Results 36 to 70 of 80
Thread: AIRBAG FAULT warning light and VAGCOM Fault Code 00588
  1. 06-08-2009 04:12 PM #36
    Will this fix work on a 2006 Jetta 2.0T
  2. Member Fixxxer's Avatar
    Nov 15th, 2002
    Canada Eh?
    2011 Jetta Highline
    06-08-2009 09:51 PM #37
    Yup. This fix was originally released for the Mk5 VW line but has since had positive results in the Mk4's as well.
  3. 08-21-2009 12:40 PM #38
    will this work for a 2001 Cabrio?
  4. 08-21-2009 05:52 PM #39
    Fixxxer, this seems like some really great info your helping everyone else out with. I have the same problem (00588), but when I scan my air bag mod with my VagCom it also comes up with 00532- Supply Voltage 07-10 Signal too low-Intermittent. Since both these codes come up together will you "under the seat fix" still work??? I sure hope so.
  5. 08-25-2009 12:53 AM #40
    My fault is 00591 and
    008 - Implausible SIgnal - Intermittent - MIL on
    I assume the fix is still the same: get the connector out of the circuit?
    Thanks!
  6. 09-16-2009 09:25 PM #41
    Just to be clear, the connector pair is totally removed and replaced with wires, right? Or do you simply extend the cable by splicing in wires to prevent stressing the connection as the seat slides back and forth?
    Thanks
  7. 09-16-2009 11:27 PM #42
    Fixxer-
    Am I understanding right to believe that you just need to do away with the yellow connector?
    so, essentially..adding in a connector like this would be the same as jumper'ing the wires and just making long solid wires by using insulated crimping tubes or something.(similar, maybe not exact)In order to be able to freely remove the seats without re-cutting and fixing.
  8. 09-17-2009 10:01 AM #43
    Changing to the connectors you show would be the same as leaving the yellow ones and extending the cable length, but if the intention is to eliminate the connectors then it would not fix the error light.
  9. 09-18-2009 07:03 PM #44
    Fixxxer,
    Will this fix work on a 2004 Beetle convertible? I have the same error "drivers side air bag igniter Limit HIgh". I replaced the drivers side seatbelt as it had a few broken wires at the buckle. This fixed the seat belt code, but the airbag light is still on with the igniter high code.
    Thanks!!
  10. Junior Member AngeloB5's Avatar
    Nov 21st, 2002
    Queens, NY
    09-24-2009 12:08 PM #45
    this maybe a dumb question but based on this photo, http://www.flickr.com/photos/2...87793, the wires on each side of the plug do not match up. I am assuming I am following pin to pin with a one to one connection. Is this correct?
    Thanks
  11. 09-24-2009 12:24 PM #46
    You definitely want to match by pin #'s. I realized that is why he says to leave a short length of wire when you cut off the connectors; so you can tell what color is where. If the colors going into both connectors matched, you could easily see which ones to connect.
    I thought the instructions wre ambiguos when he said "connector" instead of "connectors"; "connector" could have meant you leave some length of the wires so you can splice in the new wires and see how to reconnect.
  12. 10-04-2009 05:26 PM #47
    So just to recap....you simply cut out the connector match up the wires and resolder them together? And that fixes the problem, the airbag light will then simply go out? So what are we saying that the connector has a connection issue?
    TIA
  13. 10-04-2009 09:21 PM #48
    You will have to have the light reset after you replace the connectors. Try to find someone in your area that has the VAG-COM device. Or you can order a device to reset it on ebay. Make sure the error code is the same as that in the start of this thread first.
  14. 10-04-2009 11:19 PM #49
    Thanks for the info....the VAG-com they sell on ebay is just the cable with adaptor isn't it? What about the software? Can you provide examples of this kit?
    TIA
  15. 10-04-2009 11:40 PM #50
    ok...why is the ebay vag-com less than $50 and the one from ross labs is $350? what's the difference?
    TIA
  16. 10-05-2009 08:44 PM #51
    I'm going to go ahead and post in the most recent thread instead of posting a new one, sorry for the highjack.
    I've got the 00588 code paired with a "00654 - Seatbelt Tensioner Igniter; Driver Side (n153) 32-10 - Resistance too High - Intermittent"
    I'm just wondering would the bypass of the connector work to fix both problems?
    The light stayed off for now but if it comes back I'd like to prepare a plan of action.
  17. Member Fixxxer's Avatar
    Nov 15th, 2002
    Canada Eh?
    2011 Jetta Highline
    10-06-2009 01:15 AM #52
    Probably should have been a bit more specific. The under-seat repair is for the side airbag ignitor only. Just the one built into the side of your seat near your head.
    When you cut out that connector, bu sure you splice in a piece of wire 3 inches long between each joined section to compensate for the removed plug or you may get another Airbag light because the resistance value the Airbag module is looking for will be different.
    You won't need to add another quick release plug because this mod will not affect the removal of your seats because the entire seat harness plugs into connectors on the floor.
