thats interesting as hell..Very good looking out.
#1
Flywheel and Kits Below
FST 228MM L/W Single Mass Steel Billet Flywheel Includes Ring Gear $324.95 Shipped Ground
FST 228MM L/W Single Mass Steel Billet Flywheel Without Ring Gear $309.95 Shipped Ground
FST 228MM L/W Single Mass Alloy Flywheel Includes Ring Gear $389.95 Shipped Ground
FST 228MM L/W Single Mass Alloy Flywheel Without Ring Gear $369.95 Shipped Ground
FST 228MM L/W Single Mass Alloy Flywheel W/ Sachs VR6 Clutch Kit $559.95 Shipped GroundFST 228MM L/W Single Mass Steel Billet Flywheel W/ Sachs VR6 Clutch Kit $499.95 Shipped Ground
FST 228MM L/W Single Mass Alloy Flywheel W/ Clutchnet Stage 2 VR6 Clutch Kit $745.95 Shipped Ground
FST 228MM L/W Single Mass Alloy Flywheel W/ Clutchnet Stage 3 VR6 Clutch Kit $759.95 Shipped GroundOEM 2.5 Dual Mass Flywheel W/ Ring Gear 22.7 LBS
OEM Clutch Disc & Pressure Plate 10.1 LBS
Total Weight 32.8 LBSFST Alloy Single Mass Flywheel/ Ring Gear 10.0 LBS
Sachs VR6 Clutch Disc & Pressure Plate 13.1 LBS
Total Weight 23.1 LBSTotal Overall Weight Reduction 9.7 LBS
By using a heavier Clutch Disc & Pressure Plate this will add 3 more
pounds to the Alloy flywheel (as compared to the OEM 2.5 Clutch Disc &
Pressure Plate ) making it feel like a 13 pound flywheel. This overall
weight reduction is 9.7 pounds. A steel version could be made if the
alloy one ends up being too light and or a heavier version is wanted.Here are some examples of other weights of OEM Flywheels (Engines of
similar power)
All OEM Single Mass Cast VR6 12V flywheels are 17.75 pounds w/ ring gear.
Many users have switched to a L/W Steel Billet Flywheel that weighs in at 11.75 w/ ring gear fitted.
Also available are slightly heavier Cast steel Single Mass w/ ring gear at 13.80 pounds ( still lighter than stock).MK4 1.8T W/ 5 speed users are changing the OEM DM 22 pound flywheel
and converting to A Single Mass as well.
Again using the same weight as a 12V VR6 single mass steel billet
flywheel that weighs in at 11.75 w/ ring gear fitted.Also available
are slightly heavier Cast steel Single Mass w/ ring gear at 14
pounds.Both of the these flywheels were created in the aftermarket as a
performance part designed for the Corrado G60 and are using the very
proven Sachs VR6 clutch kit ( this Sachs kit is rated to 250-275
Torque and takes more)1.8T & 2.8 24V VR6 W/ 6 speed 02M 6 speed users are changing the OEM DM
26.5 pound flywheel to A Single Mass type as well. 16.5 single mass
steel billet w/ ring gear this takes 10 pounds off and does not chatter.Clutch Kits without Flywheel
2.5L Stage 1 Clutch Kit $179.99 Shipped Ground ( Includes 228MM Sachs Pressure Plate, Sachs Sprung Hub Disc,Sachs T/O bearing. Rated at 275 TQ at flywheel.Must be used with FST228-2.5AFW.
2.5L Stage 2 Clutch Kit $359.99 Shipped Ground ( Includes 228MM Clutchnet Yellow Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub,Sachs T/O bearing and alignment tool. Rated at 375 TQ at flywheel.Must be used with FST228-2.5AFW.
2.5L Stage 2 Clutch Kit2.5L Stage 3 Clutch Kit $375.00 Shipped Ground ( Includes 228MM Clutchnet Red Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel. Must be used with FST228-2.5AFW.
2.5LStage 3 Clutch Kit2.5L Stage 2X Kevlar Clutch Kit $445.00 Shipped Ground ( Includes 228MM Clutchnet Red Pressure Plate,Kevlar Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 400 TQ at flywheel. Must be used with FST228-2.5AFW.
