Page 8 of 8 FirstFirst ... 4 5 6 7 8
Results 246 to 269 of 269
Thread: Mk2 Gti Restoration/Customization Project
    Apr 1st, 2008
    BTV
    '87 GTI, '92 GOLF, '11 Jetta, '06 TUNDRA
    12-02-2010 05:44 PM #246
    Thanks for the bumps, guys, I appreciate the feedback!
    To answer your question about the molding holes- they are all filled with weld, it's pretty easy to do by using a copper back plate on the inside of the body. With the copper plate in place behind the hole, weld the hole and remove the copper plate (the weld will not stick to the copper which makes it the ideal material). Then skim with filler and treat the inside with a rust preventative....
    Here's a copper spoon that Eastwood sells for reference (I made my own)...
    Apr 1st, 2008
    BTV
    12-02-2010 06:15 PM #247
    Sorry for the lack of updates, but I've been super busy with work and I'm kinda burnt out on the "Tex" at the moment... However, since you all have been so kind, here's a quickie update..... the argyle frame rails and intake shroud are in- I have a little more filler work and sanding to do, but it's pretty close....
    I have been working on other details of the car and sorting out what I'm going to do with the rear arches.....
    Thanks for watchin'
  3. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    04 GTI 24vT, 2013 FR-S
    12-02-2010 06:20 PM #248
    those frame rails do it for me. very nice job
  4. Member Fusor2's Avatar
    Mar 15th, 2009
    New Philthy OHIO,
    '84 GTI '81 diesel 2door '02 Focus
    12-05-2010 02:32 PM #249
    seeing those framerails ...........i just came buckets
  5. Member jity86's Avatar
    Sep 5th, 2002
    Vancouver, WA
    86 GTI 1.8t syncro project , 84 wabbit GTI
    12-05-2010 10:22 PM #250
    harbor frieght sells a copper spoon that works great, cost like $6. I like the engine bay, very original.
    CG Autowerks
    3000 NE MINNEHAHA ST. SUITE B
    vancouver, WA 98663
    360-859-3480
  6. Member 86GTikid's Avatar
    Dec 21st, 2007
    West CT
    86 Gti R.I.P.,87 Golf coupe R.I.P, 88 GLi R.I.P., 89 Jetta Coupe VR, 94 Golf coupe
    12-28-2010 11:07 PM #251
    Playing catch-up with my favorite thread, just wondering how things are going before the new year hits
    Apr 1st, 2008
    BTV
    12-30-2010 04:22 PM #252
    Not much to update as of right now..... fortunately, I am extremely busy with work and other people's projects. Unfortunately, the gti has not changed from my last post...
    Thanks for the bump!
  8. Member Milan999's Avatar
    Feb 1st, 2010
    whitehouse station, NJ, 08889
    always changing
    01-05-2011 01:48 AM #253
    subscribed! i wish i knew how to do ANY of this stuff.. your project is what i dream of doing one day good luck and keep the updates coming.. can't wait for it to be done
  9. Member twinrado's Avatar
    Jun 23rd, 2005
    Roseville (St.Paul)
    Corrado, Audi A6, Passat
    01-05-2011 04:37 AM #254
    Quote Originally Posted by vdubbervt View Post
    What Ga should the coppper be because i am thinking of making my own tools when sealing my rear badge holes on my corrado. By the way I must say your a metal king and I cant wait to see your project done. Keep us posted and good luck.
  10. Member
    Apr 1st, 2008
    BTV
    01-05-2011 05:33 PM #255
    The gauge really depends on what you are welding, but the spoon/heat sink I made using .080" (roughly 14ga.) copper. That thickness is more than adequate for plugging up the molding and antenna holes and appears to be a similar thickness to what is pictured above...
  11. Member twinrado's Avatar
    Jun 23rd, 2005
    Roseville (St.Paul)
    01-05-2011 08:01 PM #256
    My question to you is how come you didnt angle that intake inlet section on the inner fender wall to allow the air to nicely flow into your intake box? and also if you do plan on making you own exhaust system let me know. Also continue with the nice work cheers
  12. n00b CuPEditionmkv's Avatar
    Dec 29th, 2010
    yorktown , new york
    TDI 2010 CUP EDITION
    01-06-2011 12:10 AM #257
    this is gonna be one sick v dub ..... keep up the sickk work
  13. Member
    Apr 1st, 2008
    BTV
    01-07-2011 05:33 PM #258
    Quote Originally Posted by twinrado View Post
    ~The intake shroud is angled (think pyramid with irregular hips) but it's hard to tell from this picture....
    ~I plan on working with the stainless techtonics exhaust I have now, but there will be no visible tail pipe. I'm going to delete the notch for the factory tail pipe location and weld on a "turn down" so you won't see an exhaust (hopefully).....
    That's the plan, all I need is some time to do it which has been hard to come by these days....I barely have time to change the oil in my other two vehicles!!!!
  14. 01-12-2011 11:52 PM #259
    Scrolled the entire thread. Looks great, man! I would kill to have that space to work out of. Can't wait for more updates. Bump!
  15. 02-23-2011 10:54 PM #260
    TTT! get any more work done? I'm also diving into body work for the first time and this thread is great.
  16. Member MyCarIsRed's Avatar
    Aug 9th, 2004
    Penrose, CO
    90 jetta coupe vr, 99 passat wagon
    02-25-2011 12:30 PM #261
    nice to see this back on track. diggin the rails man.
  17. Member Fusor2's Avatar
    Mar 15th, 2009
    New Philthy OHIO,
    02-27-2011 02:50 PM #262
    Must not fap..............erg
  18. Member 86GTikid's Avatar
    Dec 21st, 2007
    West CT
    03-24-2011 08:08 AM #263
    bump for a busy guy
  19. Member mk2gtiwhite's Avatar
    Feb 22nd, 2010
    kingston new york
    04-09-2011 05:22 PM #264
    how much to make rear arces ???????
    love the work keep it up
  20. Member arnoldspurga's Avatar
    Oct 3rd, 2010
    Vilnius, Lithuania
    1989 1.3 VW Golf 2, 1999 1.6 VW Passat B5, 2009 2.0 TFSI Vw Tiguan
    05-28-2011 05:42 AM #265
    updates?
    Quote Originally Posted by sgvwjettagli View Post
    whta is the URL to this website? help me out
    Quote Originally Posted by VegasJetta View Post
    Nitrous is like a smokin hot chick with AIDS and Herpes. You REALLY wanna hit it, but are afraid of the consequences...
    I'm 13
  21. Member cubanvr6jetta's Avatar
    Oct 22nd, 2009
    North bergen NJ 07047
    00 new beetle gl
    06-05-2011 12:44 PM #266
    how much for a set of frame rails for a mk3 jetta
  22. Semi-n00b uncle benzo's Avatar
    Jul 28th, 2008
    NOR-CAL
    09 rabbit(wrecked),90 corrado g60
    06-23-2011 08:20 AM #267
    i quit blinkin, that's when they get ya!
  23. Member 86GTikid's Avatar
    Dec 21st, 2007
    West CT
    04-02-2012 08:24 PM #268
    Back from the dead, and hoping for more updates
  24. 04-12-2012 10:32 PM #269
    Bump
