Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 141 to 175 of 269
Thread: Mk2 Gti Restoration/Customization Project
    Apr 1st, 2008
    BTV
    '87 GTI, '92 GOLF, '11 Jetta, '06 TUNDRA
    05-24-2009 05:20 PM #141
    Not much to report- been super busy with work
    Helped out a friend of mine with his vr-swap (still in the works). It's a Jetta diesel coupe and should make for a very nice daily!
    Sandblasted my lower rad. support, patched one of the mounting holes and sprayed it with engine enamel.
    Welded in some studs for the hood-release mechanism a la vwjodi
    ...then I made a panel to cover all unnecessary holes
    That's about it for now, wish I had more time to work on this project, but duty calls
  2. Member 1broknrado's Avatar
    Jul 6th, 2005
    Wilmington NC/Stratford CT
    24v Corrado
    05-27-2009 05:47 PM #142
    either way ur doing great work on everything you touch!
  3. Member MyCarIsRed's Avatar
    Aug 9th, 2004
    Penrose, CO
    90 jetta coupe vr, 99 passat wagon
    05-27-2009 06:56 PM #143
    that rad support is going to be fun to sand haha
    i shaved mine a while back and the sanding part nearly made me kill myself. it's got so many tiny areas that fillers like to sit in and make air pockets.
    here is mine:
  4. Member
    Apr 1st, 2008
    BTV
    05-28-2009 09:27 AM #144
    Quote, originally posted by MyCarIsRed »
    ...looks good, though!
    With such little time to work on this car, I keep finding ways to make a lot more work for myself
  5. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-28-2009 09:28 AM #145
    check out my thread, got the engine bay painted a few days ago..working on entire car right now... just not sure what im going to do with the window seals because i cant afford to replace them all
  6. Member MyCarIsRed's Avatar
    Aug 9th, 2004
    Penrose, CO
    05-28-2009 11:40 AM #146
    Quote, originally posted by vdubbervt »
    don't i know it man. i have the time, but no steady income so i'm fighting the other demons trying to not spend more money than i already have into it.
    Apr 1st, 2008
    BTV
    05-28-2009 11:45 AM #147
    what do you think would help to eliminate the "air pockets", use a lighter filler like metal glaze?
  8. Member MyCarIsRed's Avatar
    Aug 9th, 2004
    Penrose, CO
    05-28-2009 11:47 AM #148
    i ended up using duraglass first over the welds, then a light filler like rage gold. seemed to work okay. i don't have a latch though, so i don't know how that area will flex or anything.
  9. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-28-2009 11:54 AM #149
    perfect. i used only the rage if i needed to build a hole, but for pinholes and MINOR work i used Evercoat Icing. works/sands/spreads amazing.
  10. Member MyCarIsRed's Avatar
    Aug 9th, 2004
    Penrose, CO
    05-28-2009 04:58 PM #150
    Quote, originally posted by 1broknrado »
    i never really got into icing. i know it's supposed to work really well, but i really have never had any issues with pinholes in rage. i usually shoot everything with a few coats of highbuild primer before i wetsand it all down anyway, so even if i did get pinholes it would be pretty easy to sand them out. not arguing with your choice by any means, i've just never needed it. i've considered giving it a shot... maybe one of these days. to cut down on sanding time, with most of my fillers, i only let them set until they're just hard enough to not clog my sandpapers. that way, even the heaviest of fillers is still pretty easily sandable with a 180 grit.
  11. Member
    Apr 2nd, 2008
    Bend, OR
    2000 Golf 4d, 2013 Golf TDI w/tech, Past cars: 2007 GLI, 2006 2.0T
    06-01-2009 12:54 PM #151
    Wow man, this is what it's all about right here-- the true meaning of a project car. Not something you buy as a piece of crap and just drop off at someones shop and come back a couple months later and it's done. It looks like a lot of work, but I can't imagine how fun it would be. I am getting ready to take some classes at my college that get in to welding, and I was wondering if most of the skills you are using are pretty basic or advanced. I know a lot of it simply has to do with the ability to envision something first, but like the seatbelt delete patches, would something like that be easy for a beginner?
    Apr 1st, 2008
    BTV
    06-01-2009 01:11 PM #152
    Quote, originally posted by zRockstar »
    Hey, thanks for the support- this is a lot of fun for me, but it's hard for me to spend time on this build as I don't have much money or time to devote to it at the moment.....