2.5L Stage 2X Clutch Kit2.5L Stage 2X Fiber Carbon Clutch Kit $445.00 Shipped Ground ( Includes 228MM Clutchnet Red Pressure Plate,Fiber Carbon Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 400 TQ at flywheel. Must be used with FST228-2.5AFW.
Install photos and sound clips below. Test Fitted and driven Friday and Saturday.To my knowledge this is the First kit using these parts. I have only seen a box from SB ( no contents or description known) Also heard about another flywheel from BS again have not seen contents or know description of it).
There was a very slight noticeable chatter at idle with clutch pedal out. this noise is no where near as loud a the 9 lb alloy flywheel on a 02m 6 speed. Sounds clips might not pick it up ( recorded on a basic canon digital camera) this will be uploaded later today.
California residents will be charged 8.00 % sales tax.The current site only has a fraction of the parts listed that we carry.Please contact us if the items you seek are not on the site. Competitive pricing, Fast shipping, If you see a lower price let us know, chances are we can work with you.
Questions at 714-997-5842 M-F 10-6 PST
Email is better than IM
sales(AT)fourseasontuning.com*Thanks for looking.
JamesAKA wld101turkey
Modified by FourSeasonTuning.com at 9:27 PM 4-5-2009
:: www.FourSeasonTuning.com
:: Wössner-APR-C2-United-Supertech-Clutchnet-DXD/SBC-Koni-KW- IE-Bosch-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
:: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
#2
#3
Thank You.
#4
any 2.0T clutch kits?
Women are the most powerful beings in the world for this simple reason. When your dead it takes 6 guys to carry your casket but only takes 1 woman to put you there.
#5
The Mk5 2.0T kits are listed now.$949.95 2.0T South Bend Clutch Stage 1 KIT W/ 20 Lb Flywheel SBC Single mass steel billet 20 Lb,SBC Full face Organic Disc W/ Sprung Hub,Modified Sachs Pressure plate,flywheel & pressure plate bolts, OE release bearing and alignment tool.Rated at 400 TQ.
$1049.95 2.0T South Bend Clutch Stage 2 TZ KIT W/ 20 Lb Flywheel SBC Single mass steel billet 20 Lb,SBC Kevlar Disc W/ Sprung Hub,Modified Sachs Pressure plate,flywheel & pressure plate bolts, OE release bearing and alignment tool.Rated at 325TQ.
$1049.95 2.0T South Bend Clutch Stage Stage 2 Endurance (aka old 3 OFE KIT) W/ 20 Lb Flywheel SBC Single mass steel billet 20 Lb,SBC Full face OFE disc Dual sided W/ Sprung Hub,Modified Sachs Pressure plate,flywheel & pressure plate bolts, OE release bearing and alignment tool.Rated at 450 TQ.
2.0T South Bend Clutch Stage 2 Endurance
#6
cool, yeah, i think i need a new cluth soon.... it's good to know you got them instock !![]()
#7
What is the install time for the 2.5l jetta?This looks great!
#8
Thank you & Im sent.
#9
Anything available for the MKV GTI, other then Clutchmaster listed on your site?
#10
Is your engine code a BPY or CBFA?
#12
any info and idea if u sell a single mass flywheel/clutch to fit my mk4 golf engine code bde 2.8 v6 24v 2002 model, (240mm)fitted with the 02m 6speed , after something to suport 500bhp , just shipping im a bit worryd about ,
mk1 golf, mk5 r32c holset hx40 turbo 6 speed tdi gearbox,02m haldex 4wd , electric steering ,
#13
We have a 02M for the VR6 that will support 450 torque. Shipping would be about $110
for 2 Large Flat Rate USPS 6-10 day service.$1035.00 Clutchnet Stage 3+ CLUTCH KIT W/16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Copper Feramic Steel covered Sprung hub Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 3+ Copper Feramic KIT
#14
IM's replied
#15
Pm'd
DubsOfQueens.com | Tyrol Sport | BSH Street Team
#16
Replied
#17
I have about 7k miles on mine and I love it. I let it break in for 1,000 miles the slow started "testing" it. It feels so much better than stock. Like a totally dif car
93 Golf R.I.P - 85 Jetta R.I.P - 06 Jetta - Sold
#18
Do u have any clutch kits for the mkv 2.0T. I need the complete kit. Letme know plz. Sorry if im repeating the question but im on my iphone.
