Page 1 of 2 1 2 LastLast
Results 1 to 35 of 62
Thread: VF Engineering RSS32 Stage 1 Turbo Kit Pictures
  1. 01-15-2009 04:48 AM #1
    Hello Everyone,
    Just wanted to share some pictures with you guys
  2. Here is the top view with everything back together.
  3. Seconday Air Injection ports machined into manifold.
  4. Upper downpipe showing V-Band break for ease of service
  5. Hardline to wastegate for durability
  6. Oil supply hose showing heat sleeve and heat tube. Also showing bracket and cushion clamp
  7. This complete assembly installs as a single unit
  8. Turbo is tucked up nice and tight against the back of the block where the hot parts are less exposed to parts that should not see glowing metal.
  9. In order to keep the O2 sensor at a more reasonable temperature we came up with these heat-sinks to help extend there life
  10. Since the manifold is divided internally the dual O2's keep diagnostics similar to a factory car.
  11. Location of turbo and design of exhaust manifold allows the use of the original double walled stainless steel heat shield. This is an extremely effective way to keep heat away from whatever is on the other side of the shield.
  12. Stainless hardline mounted with cushion clamp from bottom of the water reservoir to firewall
  13. VF-E oil supply banjo.
  14. Compressor location
  15. Oil supply banjo installed with Goodridge PTFE hose
  16. Top right shows top of water hardlines with AN adapters installed
  17. CV heat shield mounted to protect boot from melting
  18. Upper and lower support bracket shown. This two piece design makes clutch or transmission jobs much easier.
  19. V-Band shown where upper and lower down-pipe join. Having this break point allows much more service freedom than one piece designs
  20. Lower downpipe mounted. Showing CV joint heat shield.
  21. Support brackets shown.
  22. Some detail of Water hardlines.
  23. MAF showing stainless honeycomb flow straightener.
  24. Oil supply bracket to compressor housing.
  25. 44mm Tial Wastegate showing VF made heat shield.
  26. We are now doing installs and will start to ship kits in the next few weeks.
    I know dyno, dyno, dyno, dyno We have been working very hard getting components production ready and will be making a separate post soon.
    Let me know what questions you guys have, or if anyone wants to meet for a test drive.
    Jeff Moss
    Modified by moss@vf-engineering at 2:12 AM 1-15-2009
    Edited to add more picts
  27. Compressor to throttle body pipe.
  28. Barely showing huge BPV (hooking up the second port reduced cracking pressure about 50% for better low load behavior)
  29. Plenum Block off for the leak prone hose that does nothing on the R32
  30. Support bracket break point shown
  31. Bottom corner of oil return hard line
  32. Showing break point and PTFE(teflon) hose
  33. No temperature sensitive rubber based hose in sight of manifold or turbine
  34. Modified by moss@vf-engineering at 2:31 PM 1-15-2009
    Edited to add updates and links to other related threads (1-16-2009)
    VF Engineering RSS32 "Beta" Turbo kit dyno.
    VF-Turbo Stg1 on RACE GAS - power unloads.(at VF-E)
    VF-Turbo Stg1 on a Mustang AWD - vids / plots / pics (at GIAC)
    VF R32T Let the installations begin!
    A big THANK YOU to VF Engineering for hosting today's SoCal R32 GTG!!!
    Modified by moss@vf-engineering at 2:08 PM 1-26-2009
  35. 01-15-2009 05:07 AM #2
    will be keeping an eye on this one
    hafizur
  36. Member VeeRsixx's Avatar
    Jan 5th, 2004
    Harrisburg PA
    '04 R32 Black Magic
    01-15-2009 05:11 AM #3
    That looks extremely well designed.
    edit: the MAF honeycomb flow straightener is very interesting. I wonder what temp. the heatshield above the CV joint boot, close to the hot side, sees.
    Modified by VeeRsixx at 5:27 AM 1-15-2009
    past dubs: (all black) - 1984 GTI - 1992 GTI 16v - 2001 GTI VR6
    VAD mobile scans available
  37. 01-15-2009 06:47 AM #4
    Jeff
    Any pictures of the stage 2 RSR set up showing air/water after cooler installed?
