VWVortex.com - OFFICIAL****2.0 8v turbo spec lists thread(whp,psi,etc)
    Page 3 of 9 FirstFirst 1234567 ... LastLast
    Results 51 to 75 of 220
    Thread: OFFICIAL****2.0 8v turbo spec lists thread(whp,psi,etc)
    1. Member GTijoejoe's Avatar
      Oct 6th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      06-23-2009 02:29 PM #51
      Quote, originally posted by jose_vw »
      277whp / 272lbsft @ 17psi
      Since when does 17.99psi = 17
      Modified by GTijoejoe at 8:17 PM 6-23-2009
      2.0T+034efi+meth = 300+whp = RIP
      FS: 2015 Honda Civic Si
    2. Member the_q_jet's Avatar
      Mar 19th, 2005
      DC
      QUINTIN@USRT
      06-23-2009 03:55 PM #52
      Quote, originally posted by GTijoejoe »
      Quote Originally Posted by jose_vw
      agreed LOL
      DONT PM THIS ACCOUNT!! I RARELY CHECK IT!
      IF YOU HAVE QUESTIONS/CONCERNS/ISSUESWITHZOMBIES PLEASE IM MY OTHER ACCOUNT BELOW:
      Quintin@USRT
      Jul 31st, 2007
      PR
      98'NB 2.0T
      06-23-2009 04:21 PM #53
      Well, as you can both see from the graph the car decided to enjoy the 17psi range from 16.9 to 17.9, and as you can both see from the graph it is 17psi all the way up to the end when its maximum boost roughly touch 17.9 which is still 17, so I will have to say that, Yes, 17psi bro, look at the dark line marking 18psi and you will understand me.... Anyway lets say that it is 18psi...
      17 or 18 psi, I dont realy care, but what realy impressed me was how that head was flowing, I cant wait to put a nice cam down there... Any recomendations from the 8v Gurus on any specific cam will be realy appreciated.
      Modified by jose_vw at 12:43 PM 6-23-2009
    4. Member GTijoejoe's Avatar
      Oct 6th, 2001
      06-23-2009 09:17 PM #54
      At what RPM did you stop the run?
      Seemingly you kept pulling till 'redline', that head work shows with stock cam [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Many of us are using autotech 270 cam... I've used TT 260/256 cam, both work well with FI application...
      Jul 31st, 2007
      PR
      98'NB 2.0T
      06-24-2009 03:12 PM #55
      6000-6100 rpm
    6. Member Daskoupe's Avatar
      Oct 9th, 2006
      Sarasota, Fl
      mk2 coupe,15 A3 Tdi
      10-04-2009 01:17 PM #56
      BACK up.Lets keep this going
      new setup is 1500 miles deep
    7. Member 2.0t mk2's Avatar
      Dec 23rd, 2007
      Dallas, Ga
      01 TT 225 with a 3076r ,94 Jetta GLX
      10-04-2009 05:31 PM #57
      will post new setup soon
      go fast and get money
    8. Member Salsa GTI's Avatar
      Aug 29th, 2000
      Venice Florida
      2000 GTI VR6 ....... A founding Member of the 8v 320+whp Club
      10-07-2009 08:22 PM #58
      Ok Finaly after 4 failed chip tuned attempts.....it breaks 300whp
      Yes folks first run Low boost..10 psi 200.20 whp 200.06 wtq 70deg 26% humidity...
      second run..push the rear window defrost button...fun boost 25psi
      320.12 whp 329 wtq........
      http://www.youtube.com/watch?v..._page
      now I'm happy
      1999 OBD2 ABA …….
      Completely Stock Lower End
      German OBD1 Autotech 270 camshaft with TT adjustable cam Gear
      E-Bay under drive pulley
      My Home built MK4 short runner intake manifold
      034efi stage 1C
      034 motorsports coil
      Delphi 85# low imp injectors
      Stacked Victor Rienz head gaskets and ARP non undercut head studs
      PSI cast exhaust manifold with external waste gate flange
      Tial 38mm waste gate with 10 psi spring. plumbed in stainless back into the down pipe pre cat…..
      Turbonetics T3/TO4B “S” trim turbo with a stage 2 exhaust wheel in a .63 5 bolt exhaust housing
      Air pressure regulator as a boost controller 23-25 psi of Boost
      3” Stainless down pipe into 3 inch exhaust with cat welded around it..(for Looks)
      18” long magnaflow center resonator…magnaflow muffler into duel outlet exhaust tip
      Paint matched G60 valve cover
      2.5” stainless intercooler piping into 2.5 in and out front mount intercooler..(painted Black) core measuring 3”x7”x19”
      NGK BREK8EIX spark plugs gapped at .026
      Using an 02A trans with an Autotech Wavetrac Diff and a Spec Stage 3 Clutch and 11lb flywheel
      Modified by Salsa GTI at 8:59 PM 10-7-2009
      Modified by Salsa GTI at 9:00 PM 10-7-2009
    9. Member bharry07's Avatar
      Jul 6th, 2006
      CT
      mk3s
      10-07-2009 10:37 PM #59
      Bone Stock OBD2 ABA with 190k
      12-13psi on 14b Mitsu Turbo from Starion
      c2 42lb
      440cc inj
      3in MAF
      Turbosmart 38mm Wastegate 6lb Spring, open dump
      Homemade Short runner
      2.25 Turbo back to a VR6 Suitcase for the quiet performance
      2in Intercooler piping
      Kinetics Manifold
      Custom adapter from t3 to mitsu flange
      No recirculating BOV
      Lightweight flywheel/Sachs replacement clutch
      Ran at 18psi for over a month before the long trip from CT to MD for H20. She
      didnt blow up so I drove it there and back. Figured was a good torture test!
