perfectly before, so I'm pretty sure it's not a problem with the stalk ?
      The coding for the stering wheel module that I used was 0002042 (from the standard of 0000042).
      Can anyone shed any light on this please ?
      Regards
      Andrew
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      01-05-2009 05:38 AM #2
      Post a complete scan please, just the coding isn't really enough here...
    3. 01-05-2009 07:29 AM #3
      Theresias,
      I've just gone ot the car and done a fullscan, here it is:
      Chassis Type: 1K0
      Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 7D
      VIN: WVWZZZ1KZ5W169131 Mileage: 63630km/39537miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      37-Navigation -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door,Rear Left -- Status: OK 0000
      7D-Aux. Heat -- Status: OK 0000
      Address 01: Engine Labels: 03G-906-016-BKD.lbl
      Part No SW: 03G 906 016 FM HW: 028 101 190 3
      Component: R4 2,0L EDC G000SG 6179
      Revision: 12345678 Serial number: VWZ7Z0D1164509
      Coding: 0000072
      Shop #: WSC 01279 785 00200
      No fault code found.
      Readiness: 0 0 0 0 0
      Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
      Part No: 1K0 907 379 K
      Component: ESP FRONT MK60 0104
      Coding: 0023170
      Address 08: Auto HVAC Labels: 1K0-907-044.lbl
      Part No SW: 1K0 907 044 BN HW: 1K0 907 044 BN
      Component: ClimatronicPQ35 110 1010
      Revision: 00110021 Serial number: 00000000000000
      Shop #: WSC 00000 000 00000
      Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
      Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
      Component: Bordnetz-SG H34 0803
      Revision: 00H34000 Serial number: 00000001258640
      Coding: E5898F2600041800001400001400000000087F075C
      Part No: 1K2 955 119 B
      Component: Wischer VW350 012 0401
      Coding: 00065493
      Shop #: WSC 00000
      Part No: 1K0 955 559 M
      Component: RegenLichtSens 005 0605
      Coding: 00217125
      Shop #: WSC 00000
      Address 15: Airbags Labels: 1K0-909-605.lbl
      Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
      Component: 08 AIRBAG VW8 013 2100
      Revision: 02013000 Serial number: 0033HD02TGRO
      Coding: 0012344
      Shop #: WSC 01269 785 00200
      Address 16: Steering wheel Labels: 1K0-953-549.lbl
      Part No SW: 1K0 953 549 AL HW: 1K0 953 549 AL
      Component: J0527 036 0070
      Coding: 0002042
      Shop #: WSC 12345 123 12345
      Part No: XXXXXXXXXXX
      Component: E0221 007 0050
      Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
      Part No: 1K0 920 961 B
      Component: KOMBIINSTRUMENT VDD 0814
      Coding: 0003403
      Shop #: WSC 00400 210 50644
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Part No SW: 1K0 907 530 E HW: 1K0 907 951
      Component: Gateway H09 0110
      Revision: 09 Serial number: 2700104B300478
      Coding: 3D3F0B48070003
      No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
      Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
      Component: IMMO VDD 0814
      Address 37: Navigation Labels: 1T0-919-887.lbl
      Part No: 1T0 919 887 B
      Component: Navigation 0321
      Coding: 0000002
      Shop #: WSC 01324 785 00200
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
      Part No: 1K0 959 701 E
      Component: Tuersteuergeraet 09 0148
      Coding: 0000052
      Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
      Part No: 1K2 909 144 H
      Component: EPS_ZFLS Kl.3 1502
      Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
      Part No: 1K0 959 433 BL
      Component: 01 KSG 0301
      Coding: 99C802087F2D870748DFC69010
      Part No: 1K0 951 605 C
      Component: LIN BACKUP HORN H02 1301
      Part No: 1K0 907 719 B
      Component: Neigungssensor 004 0003
      Part No: 1K0 951 177
      Component: Innenraumueberw.004 0101
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
      Part No: 1K0 959 702 E
      Coding: 0000052
      Address 56: Radio Labels: 1T0-035-095.lbl
      Part No: 1T0 035 095
      Component: Radio 0321
      Coding: 0000422
      1 Fault Found:
      00857 - CD Changer Unit (R41)
      003 - Mechanical Failure
      Address 62: Door,Rear Left Labels: 1K0-959-703-GEN1.lbl
      Part No: 1K0 959 703 C
      Component: Tuersteuergeraet 06 0213
      Coding: 0000016
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
      Part No: 1K0 959 704 C
      Coding: 0000016
      Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
      Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
      Component: PTC-Element 0404
      Revision: 00800000 Serial number:
      End ---------------------------------------------------------------------
      I was messing with the measuring blocks and this was appended to the end of the log file. It certainly seems to do with the CCS system.
      Address 16: Steering wheel (1K0 953 549 AL)
      12:17:39 Group 004: Cruise-Cntrol-System
      OFF Main Switch
      Not Oper. CCS-Set
      Not Oper.
      N/A
    4. 01-05-2009 03:10 PM #4
      bump: anyone ?
      Feb 11th, 2004
      Magdeburg, Germany
      01-05-2009 04:49 PM #5
      How come you installed the 1K0-953-549-AL, your dealer should have supplied you with 1K0-953-549-BK if you ordered the module new from them?
      I sorta wonder because some of those older modules have recently gotten software updates because they acted weird in combination with cruise control...
      P.S.: Please do not bump threads, we are trying to answer all questions as soon as possible but do to time zones around the earth and working days as well as enough other requests this sometimes simply takes time.
    6. 01-06-2009 03:08 AM #6
      Sebastian
      Apologies for the bump, point taken, won't do it again.
      As to your reply, the mdule in question (AL) was one that a number of people on the forums used to retrofit the MFSW (although I guess in hindsight I should have asked them if they also had CC!).