    Welding classes are great- I would suggest it to anybody, even if you think you are an expert, you will always learn something new from working with other people.
    Some of these little details don't require a lot of skill, but experience and the right tools always helps. I find taking the time to make something fit right before welding makes a HUGE difference, even if you have to make it two or three times. That way you can save time, energy and resources when applying filler.
    The seat belt patches, for example, I spent most of my time making the pattern. Once I was happy with the pattern, I transferred that to metal, cut it out and then had to figure out the exact radius to make my bend. I actually made two pieces before getting the right radius on my bend just right- I "bump bent" the piece in three stages on my bending brake to get the piece where I wanted it. Then did some slight trimming to get the patch to sit just below the plane of the existing area- that way I knew I wasn't going to be too high, but not too low so that I would have to add a lot of filler...Sounds like a lot of work for a little piece, but that is my process- make it right the first time!!!!!
  13. Member vwmk2vr6s's Avatar
    Aug 19th, 2007
    Colorado
    Sold them all.
    06-03-2009 10:52 PM #153
    Car is looking good! You have alot of great ideas. Shaved rad supports are a pain but worth the work. here is my shaved rallye rad. support.
    www.pusherbmx.com The only rider owned BMX shop in Colorado. Check us out.
  14. Member
    Apr 1st, 2008
    BTV
    06-04-2009 09:19 AM #154
    [QUOTE=vwmk2vr6s]Car is looking good! You have alot of great ideas. Shaved rad supports are a pain but worth the work. here is my shaved rallye rad. support.
    QUOTE]
    Looks great! Well done, sir!!!
    I can't wait for my car to be at that stage, gonna be a while, though
  15. Member
    Oct 15th, 2008
    NYC
    Underground
    06-11-2009 01:37 AM #155
    Awesome work man! I actually think I was at your shop sometime last fall (I think). I remember you showing us this build. You had the rear hatch lip done and maybe a corrado dash installed; something like that...
    I had bought a pair of crosshairs off of you. My cuz and I came; I'm Jake the big guy and Matt was the tall/skinny guy. Oh ya, and there was a sick light grey/baby blue corrado 1.8t there w/ a shaved bay that someone had been working on for a show.
    Modified by No post counting at 1:39 AM 6-11-2009
  16. Member
    Apr 1st, 2008
    BTV
    06-11-2009 08:05 AM #156
    Quote, originally posted by No post counting »
    Yup, I remember, that was right before the Johnson Show. How'd the lights work out?
    Thanks for the bump
  17. Member
    Apr 1st, 2008
    BTV
    06-17-2009 05:36 PM #157
    I had an hour to work on my radiator support today...
    Filled some more holes and decided to do some lead filling around the hood-catch area to minimize the use of bondo...
    Lead blobbage...
    then a quick sand...
    Had a nice dent to contend with...
    ...hammered most of it out and filled the hole next to it and laid down some more lead
    That's about it for today, I've got the first light layer of bondo setting up right now, I'll get to sanding that tomorrow morning if time allows...Should be pulling another Passat vr6 motor on Friday- stay tuned for more, I'm dying to get back into this build!!!!
  18. Member
    Oct 15th, 2008
    NYC
    Underground
    06-17-2009 11:10 PM #158
    Thanks for the bump
    Ya that's right. The lights worked great right up until I lost a rear wheel on the highway in NJ. I ended up leaving the car in NY and selling it to a local. But the lights looked great
    I'm now working on a s2 scirocco...
  19. Member
    Apr 1st, 2008
    BTV
    06-18-2009 10:31 AM #159
    Are you still in VT? What are you doing to the scirroco?
  20. Member ur faster's Avatar
    Jul 20th, 2005
    Harrisonburg,VA
    1989 VW Jetta GLI, 2004 Audi A6 s-line 2.7t, 93 Corrado VR
    06-19-2009 10:08 AM #160
    Nice Work!
  21. Member
    Oct 15th, 2008
    NYC
    Underground
    06-19-2009 12:01 PM #161
    Yep still in VT. I'm in Morrisville... And right now I'm just driving the rocco but this fall/winter it's going under the knife. It needs either 2 patch panels or 2 entire rear quarter panels welded in; then some misc shaving and a respray.
    It has a built 2.0 16v w/ a 9a trans and lsd.