      Have like 3-4k on setup and dyno is coming soon. Hoping for
      anything over 200whp at 12psi
      Modified by bharry07 at 9:01 PM 10-7-2009
      Dan's Auto Sales & Repair CT Auto Repair and Used Car
      Creep....
      IM me for Air Ride Installs, Frame notches, ect.
      Apr 24th, 2009
      Saginaw, MI
      1999.5 VW Jetta
      10-07-2009 11:52 PM #60
      do you have any problems with an open BOV and the softwear?
    11. Member steven12345's Avatar
      Jul 18th, 2006
      rahway NJ
      01-11-2010 12:56 AM #61
      any new setups to be added to such a old topic
    12. Member Daskoupe's Avatar
      Oct 9th, 2006
      Sarasota, Fl
      mk2 coupe,15 A3 Tdi
      01-11-2010 05:25 PM #62
      60-1 for thats about it
    13. Member rweird's Avatar
      Apr 10th, 2004
      Lititz, PA
      1988 Cabriolet
      01-11-2010 06:57 PM #63
      stock aba block 125k
      stock head
      headspacer
      arp head studs
      delphi 42lb injectors
      ebay fmic
      2.5" charge pipes
      3" intake K&N
      3" custom dp
      3" MBS exhaust w. magnaflow
      lwfw
      old eip 8puck clutch disc
      t3/t04e 50 trim .63 hotside
      stg2 c2 chip
      greddy type rs bov
      turbonetics deltagate mk2 wastegate 9lb spring i think? open dump
      kinetics manifold
      turbosmart manual boost control
      ~14psi from before i put in the headspacer and studs
      traction issues.
      Modified by rweird at 6:23 PM 1-11-2010
    14. Member the_q_jet's Avatar
      Mar 19th, 2005
      DC
      QUINTIN@USRT
      01-11-2010 09:50 PM #64
      FP Red turbo (3582r compressor wheel, mitsubishi td06h turbine wheel) @24psi put two cars on a stage3 2.7TT A6 from 40mph to 100
      switching to something else now as that turbo blew the seals
      Quintin@USRT
    15. Member
      Dec 8th, 2008
      New Haven CT
      97 vrt gti 97 trek 2.0 T sold cheap 94 s10
      01-25-2010 05:10 PM #65
      1997 jetta trek stock motor
      sai delete
      garret turbo 42 ar cold 48 hot 5ib internal wg
      ebay intercooler kit , bov, and manifold
      c2 stage 1 chip and matching injectors
      horrible exhaust leak but a much faster car
      i want a sri and a cam! and a paint job!!!
    16. Member gtvento13's Avatar
      Oct 4th, 2007
      Cranston RI
      all my cars is foreign
      01-29-2010 06:41 PM #66
      i see ur car at all the local shows hood always closed, im happy to see ur bays
      Modified by gtvento13 at 2:42 PM 1-29-2010
      A&M Euros
    17. Member Daskoupe's Avatar
      Oct 9th, 2006
      Sarasota, Fl
      mk2 coupe,15 A3 Tdi
      01-29-2010 07:15 PM #67
      i need a Fuel pump!
      what are you guys running?
      I cant get over 14 psi,even with a 4bar lol.afr's are at 12.2!!!
    18. 01-29-2010 07:24 PM #68
      1992 gti 16v witha 2l aba turbo
      tiny turbo this year
      looking for 200 whp on 15 psi
      airresearch t3 43 trim .48 ar
      Kinetic head spacer
      apr headstuds
      kinetic downpipe
      kinetic cast turbo manifold
      large fmic
      stainless steel piping
      g-60 engine management
      old pics
      got it in golf plus haha
      Modified by MaxVW at 3:26 PM 1-29-2010
    19. 01-29-2010 07:32 PM #69
      i ran into that problem try a cis pump they will flow enough to get past 300 whp IIRC
    20. Member Daskoupe's Avatar
      Oct 9th, 2006
      Sarasota, Fl
      mk2 coupe,15 A3 Tdi
      01-29-2010 07:49 PM #70
      i would but i dont have any good ones.There like 110 dollars new,which gets me 20 short of a wablro
    21. Member VDubberster's Avatar
      Oct 9th, 2007
      Providence, ri
      1996 Jetta GLS and 1994 Golf sport
      02-02-2010 02:43 PM #71
      For the guys with SRI with obd1 system aba, where do you relocate the icas? or what is done to it if disconnected
    22. 02-02-2010 06:30 PM #72
      I think you mean the ISV on OBD1 ABA, as obd2 does not use it. I extended the wires and stuck it the rain tray. reconnect the in and out on the valve to itself and leave it hooked up, mines been fine for over 2 1/2 years. You will most likely have to play with the small idle adjustment screw on the throttle body to get it just right, or i least i did.
    23. Member Daskoupe's Avatar
      Oct 9th, 2006
      Sarasota, Fl
      mk2 coupe,15 A3 Tdi
      02-02-2010 07:06 PM #73
      i moved mine to the bottom.still use it cause i have ac
    24. Member VDubberster's Avatar
      Oct 9th, 2007
      Providence, ri
      02-03-2010 01:03 AM #74
      sorry typo was suppose to be iac, idle air control
    25. 02-04-2010 06:50 PM #75
      Quote, originally posted by 2.0t mk2 »
      Is this made out of the stock manifold? Like the back half welded to the stock runners? Do you have any pics of the making of this manifold?