  38. Member rabbit07's Avatar
    Feb 22nd, 2007
    Frederick, MD
    CC
    01-15-2009 06:50 AM #5
    WOW that looks great. looks factory.
    2010 CC sport 6MT
    past: 2007 VW Rabbit, 1987 Porsche 944S, 1986 Porsche 911, 2008 VW R32, 2007 Audi A4
  39. Member Matty_Edge's Avatar
    Jul 28th, 2007
    Braintree/Boston MA
    2004 Black Magic Pearl R32 and 1993 Ruby Red 40th Anni. Corvette 'vert
    01-15-2009 07:06 AM #6
    I just jizzed in my pants
    http://www.youtube.com/watch?v=4pXfHLUlZf4
    Cant wait to get one in the spring
  40. Member .:1of1500:.'s Avatar
    Jun 18th, 2003
    Allentown, PA
    2 '95 Golfs, 1 '06 GTI
    01-15-2009 08:29 AM #7
    Isn't this test car for sale?
    1995 GTI VR6 turbo "Bought, not Built" - 1st Place, Mark III Wild, V.A.G. Fair 2010
    1995 Rat Golf CL
    2006 GTI 6MT PKGE 1
  41. 01-15-2009 08:38 AM #8
    Jeff... how close are those o2 sensors to the firewall??
    Maybe it is the camera angle, but it looks like they might hit the wall when the car is launched at the strip.. other than that, it looks great!!
    Quote Originally Posted by grammaticus
    A point of view can only ever be as precise as the language from which it has been constructed; we ought, therefore, to use the most precise language we can muster--nothing less--when making our case. Yes, it is a burden, but if you value your point of view, if you care at all that others understand you and what you believe, there is simply no way around the fact.
  42. 01-15-2009 08:45 AM #9
    Looks very well engineered!!
  43. Member r32autoxer's Avatar
    Aug 12th, 2005
    Alva, Fl
    87 Scirocco 16V, 04 RS R32T, 10 Jetta TDI Sportwagen
    01-15-2009 09:47 AM #10
    The CV boot WILL melt at the track, being that close to the turbo. Will put money on that...
    If I were you, I would seriously consider fabing a larger CV heat shield. A melted CV boot will cause a fire instantly that close to the turbo.
  44. 01-15-2009 10:00 AM #11
    Is this kit STOCK compression ratio? What boost does it run and ESTIMATED power?
  45. 01-15-2009 10:13 AM #12
    Quote, originally posted by Patryk R32 »
    the answer is NO. Boost, Jeff is going to have to answer that part
    Nice work Jeff I want to know about that CV BOOT as well
    Modified by michel at 10:14 AM 1-15-2009
    2004 DBP R32
    2004 ML500
    1994 JETTA III
  46. 01-15-2009 10:21 AM #13
    Quote, originally posted by revindevin »
    Jeff
    Working on this Friday.
    Already have charge pipes, IC, and IC brackets mostly made. Need to final fit and make sure patterns are made, mount relay, pump and heat exchanger. Finalize water reservoir and take picts for instructions and assembly people.
    Sounds like a lot! But will have some help from Nik and Mike.
  47. 01-15-2009 10:26 AM #14
    Quote, originally posted by rabbit07 »
    Thanks!
  48. 01-15-2009 10:27 AM #15
    Quote, originally posted by .:1of1500:. »
    Don't know, but you can send me an offer and I will forward to the client if you wish. moss@vf-engineering.com
  49. 01-15-2009 10:30 AM #16
    Quote, originally posted by PowerDubs »
    I can see how you would say that looking at the image above. They are actually a pretty good distance away. Will look and see if I have an image that is more clear.
  50. 01-15-2009 10:37 AM #17
    Quote, originally posted by r32autoxer »
    We have hundreds of dyno pulls which has very little actual wind movement in the area and have taken the kits off quite a few time to check for heat related issues and the CV boot and heat shield has looked fine. We will continue to keep an eye out for any problems of course.
  51. 01-15-2009 10:41 AM #18
    No. We use a stainless steel spacer, and OEM MLS (multi Layer steel) gaskets.
