Wtb r32 or 6cyl audi 02m clutch housing for the awd transmission
#36
for 85-88 Quantum, I believe. Numbers are as follows:
017 525 d53 e on actual housing, and 017 525 131b on cover
Make offer.
No reasonable offer will be turned down... it's a large piece of uselessness that has to be in my car (live in the barracks, can't store it in my room)
#37
#38
I bought a drivetrain swap for a 4cyl Mk2 and the guy had both setups. He gave me the R tranny instead of the TT tranny. I lost contact with the guy so I couldnt swap with him. Ive replaced the tranny with a TT tranny so I have this one up for grabs. He mentioned the R system had 50K miles (maybe I got those bits for the rest? The TT was 77k). Everythings tight and clean. No angle drive or starter. $1100 obo plus shipping. Located in Az. Its easier to get ahold of my via email onebludub@yahoo.com
#39
Still got the vr6 syncro bellhousing??
#40
Looking for parts or complety swap to convert my mk3 vr6 turbo to awd..
#41
Approximately 3600 miles.
Removed from a rear-ended R32.
Does NOT include the angle drive
$1600 shipped CONUS
or
$1500 picked up in Charlotte NC
#42
92 sedan 249,000 kms, DE headlights, H&R lowering springs, leather, sun roof, good engine and supercharger. Will sell whole car $1000 or complete syncro system for a few hundred more to cover the cost of removing. OBO
Located in Ottawa On Canada
#43
G60 syncro trans w/transfer case & rear end - $350 picked up
Audi tt/r32 center drive shaft - $100 picked up
front axles from either a audi tt or r32 not sure - $100 picked up for the pair
Im in area code 21703. PM on here for best results.
#44
Everything is OBO + shipping (i will ship anywhere) and from a 92 B3 Passat Syncro
Full syncro drivetrain: $1200 + shipping
Full exhaust system that fits 91-92 Passat Syncro and Rallye Golf:
Factory G60 syncro exhaust manifold $75
Factory G60 syncro downpipe: $100
Factory G60 syncro cat pipes: $150
Factory midpipe/dual suitcase mufflers. Front end of the pipe has the stock slip joint that starts after the 2 cat pipes Y together so it will slip right onto your stock dual cat pipe. $75
1 Set Passat Syncro Rear Beam Mounting Plates (4 hole) Redrill 1 hole and they work on mk2/mk3/corrado $75
1 Syncro Viscous Coupling: $150
2 Rear Diff Crossmembers (not the rubber mount/bracket) $100 each
2 Passat Syncro Gas Tanks $75 each
3 Passat Syncro Rear Springs $50 each
2 Non leaking Rear Passat Syncro Struts $50 each
ABS/EDL brake master unit: $75
ABS/EDL ECU: $50
#45
I'm selling my Haldex unit.
http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123
If the auction doesn't go you can IM me but I'm not on here much. Send me a message through eBay if you are interested.
#46
parts no longer for sale![]()
#47
Haldex is relisted on eBay. $799 buy it now.
Also selling:
SOLD
Brand spankin' new VR6 02C Syncro bellhousing. $550
http://columbus.craigslist.org/pts/1933856848.html
SOLD
Passat Syncro 02C transmission (with 4 cyl bellhousing) $250
http://columbus.craigslist.org/pts/1933862357.html
SOLD
Syncro rear differential from a Passat $250
http://columbus.craigslist.org/pts/1933868967.html
Still have this one!
Syncro differential from a Rallye - this one is in great shape $250
http://columbus.craigslist.org/pts/1933873404.html
#48
Anybody have the syncro rear beam? need everything but the diff, Mine was stolen.
#49
new MK2 rallye floor pan and used gas tank. offers
im email for pics
#51
anyone interested in a passat vr6 daily/beater for or partial trade toward syncro drivetrain setup?
will deliver
http://forums.vwvortex.com/showthrea...n-PA-cheap!!!!
#52
FOUND an O2C VR Bellhousing ...
Thanks DHill! got it fast and exactly as posted!
#53
I have a 02M transfer case, fits R32 and Audi TT. pm me for price.
#54
my plans for making my mk3 AWD is on the back burner for now.. so all the stuff i bought is up for grabs. The passat had 153xxxkms on it when i removed all the parts. Keep in mind.. it is a very easy swap into a mk2 or mk3. The rear subframe literally bolts up, you just need to make one cross brace for a bracket. I am located 1 hour from the Niagara Falls border
-Passat Syncro complete rear subframe assembly including, rear diff, VC, suspension,axles, brakes.. basically everything you need
-Driveshafts
-Syncro transmission
-axles
-G60 big brakes
$900 -SOLDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
I also have a Audi TT/ R32 Haldex rear end for those of you who want to make serious power with the awd.. $800 - SOLDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
and lastly i have the R32 4motion transfer box...$500 - THROW ME AN OFFER!!!!!
