Page 4 of 4 FirstFirst 1 2 3 4
Results 106 to 113 of 113
Thread: Anyone with a cold start misfire...
  1. Member dubbin415's Avatar
    Nov 1st, 2007
    San Francisco
    06-23-2010 11:58 AM #106
    I've just developed this problem on cylinder 1, and wanted to resurrect this. Any news of whether you guys found out if it's the injectors, lashes, lifters, or intake valves?
    Thanks guys
  2. Member dubbin415's Avatar
    Nov 1st, 2007
    San Francisco
    07-08-2010 10:12 PM #107
    resurrecting. any solutions?
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    07-08-2010 10:34 PM #108
    clean your intake valves.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  4. Member 719MKV.t's Avatar
    Aug 4th, 2009
    Honolulu, HI
    Turbo MKI Rabbit
    01-22-2011 08:50 PM #109
    Sooo i just developed this problem, i am revo stage II+, 3" exhaust, cai, water meth with 2 injectors, kmd fuel pump upgrade and the sort... i don't know what cylinder but i think its my w/m pooling in the intercooler piping and i think that's it but im not sure...any insight?
    Sep 23rd, 2009
    Dallas, TX
    2007 Audi A3 2.0T
    01-22-2011 09:10 PM #110
    Quote Originally Posted by 719MKV.t View Post
    If you think it's your meth, then stop spraying and put your tuning back to stock (not sure if you can do that with revo) and see if it goes away.
  6. 07-31-2012 07:58 AM #111
    Looking through this, it kind of seems like no one really got a resolution to this problem directly. It seems like some things partially fixed it but no full resolution.
    Im keen to see a resolution for this as I am have cold start misfires until operating temp is reached. The misfires are from idle to 2500rpm and are only on cylinder 3.
    Injector has been replaced, coil packs, new pcv, purge valve, spark plugs, sea foam, inlet gasket. To me it has to be electronic because it stops misfiring at the exact same relative operating temp and rev range.
    Must be a resolution out there somewhere!
  7. Member lionel2341's Avatar
    Jan 2nd, 2005
    2006 Jetta GLI--1988 German Jetta GT--1966 Shelby Mustang
    08-03-2012 11:05 AM #112
    I think it's the ECM program and fuel enrichment during cold starts, my cyl #4 consistently misses untill temp is normal then the car runs perfect, and yes I've changed everything and cleaned the valves, and nothing changed. this morning all hell broke lose and cyl 234 all missed and gave me code 0456 small evap leak. So I'm starting to lean to a program problem with cold start enrichment in open loop at start.
  8. 08-07-2012 07:56 AM #113
    that sounds logical to me lionel. It doesnt really make sense for it to be a mechanical issue as it always goes away at the exact same operating temperature. Is there a resolution to this, or is it back to the dealer?