  18. Member sebich1's Avatar
    Dec 10th, 2007
    Washington DC
    2000 Jettta GLX
    10-06-2009 03:56 PM #53
    i need an explanation concerning my jetta ...
    so last winter i had the exact same code:
    00588 - Airbag Igniter; Driver Side (N95)
    33-10 - Resistance too Low - Intermittent
    each time the weather was really bad with temperature below freezing (20F), i would find this code ...
    i read in a tech bulletin (01-00-07) saying that this code which appeared with the low temperature is related with the wiring harness behind the clock spring ...i changed the harness in front and behind the clock spring jut in case ..and no more code !!!
    BUT after changing the harnesses , the temperatures never dropped that low ...
    will i have some problem the next winter or i was right about changing the harness behind the clock spring ???
    thans fixxxer for your answer!!!
  19. 10-06-2009 04:25 PM #54
    The reset device, which is about $40, only does a reset and does not read codes. The cable with software, which is about $15, uses a scaled back version of the VAG-COM software but should be able to read most codes and do the reset. I'd send questions to the seller before you buy, but that is what they told me. I ended up not having to buy either.
  20. 10-16-2009 10:35 AM #55
    The reset device what is it?
  21. 10-16-2009 02:28 PM #56
    Check ebay for "VAG-COM" and "VW airbag" to see what type of devices are out there.
  22. 10-23-2009 10:56 PM #57
    just got the vag-com in and I did find a code seat belt switch left E24 cam up what is that?
  23. 10-27-2009 08:24 AM #58
    Any way to turn just the airbag light off to pass me inspection or can i un hook the wire code seat belt switch left E24
    Modified by Gti2008 at 5:34 AM 10-27-2009
  24. 10-27-2009 09:40 AM #59
    Check the vag-com website for a list of codes or do a web search, you'll find them. You can try to reset it, but I don't know if it will work or stay off. I'd just fix it.
  25. 10-29-2009 01:03 PM #60
    Does this fix work for the VW Jetta '01 MK IV GLS as well?
    Rgds
    SR
  26. Member jettatech's Avatar
    Oct 25th, 2001
    NJ
    85 ABAT,10 CCTA Tigger
    11-01-2009 10:04 AM #61
    FYI OP the N95 is the driver side front airbag( steering wheel). I don't recommend going and splicing the wires under the seat for that. Be careful when working on airbag systems and wires. Just because a certified vw tech says something works...... There is a technical solution for seat harnesses, yes, but that has nothing to do with a driver side front N95 bag. N195 and N95 are 2 different airbags. Please folks, don't go just cutting into your harness because someone over the internet told you so.
  27. 01-31-2010 11:42 AM #62
    I just replaced my 2000 golf seats with 2004 GLI seats. I spliced in the old connector from the old seats, and the airbag light is on. Now I read your advice.
    So I'll cut out the connectors, replace with wire pieces. How about the smaller connector going to the seat belt on the driver's side? Cut out that connector too?
    After hooking up the battery again, will the light go off, or do I need to re-set "codes" with "vagcom"? I don't have any special tools to check codes.
    Thanks for your reply!
  28. 02-07-2010 09:15 AM #63
    will this work on a 2003 audi tt 225hp?
  29. Member odawg753's Avatar
    Nov 5th, 2008
    long island
    2001 gti glx vr6, 1989 s10
    02-21-2010 03:46 PM #64
    i dont have vagcom but my light did go on today while driving, assuming that this is the problem, how do i clear the code? just disconect battery?
    p.s. those ebay things are garbage i bought one and it didnt work
  30. 02-21-2010 09:38 PM #65
    This fix worked on my 2005 Audi TT. Used the Vag-Com to clear the code and all is good. Thanks!
  31. 02-23-2010 08:32 PM #66
    i have an audi s4 is the fix the same code says passenger seat air bag
  32. 06-01-2010 08:17 AM #67
    I have change the passenger seat in my 2006 RS4 for a standard A4 seat(bony assed wife) no I don't want to change her either(no comments please). Now my airbag light is on will this fix work for me. This car is in Ireland so does a European spec car make a differance to this fix. Please any info would be greately appericated.
  33. Member chris808costa's Avatar
    Mar 10th, 2010
    Hawaii
    01 GTI vr
    06-05-2010 11:36 PM #68
    Here is a pic of mine
  34. 06-24-2010 08:48 PM #69
    i was switching out the gauge cluster fuse on my 2001 gti. when i put the fuse back, my air bag light came on and the "airbag fault" message came on. what do i do?
  35. 06-25-2010 05:57 PM #70
    For anyone in doubt.
    The instructions provided by Fixxxer (http://forums.vwvortex.com/showthrea...1#post54799334)
    resolved
    01217 - Side Airbag Igniter; Driver Side (N199)
    The instructions provided by Penclnck (http://forums.vwvortex.com/showthrea...0#post55699883)
    resolved
    The steps were performed on a 2000 Jetta VR6 GLX.
    Thanks!