Instagram Arismkv
#19
Stock or performance kit?
#20
A performin kit
Instagram Arismkv
#22
$674.95 OEM 2.0T FSI KIT W/ 19 Lb Flywheel FST Single mass steel billet 19 Lb,LUK Full face Organic Disc Dual Dampened,LUK Pressure plate,LUK release bearing. 6 Flywheel & Pressure plate bolts, and alignment tool.
OEM 2.0T FSI KIT W/ 19 Lb Steel Billet Flywheel$674.95 OEM 2.0T FSI KIT W/ 9 Lb Flywheel FST Single mass Alloy 9 Lb, LUK Full face Organic Disc Dual Dampened, LUK Pressure plate,LUK release bearing. 6 Flywheel & Pressure plate bolts, and alignment tool.
OEM 2.0T FSI KIT W/ 9 LB Alloy Flywheel
Modified by FourSeasonTuning.com at 10:25 PM 4-17-2010
#23
***DXD/South Bend Clutch Kits Fits 2008.5 and Up TSI engines ***
$949.95 STAGE 2 Daily Kit with 17lb flywheel DXD/SBC Single mass Steel Billet 17 pound 240MM flywheel, 240MM Pressure Plate,Sprung Hub Full face Organic/Metallic Disc, 8 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 2 Daily Kit 400TQ
$1049.95 STAGE 2 Endurance Kit with 17lb flywheel DXD/SBC Single mass Steel Billet 17 pound 240MM flywheel, Sachs Sport Pressure Plate,Sprung Hub Full face Organic/ OFE Metallic Disc, 8 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 2 Endurance Kit 450TQ
$1049.95 STAGE 2 Drag Kit with 17lb flywheel DXD/SBC Single mass Steel Billet 17 pound 240MM flywheel, Heavy Duty Pressure Plate modified for a puck style disc with no cushion between the linings to keep the clutch pedal travel short and quick, Six Puck Sprung Hub Disc, 8 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 2 Drag Kit 520TQ
$1349.95 STAGE 3 Daily Kit with 17lb flywheel DXD/SBC Single mass Steel Billet 17 pound 240MM flywheel, Sachs Sport Modified Pressure Plate, Sprung Hub Full face Organic Disc, 8 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 3 Daily Kit 470TQ
$1399.95 STAGE 3 ENDURANCE Kit with 17lb flywheel DXD/SBC Single mass Steel Billet 17 pound 240MM flywheel, 240MM Sachs Sport Modified Pressure Plate,KEVLAR Sprung Hub Full face Disc, 8 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 3 ENDURANCE Kit 485TQ
$1395.95 STAGE 3 Drag Kit with 17lb flywheel DXD/SBC Single mass Steel Billet 17 pound 240MM flywheel, 240MM Sachs Sport Modified Pressure Plate, Graphite impregnated Ceramic Six Puck Disc, 8 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 3 Drag Kit 575TQ
#24
:: Wössner-APR-C2-Cat Cams-Supertech-Clutchnet-DXD/SBC-Koni-KW- IE-Bosch-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
:: VW / Audi Performance and Oem Parts Source ::714-997-5842 M-F 10:30-6:30 PST
#26
Only OEM ones for the DSG.
#27
#28
Can price on Tuesday, What is your year make and model?
#29
New to the whole tuning of VW's. I need to know what flywheel and clutch kit would perform the best in a a Jetta. Please pm me back so I can maybe sneak these in under the X-mas tree!
#30
PM sent
#33
Hey bud, the Stage 1 kit that is cheap for the 2.5L doesnt seem to load when you click the link, but the Stage 2 does. Did you do away with the Stage 1 Clutch Kit?
Chapter 11 Dübs - Broke Status
#34
The stage one kits are still here,however they must be used with the flywheel.
Steel Flywheel
http://www.fourseasontuning.com/prod...5SBRG.K7003802
Alloy Flywheel
http://fourseasontuning.com/product.....FST107904-11T
#35
Thanks for the info, besides weight, i dont see very many differences between the steel and aluminum. Could you point out the main differences between the two? If i understand they are still rated to 275 TQ