  22. Member
    Apr 1st, 2008
    BTV
    06-19-2009 12:28 PM #162
    Quote, originally posted by ur faster »
    Nice Work!
    Thanks
    Very cool, you should swing by next time you leave the sticks
  23. Member zcxerxes's Avatar
    Nov 13th, 2005
    64 notchback, 87 scirocco 16v, 93 corrado
    06-21-2009 10:47 PM #163
    nice work. i wish i'd have found this a week ago so i could have had you make me flairs instead of cutting some off another car and welding them in.
    sometimes you have to do $hit
    aircooled abomination
  24. Member
    Apr 1st, 2008
    BTV
    06-22-2009 08:54 AM #164
    Thanks- I responded to your IM
  25. Member
    Oct 15th, 2008
    NYC
    Underground
    06-22-2009 09:59 AM #165
    Haha will do
  26. Member
    Apr 1st, 2008
    BTV
    06-29-2009 06:22 PM #166
    Another quick update on the radiator support....spent some time yesterday and today throwing some filler at it and some sanding- it went pretty easy although there are a lot of little dimples and voids due to the factory spot welding and such, but overall, not too bad.
    Here it is in all its rose primer glory!
    It feels good to check this off the ever-growing To Do List, I just hope it looks good after paint, and most importantly, I hope the solder does the trick of preventing any cracks down the road...
    I'll try to get more done in the near future and post more pics....
  27. Member
    Apr 1st, 2008
    BTV
    08-03-2009 07:27 PM #167
    So, been busy with work so not much happening with the gti resto, however I have been acquiring some more parts lately- I got some half-smoked tails with bulb trays, a B&M short shifter (already installed in the shifter box), clean door cards, and other misc. items all for $200!
    But......the big score as of late is my new daily ! I've been looking for a clean 4 door golf for the last two months and finally found one in Hartford, CT. It's a '92 Golf, one owner, with 61,000 original miles, no rust on the undercarriage whatsoever and the rest of the body is in descent shape.
    Here are some pics of my new daily....
    Only plans for this thing is clean it up a little- needs a good wax and eventually a respray, but that'll have to wait. Going to put some passat or mk3 springs on her to jack it up a little, and maybe replace the sweet factory stereo
  28. Member koko5869's Avatar
    Feb 15th, 2006
    Lehigh Valley, PA 18042
    04 BDF O2M / C5 A6 3.0Q
    08-03-2009 08:47 PM #168
    funny as it seems, thats my dream car...but only slightly altered
    just cant find any of them around these parts worth buying.
  29. Member
    Apr 1st, 2008
    BTV
    08-04-2009 08:24 AM #169
    Quote, originally posted by koko5869 »
    I looked for months all over the Northeast, unless you want a two door or a Jetta, it's gonna be hard to find a clean 4-door. But you are in PA, there's gotta be a clean 4-door around your area......don't look on Vortex, it's hard to find a good deal on here 'cause most people know what they are worth, look on Craig's List, maybe you'll find an old lady that needs to get rid of her car for next to nothing?
    Good Luck!!!!
  30. Member padubbin421's Avatar
    Apr 10th, 2009
    nepa coal cracker
    91 vrs/c jetta,s10,lt250r
    08-08-2009 08:58 PM #170
    sick stuff
    Bam
  31. Member DUBsportGLX's Avatar
    Aug 12th, 2003
    Lancaster Pa
    2001 Audi A4 Quattro 1.8T
    08-09-2009 01:17 AM #171
    cool project. I did an MK2 GTI a few years back if you need anything let me know.
  32. 08-09-2009 04:17 PM #172
    Quote, originally posted by vwmk2vr6s »
    why would one shave his rad support in the first place
  33. Member 65dunebuggy's Avatar
    Jan 22nd, 2008
    Iowa
    12 CW Golf R, FS 06 GTI
    08-10-2009 12:55 AM #173
    love the car as well as the garage art I am a HUGE Simpsons fan awesome work
  34. Member
    Apr 1st, 2008
    BTV
    08-10-2009 09:00 AM #174
    Thanks for the bumps, folks!
    I hope to have some time to get back to the build soon, but work is taking all of my time and I gotta make some money while I can.....
    I did, however put my old blaupunkt stereo in my new daily and also threw in my recaro trophies for added comfort- four door 8v, lovin' it!!!!
  35. 08-10-2009 11:21 PM #175
    you must really love that car. Oneheluva project you've taken on here. stay on it!!