      DO you think it's the new module that isn't compatible then. I noticed from the wiki the following:
      Steering Column Control Modules:
      There are 2 types of steering column control modules, each of them has 3 variants. The type is depending on the installed slip ring / clock spring, either use the part number of the currently installed module or the part number of the slip ring to determine the correct module for the vehicle in question. .
      Type I (Compatible to Slip Ring: 1K0-959-653, 1K0-959-653-A)
      Lowline
      Part Numbers: 1K0-953-549
      Supported Features: None
      Midline
      Part Numbers: 1K0-953-549-A
      Supported Features: Cruise Control, Trip Computer
      Highline
      Part Numbers: 1K0-953-549-B, 1K0-953-549-D, 1K0-953-549-AM
      Supported Features: Cruise Control, Trip Computer, Multi-Function Steering Wheel
      Type II (Compatible to Slip Ring: 1K0-959-653-C, 1K0-959-653-D)
      Lowline
      Part Numbers: 1K0-953-549-E, 1K0-953-549-AE
      Midline
      Part Numbers: 1K0-953-549-F, 1K0-953-549-AF, 1K0-953-549-AP, 1K0-953-549-AQ, 1K0-953-549-BC
      Highline
      Part Numbers: 1K0-953-549-G, 1K0-953-549-AG, 1K0-953-549-AK, 1K0-953-549-AL, 1K0-953-549-BD, 1K0-953-549-BK
      From this it seems that the "AL" module was designed for the highline cluster, and I have the midline unit in my car. Should I have gone for a "AF", "AP" etc. ?
      Do you know if there is any coding that can be done to get it working please ?
      Also on a final note, when I came to do the adaptation on the steering Angle Sensor (G85), I followed the Ross Tech Wiki, but have since realised that it stated:
      Sensor for Steering Angle (G85)
      Important Note: This applies only for Models with Conti/Teves MK70 ABS/ASR. For Conti/Teves MK60 ABS/ASR/ESP look at Vehicle specific specific Procedures in ABS System documentation
      I followed the procedure and it worked perfectly. However I have since realised that I do have the MK60 brakes and not the MK70. Even though the coding worked, I have no fault codes or warning lights, will I have screwed something up by using this technique ?
      Regards
      Andrew
      Modified by Norbreck21a at 12:09 AM 1-6-2009
    7. 01-07-2009 02:51 AM #7
      Sebastian,
      I have been told to try the coding 0002022 (not 42). However I have the on board computer (albeit the half height midline one). Any chance this would work ?
    8. 01-08-2009 10:59 AM #8
      Theresias
      I've been having a poke around my Scan and the label files for VCDS.
      I've been looking into the VCDS label file 03G-906-016-BKD.lbl which is for my 2.0TDI BKD engine.
      I noticed from near the bottom of the file there is a section on Coding II.
      In that bit it says:
      L00,Engine Control Unit (J248/J623) Coding-II
      L01,11463 = Cruise Control Activation
      L02,16167 = Cruise Control Deactivation
      Am I reading this right that the CCS system can be activated or de-activated through the engine control module ?
      As it's the engine I'm a little afraid of messing things up, which I why I thought I would speak to you first.
      Also, within the same measuring blocks further up the file is the following:
      006,0,Cruise Control System (CCS)
      006,1,Vehicle Speed,(actual)
      006,2,Pedal Monitoring,,See Label File
      ; xxxxxxx1 = Brake Light Switch operated
      ; xxxxxx1x = Brake Pedal Switch operated
      ; xxxxx1xx = Clutch Pedal Switch operated
      ; xxxx1xxx = CCS enabled
      ; xxx1xxxx = ACC enabled
      ; xx1xxxxx = Main Switch
      ; 00xxxxxx = ACC/CCS Mode not active
      ; 10xxxxxx = Status override
      ; 01xxxxxx = ACC/GRA active
      ; 11xxxxxx = ACC blocked
      006,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
      006,4,Switch Monitoring,,See Label File
      ; xxxxxxx? = Stuck ON
      ; xxxxxx?x = Pressed OFF
      ; xxxxx?xx = Decelerate (-)
      ; xxxx?xxx = Accelerate (+)
      ; xxx?xxxx = Set (SET)
      ; xx?xxxxx = Resume (RESET)
      ; ?xxxxxxx = Stuck ON (Hardware)
      Worth having a go or could I really screw things up if I mess ?
      Can I be cheeky and ask one further question (which may or may not be related).
      As my car has coming home / leaving home lights function, when I unlock the car, all the dash lights and the illumination for all the car switches and Nav all come on, except the ones on the steering wheel. The lights on the steering wheel only come on with the ignition irrespective of anything else. The buttons themselves also only work with the ignition on. Is this the correct behaviour ?
    9. 01-08-2016 05:31 PM #9
      I know this is an old thread but it was a top search result for my searching so figured a solution here would be beneficial in others not posting asking for results the problem is the swcm itself , is incompatible with your stalk easy identifier is its missing one pin which is the single stalk turn/cc combo if it has all * pins for the turn /cc setup it supports the dual stalk, I'm pretty sure 99.9% sure this cannot be coded to support the single stalk unfortunately so best bet is finding a swcm that supports your configuration lots of good info on support for single stalk here http://forums.vwvortex.com/showthread.php?3716659 wish I'd of known this before i went salvaging but hopefully this saves someone alot of time and money
      2001 TT GIAC TUNE apr fmic kit , modshack intake, modshack mofo w/4 bar fpr ,silicone plumbing, dv relocate, bfi dogbone, relentless 3" down pipe,endless mods SOLD
      2006 Jetta coil pack swap 2011 tdi rims lol
      audi s4 apr stage 2 +supporting mods SOLD
      2003 Audi S8 No mods SOLD