    10-11 psi
    About 375, cams seem to be worth 15-30 whp more and we are currently using NA style exhaust systems(what most people have).
  52. 01-15-2009 11:18 AM #19
    Looks good, seems like a lot of thought went into this kit
  53. Member tongboy's Avatar
    Dec 12th, 2001
    Portland, OR
    01 M5, 91 GLI TDI Swap, 98 M3 Sedan LS1/T56 Swap
    01-15-2009 11:38 AM #20
    I want
  54. Member j-dub's Avatar
    Oct 22nd, 2000
    Phoenix, AZ
    04 R32, 57 Type 1
    01-15-2009 11:54 AM #21
    Looks great!
    WOULD THE PERSON WHO TOOK THE STEP LADDER YESTERDAY PLEASE BRING IT BACK OR
    FURTHER STEPS WILL BE TAKEN
  55. Banned jettin123's Avatar
    Sep 10th, 2002
    01-15-2009 12:10 PM #22
    Looks like alot of thought and time went into the building of this kit. I like all the little added heat shielded pieces, but I have to agree, I would be surprised if that cv boot heat shield will be able to handle all the heat that will be coming from that turbo.
    Kit looks great though, now we want to see some numbers.
  56. 01-15-2009 12:23 PM #23
    Looks great Mossy
    I have signatures globally turned off!
  57. 01-15-2009 12:32 PM #24
    http://forums.vwvortex.com/zerothread?id=4193864
    .: FireVortex does NOT support vBulletin - no ETA :: FireVortex v2.0 Suggestions
    .: BuddyPress Plugins Powered By BP :: WP - BuddyPress Showcase
    .: JSW TDI
  58. 01-15-2009 01:27 PM #25
    are the stage 2 kits available as well? and if so what the hp of this kit? i have stage 4 vfe sc kit and am interested in swapping it out.
  59. 01-15-2009 01:29 PM #26
    Quote, originally posted by geoffreyhobika »
    PM sent!
    -Sean
  60. Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    01-15-2009 02:20 PM #27
    Quote, originally posted by VeeRsixx »
    i have a similar honeycomb straightener on my intake (you can buy the honeycomb from photography shops), interestingly enough, it made a bigger difference by putting it after the sensor, rather than before.
  61. Member Skela's Avatar
    Dec 25th, 2004
    Cypress, TX
    2004 R32TT, 2005 Phaeton, 2008 A6 S-Line
    01-15-2009 03:07 PM #28
    The kit looks great! It's obvious a lot of time, effort and pride went into making this turbo package.
    The devil is in the details and it looks like you've planned for all contingencies.
    I'm looking forward to seeing some of these on the road.
    Two thumbs way up for the pre turbo O2 sensors by the way. The previous design always bothered me.
    MkIV R32TT AWIC DSG
  62. 01-15-2009 03:40 PM #29
    Looking good so far guys!!
  63. Banned
    Oct 15th, 2005
    01-15-2009 03:54 PM #30
    This kit looks great, and very very well designed
  64. Member Det. John Kimble's Avatar
    May 20th, 2006
    Lynnwood, WA
    DBP R
    01-15-2009 03:56 PM #31
    I have been waiting to hear more information on this
    Kit looks great!
  65. Member R32R1's Avatar
    Jul 1st, 2008
    South County, RI
    Toilet R32 and a mk3 show car
    01-15-2009 04:44 PM #32
    Sean-
    How do-able is this kit going to be for install compared to the s/c stg 2? I mean for a guy like me w/ two VW techs helping out
    Professional Window Tinter- RI/MA
    Cilantro GTG Euromedian The Build Thread
    LOA Member #94
  66. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    01-15-2009 04:54 PM #33
    Kit looks great can't wait to see some numbers
    .:R Independent Amsoil Dealer HTTP://www.synthetic4you.com
    C2 Turbo
  67. 01-15-2009 05:32 PM #34
    Added more pictures.
  68. 01-15-2009 06:13 PM #35
    See you SoCal R32 folks on January 24th at the VF GTG!!!
    http://forums.vwvortex.com/zerothread?id=4200125
