VWVortex.com - Mk2 Gti Restoration/Customization Project
    Page 11 of 11 FirstFirst ... 7891011
    Results 251 to 275 of 275
    Thread: Mk2 Gti Restoration/Customization Project
    1. Member 86GTikid's Avatar
      Dec 21st, 2007
      West CT
      86 Gti R.I.P.,87 Golf coupe R.I.P, 88 GLi R.I.P., 89 Jetta Coupe VR, 94 Golf Sport, 95 Passat Vr etc
      12-28-2010 11:07 PM #251
      Playing catch-up with my favorite thread, just wondering how things are going before the new year hits
      Apr 1st, 2008
      BTV
      '87 GTI, '92 GOLF, '11 Jetta, '13 TUNDRA
      12-30-2010 04:22 PM #252
      Not much to update as of right now..... fortunately, I am extremely busy with work and other people's projects. Unfortunately, the gti has not changed from my last post...
      Thanks for the bump!
    3. Member Milan999's Avatar
      Feb 1st, 2010
      whitehouse station, NJ, 08889
      always changing
      01-05-2011 01:48 AM #253
      subscribed! i wish i knew how to do ANY of this stuff.. your project is what i dream of doing one day good luck and keep the updates coming.. can't wait for it to be done
    4. Member twinrado's Avatar
      Jun 23rd, 2005
      Roseville (St.Paul)
      Corrado, Audi A6, Passat
      01-05-2011 04:37 AM #254
      Quote Originally Posted by vdubbervt View Post
      Thanks for the bumps, guys, I appreciate the feedback!
      To answer your question about the molding holes- they are all filled with weld, it's pretty easy to do by using a copper back plate on the inside of the body. With the copper plate in place behind the hole, weld the hole and remove the copper plate (the weld will not stick to the copper which makes it the ideal material). Then skim with filler and treat the inside with a rust preventative....
      Here's a copper spoon that Eastwood sells for reference (I made my own)...
      What Ga should the coppper be because i am thinking of making my own tools when sealing my rear badge holes on my corrado. By the way I must say your a metal king and I cant wait to see your project done. Keep us posted and good luck.
      Apr 1st, 2008
      BTV
      01-05-2011 05:33 PM #255
      The gauge really depends on what you are welding, but the spoon/heat sink I made using .080" (roughly 14ga.) copper. That thickness is more than adequate for plugging up the molding and antenna holes and appears to be a similar thickness to what is pictured above...
    6. Member twinrado's Avatar
      Jun 23rd, 2005
      Roseville (St.Paul)
      01-05-2011 08:01 PM #256
      My question to you is how come you didnt angle that intake inlet section on the inner fender wall to allow the air to nicely flow into your intake box? and also if you do plan on making you own exhaust system let me know. Also continue with the nice work cheers
    7. n00b CuPEditionmkv's Avatar
      Dec 29th, 2010
      yorktown , new york
      TDI 2010 CUP EDITION
      01-06-2011 12:10 AM #257
      this is gonna be one sick v dub ..... keep up the sickk work
      Apr 1st, 2008
      BTV
      01-07-2011 05:33 PM #258
      Quote Originally Posted by twinrado View Post
      ~The intake shroud is angled (think pyramid with irregular hips) but it's hard to tell from this picture....
      ~I plan on working with the stainless techtonics exhaust I have now, but there will be no visible tail pipe. I'm going to delete the notch for the factory tail pipe location and weld on a "turn down" so you won't see an exhaust (hopefully).....
      That's the plan, all I need is some time to do it which has been hard to come by these days....I barely have time to change the oil in my other two vehicles!!!!
    9. 01-12-2011 11:52 PM #259
      Scrolled the entire thread. Looks great, man! I would kill to have that space to work out of. Can't wait for more updates. Bump!
    10. Member illi's Avatar
      Mar 25th, 2001
      92 GTI, 10 GTI, 04 X5, 01 Yukon XL
      02-23-2011 10:54 PM #260
      TTT! get any more work done? I'm also diving into body work for the first time and this thread is great.
