VWVortex.com - AEB 1.8t swap turbo oil and coolant lines? Help.
    Results 1 to 13 of 13
    Thread: AEB 1.8t swap turbo oil and coolant lines? Help.
    1. Member Boosted8v's Avatar
      May 5th, 2002
      Crofton, MD
      1990 Corrado 20vT, 2004 Passat Wagon 1.8T 5-Speed 4Motion, and 1987 Golf 8v Automagic
      01-17-2009 01:24 PM #1
      I put an AEB 1.8t from an A4 in my Corrado with a K03s on it with a mk4 1.8t manifold. I have rigged up oil and coolant turbo lines on my car because stock ones didnt line up with anything when doing the swap. Especially since im running mk4 manifold and turbo and b5 engine.
      What turbo lines are you guys running with the similar swap. I am running a mk2 oil cooler flange instead of the crooked audi 20v ones. Are you running stock vw one, from what car? and if your running aftermarket ones can you please give me an exact link to buy them. This has been one of the main problems on my car with leaks and hode failure.
      Thanks.
    2. 01-18-2009 01:41 AM #2
      Any OE transverse lines will work. the only difference will be the coolant return on the back of the engine. the AEB used a nipple in the block for the line to attach where as the later cars used a M14 threaded banjo.
    3. Member Boosted8v's Avatar
      May 5th, 2002
      Crofton, MD
      01-18-2009 02:24 AM #3
      What about the oil return? Since they use different oil pans, is the mounting point and length of the return the same between an A4 and a Mk4?
    4. 01-19-2009 10:17 PM #4
      You should be using a Mk4 return line and Mk4 pan. No issues if that's the case....if you're not you should be.
      Mar 5th, 2001
      Maine
      2016 VW GSW SEL, 1991 VW GTI 1.8t, 2012 Mazda 5 Sport
      01-19-2009 10:28 PM #5
      Quote, originally posted by Boostin20v »
      Mk4 oilpans dont fit AEB blocks, brainiac.
    6. Member Boosted8v's Avatar
      May 5th, 2002
      Crofton, MD
      01-19-2009 11:19 PM #6
      Quote, originally posted by Veedubgti »
      Yeah I didnt think they were interchangeable.
    7. 01-20-2009 07:33 AM #7
      Of course, forgot which short block you were using. As mentioned the Mk4 pan doesn't fit the 058 block (AEB).
      I do not know if the Mk4 line fits an AEB pan, though I'd be swapping it for a transverse pan anyway.
    8. 08-17-2010 08:19 AM #8
      Quote Originally Posted by Boosted8v View Post
      Thanks.
      Im having the same problem with my swap did you ever get the answer to the oil feed line im stuck on this problem
    9. Member 1.8TRabbit's Avatar
      Nov 15th, 2004
      Garage in the Rockies
      82 Rabbit 1.8L, 84 Rabbit GTI 20vBT, 86 Audi 4000Q, 96 Audi A4Q V6, 02 Audi A4 1.8T,06 BMW 325I
      08-18-2010 03:01 PM #9
      Quote Originally Posted by Veedubgti View Post
      lol, is that a little bit of inferiority I sense?
      Dwight D. Eisenhower: “If you want total security, go to prison. There you’re fed, clothed, given medical care and so on. The only thing lacking… is freedom.”
    10. Member Skat's Avatar
      Jan 9th, 2004
      Palm Coast, Fl
      92MG20v
      08-19-2010 11:32 PM #10
      Quote Originally Posted by Boostin20v View Post
      i used the 2.0 16v steel pan, and just tapped it, works just fine. And also used all the MK4 lines, just had to heat them up and re-bend them to fit what you are doing.
      The oil return line is a flex line so you have some play.
    11. Member Minty-MkII's Avatar
      Aug 10th, 2008
      L0E 1R0, Ontario
      1992 Golf Gti 20vT, 07 Rabbit 2.5 4D
      09-05-2010 03:31 PM #11
      What Oil Filter flanges are you guys using to replace the sideways Passat/Audi ones?
      "As men, we know NOTHING turns a girl on more then a well executed handbrake turn...Peacocks have their feathers, Men have the handbrake"
      Check out the 8v to 20v Conversion Story
    12. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-10-2010 10:07 PM #12
      mk3 ABA works fine.
      There's lots of threads out there with this answer
      | œ Orchid Euro Importation œ |
      Currently driving or working on too many cars...
      | '93 Fox 16v - PVW | '99 Greenland Polo Diesel | '89 Rallye Golf | '83 Golf GTi RHD | '75 Swallowtail |
      | '82 Caddy 1.9D | '85 VW LT Car Transporter | Mk2 Jetta Limo | '90 Jetta 8V | '96 VW LT35D | '03 SpintLT35 | '02 GTI 337 | '03 GTI 20v |
      | '09 Aprilia RS125 | '81 Kawasaki AR80 | '59 NSU Quickly | '64 Honda Cub C65 + '65 C105 | Trek Emonda SLR9 | Trek Crockett 9 |
    13. Member ronster731's Avatar
      Sep 25th, 2004
      Kailua, HI
      1983 1.8t Rabbit, 04 Tacoma
      09-17-2010 01:30 AM #13
      I just had custom lines made from the passat set up. As far as the coolant lines.... I made on my own with regular hose. As far as the oil filter flange I am using a 2.0 A3 style one. GL. I'll try and post some pics up tomorrow if you would like.