PM me if you are interested.
#55
#56
*** updated list 16March 2011***
Passat Syncro parts
Rear Syncro crossmember complete with diff, VC, axles, arms
Syncro 02C Transmission
Syncro Transfer case
02C 4 cyl syncro Belhousing (used)
02C syncro front Differential (used)
02C syncro front CV axle (used) LH & RH
Passat Syncro Propshaft complete (needs rebuild)
Syncro ABS computer
Syncro Master Cylinder (complete with pump & reservoir)
G60 front knuckles with brake caliper & bracket (same as Corrado)
G60 ECU & harness uncut with sensors & switches
Passat G60 intercooler & I/C piping
G60 throttlebody
G60 Valve cover
Golf Mk2 Syncro parts
Fuel tank - Used
Lots of other VW parts from Passat wagons & sedans, look in the B3 & B4 Classifieds.
All parts are located in the Montreal area.
Pick-up preferred, shipping OK for smaller stuff.
Shoot me an offer!
e-mail me at: syncroguru@gmail.com
I don't have the time to check here often so please e-mail me.
#58
I have a bunch of random parts for sale
http://columbus.craigslist.org/pts/2072993267.html
I have a brand new OEM never used floor pan for mk2/mk3 Golf Volkswagen Syncro cars. The floor is raised about 4" compared to the FWD car to accommodate the rear beam, differential, and gas tank.
I also have a mk2/Rallye Syncro gas tank and a Passat Syncro gas tank from Canada.
Also for sale is the the rear beam, swing arms, and differential from a Rallye. Parts were imported from Denmark a few years ago.
The cross member is used to hang the rear differential and stabilize the rear beam and swing arms.
The dual catalytic converters are each smaller than a single cat and are meant to provide more clearance for the center prop shaft and exhaust in a Syncro car.
$900 for everything or...
$300 for just the floor pan
$250 for the rear beam + swing arms SOLD
$250 for the rear differential
$40 for either gas tank - SOLD the Passat tank
$30 for the cross member SOLD
$50 for the dual catalytic converters
#59
9 camber bolts (spares, build your own) $ 6 each
Center propshaft weld in tabs. A touch rusty but useable $20
#60
I am parting my 4 Motion setup.
Perfect working order, come get it!
Available:
Rear with controller attached $700
02M 4 motion 6 speed CODE GQV $900
Angle Drive $600
or Package Price $2000
Will deliver for a fee
Buyer responsible for shipping![]()
#61
looking for the rear Country floor pan for my set up...
also looking for a fuel tank as well
if anyone has any of this stuff or where/who I can contact to get these please let me know!
Cheers Matt
#62
Selling my syncro. Everything works and it has brand new michelin pilot all season tires on it. Put a lot of hard work into this car and did things right. Selling it because I NEED a truck, not a car. Make me an offer. View details here http://forums.vwvortex.com/showthrea...cro-Conversion![]()
#63
I need the mounts on the body side that will mount the passat rear beam to a mk3 golf
lmk prices
#64
#65
WTB: VR6 Syncro BellHousing + 1 Galipper Carrier
Here is a photo of what the Carrier look like:
#66
Syncro Diff from a Rallye diff on eBay
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1170
#67
only the rear subframe bushings? or the rear control arm bushings also?I have a new never used powerFlex rear beam bushings asking $100
#68
Manifold to tailpipe all in awesome condition.
Located in Victoria BC Canada
Please PM if interested.
#69
i need everything for a swap to go into my rado if u have the floor pan and other supports ill take that also but im mainly looking for eveyrhting mechanical wise i would prefer the vr6 control arms and vr6 bellhousing bc its going into a vr6 rado amd im keeping it 5 lug email me or message me asafp i need this stuff soon ill drive to the canadian border as well for pickup.![]()
#70
I'm looking to buy a 20mm rear stabilizer arm (from Rallye and a few other cars, 357511409D). Please PM me if you've got one for sale, and are willing to ship to 97223. Thanks!
Ben
2011 Golf TDI
2009 Tiguan - wife's car
1985 Golf 4-door
*SOLD* 2006 GTI, 2001 Jetta, 1990 GTI, 1987 GLI