    11. Member MyCarIsRed's Avatar
      Aug 9th, 2004
      Penrose, CO
      90 jetta coupe vr, 99 passat wagon
      02-25-2011 12:30 PM #261
      nice to see this back on track. diggin the rails man.
    12. Member Fusor2's Avatar
      Mar 15th, 2009
      New Philthy OHIO,
      '84 GTI '83 pickup '02 Focus '08 STI
      02-27-2011 02:50 PM #262
      Must not fap..............erg
    13. Member 86GTikid's Avatar
      Dec 21st, 2007
      West CT
      03-24-2011 08:08 AM #263
      bump for a busy guy
    14. Member mk2gtiwhite's Avatar
      Feb 22nd, 2010
      kingston new york
      04-09-2011 05:22 PM #264
      how much to make rear arces ???????
      love the work keep it up
    15. Member arnoldspurga's Avatar
      Oct 3rd, 2010
      Vilnius, Lithuania
      1989 1.3 VW Golf 2(GONE), 1999 1.6 VW Passat B5, 2009 2.0 TFSI Vw Tiguan
      05-28-2011 05:42 AM #265
      updates?
      Quote Originally Posted by sgvwjettagli View Post
      whta is the URL to this website? help me out
      I̶'̶m̶ ̶1̶3̶ ̶E̶D̶I̶T̶:̶ ̶1̶7̶ ̶n̶o̶w̶.̶ ̶S̶t̶i̶l̶l̶ ̶a̶c̶t̶ ̶l̶i̶k̶e̶ ̶I̶'̶m̶ ̶5̶.̶ Finally legally driving.
    16. Member cubanvr6jetta's Avatar
      Oct 22nd, 2009
      North bergen NJ 07047
      to many to list here now 2006 gli
      06-05-2011 12:44 PM #266
      how much for a set of frame rails for a mk3 jetta
    17. Semi-n00b uncle benzo's Avatar
      Jul 28th, 2008
      NOR-CAL
      09 rabbit(wrecked),90 corrado g60
      06-23-2011 08:20 AM #267
      i quit blinkin, that's when they get ya!
    18. Member 86GTikid's Avatar
      Dec 21st, 2007
      West CT
      04-02-2012 08:24 PM #268
      Back from the dead, and hoping for more updates
    19. 04-12-2012 10:32 PM #269
      Bump
    20. Junior Member
      Dec 26th, 2013
      Montreal
      MK4 TDI Jetta, Mk3 golf "CL"
      07-28-2016 11:14 PM #270
      Hate to be that guy but... 4 year later bump? What ended up happening with this car?
    21. Member
      Apr 1st, 2008
      BTV
      08-19-2016 12:24 PM #271
      Quote Originally Posted by VWDub-eh View Post
      Thanks for the interest... I still have the car, I've been chipping away at it here and there.
      The motor is all cleaned up and assembled. I widened the rear arches 20mm. Deleted the exhaust opening in the rear apron and extended the body line all the way accross. The interior has also been redone.
      But mostly, been busy with other things that are of higher priority, including tinkering with and maintaning my four door AEB swap.
      I'll check back in after another four years with an update ;P
    22. 08-28-2016 09:29 AM #272
      did kip do that?
      Hit me up for Air Lift, Accuair, and Rotiform products! corradosean@att.net
    23. Member
      Apr 1st, 2008
      BTV
      08-28-2016 01:07 PM #273
      Quote Originally Posted by corrado_sean2 View Post
      did kip do that?
      Yes, sir
    24. Member vw fiend's Avatar
      May 9th, 2002
      Carmel, Indiana
      1966 Beetle, 1986 Cabrio, 2016 GTi, 2011 JSW
      08-28-2016 10:20 PM #274
      Happy to see this pop back up in my subscribed threads. What is the story with the Recaro seats?
    25. Member
      Apr 1st, 2008
      BTV
      08-29-2016 01:04 PM #275
      Quote Originally Posted by vw fiend View Post
      They're Trophy's with new bolsters and reupholstered with grey tweed and black vinyl
