Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 106 to 140 of 197
Thread: OFFICIAL****2.0 8v turbo spec lists thread(whp,psi,etc)
  1. Member snobum's Avatar
    Dec 16th, 2005
    Portland
    00'Jetta2.0T/ 03' Bmw Z4
    05-08-2011 11:37 PM #106
    Quote Originally Posted by snobum View Post
    fully built 83mm pistons and ie rods
    aeg engine
    268/260 tt cam--- went back to 256/260 cam better low end torque
    arp head studs
    nubs sri ---- currently stock waiting on new manifold
    stacked oem spacer
    united motorsports file
    440cc injectors... 630cc for e85 on additional ecu
    evo 8 intercooler
    38mm mvr water cooled external wastegate open atmosphere dump
    open atmosphere bov
    new precision billet turbo going in when i get the new tubular manifold built. but still running a garrett t3 .50 /.48 a/r ceramic coated a/r and dp
    3" turbo back exhaust with borla
    meth injection 80% meth 20%water
    6puck clutch 11lb flywheel
    daily driven off wastegate at 12psi.
    track run at 22psi with 110 leaded race gas and meth
    est... 300whp @18psi with meth
    Modified by snobum at 1:00 AM 10-5-2009
    Modified by snobum at 1:02 AM 10-5-2009
    just an update im still running the united motorsports software i have extra ecu that has the 630cc e85 file and now a tubulare exhaust manifold has been made to fit to the precision billet turbo, new engine in garage is running 83mm 8.5:1 and ie rods, fully ported head with heavy duty vsprings and oversized valves. will post pics up soon i will be producing a few of these so soon for sale!!!! an lri is in the mix but im going the longgg runner style with some different angles to it you will see soon enough not your average lri. car has had issues with the walbro pump with use of e85 so i went 044 and im using a fuel lab fpr. there is so much more
  2. Member Kjkustomz's Avatar
    Apr 10th, 2011
    Edmonton AB. Canada
    99Wolfburg golf 8VT, 79 German rabbit 16vt aba/abf
    06-15-2011 02:13 PM #107
    Just started my build. Playing with boost for the first time. I'll be using obd2 2.0l block.
    Stock internals
    C2 motorsport stg1 30lb software
    Ported aba head, (stock valves)
    Stock int mani match ported
    Autotec 270 cam
    Autotec adj cam gear
    Double stacked head gaskets
    Arp head bolts
    True t3super 60, w/.63 ar
    Internally gated, will be changing to external.
    3"dp
    Svt 30 lb inj
    Spearco fmic, 21/2 in & out
    Snow stg 2 water meth kit.
    Aem tru boost wideband/controller
    Hoping to run 10-12 psi. Goal is 250 hp
    Still need 38mm wastegate & bov. Can hardly wait.
  3. Member Albertkvw's Avatar
    Aug 19th, 2010
    908 nj
    99 golf, 03 jetta
    08-18-2011 04:41 PM #108
    Was set on dropping in a vr but this thread is making me rethink that, 2.0t lot less money and still can have some fun. I dont know anymore hehe
  4. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    95 2.0 turbo, 97 vr6
    08-28-2011 10:06 PM #109
    kinetic stage 3 with precision super 60..and built motor
    no dyno sheets yet still breaking in
    before 02a swap
    OG suede
    I survived epic thread 2011 never forget 11/11/11
    Quote Originally Posted by vastxpunk View Post
    You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
    May 3rd, 2011
    Downtown, Bako
    E36 ///M3 + Mk2
    12-05-2011 12:23 PM #110
    wow great thread!
    Shinin’ like a mother****er BBS' blingin' Steve Erkle bought a ton... -Dolla
  6. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    Eight valve like WHOA.
    01-25-2012 03:10 AM #111
    It's Timmy with mmmmMojo, i have returned
    8VALVETURBO - Sorting the kinks out.
  7. Member themagellan's Avatar
    Mar 30th, 2007
    NorthShore, MA
    1991 Audi 200 20vt Quattro
    01-25-2012 11:03 AM #112
    Pretty sweet torque #'s up in here!
  8. Junior Member mikeyaka23's Avatar
    Jan 26th, 2012
    Beetle 1998
    02-08-2012 07:41 PM #113
    Quote Originally Posted by nab5126 View Post
    I can play too, 00 MK4 Golf AEG
    Stock everything: head, cam, pistons
    T3 Turbo out of a Benz i beilieve, .42-.48
    Team PSI mani
    Ebay Fmic and pipes
    C2 Tuned
    42lb injectors
    3" C2 alum maf
    C2 Head spacer
    Arp studs
    BFI stg 2 dogbone mount
    BFI leaky steel pan
    Over the summer was running ~10 psi the dyno at vagkraft i did 175whp and 230 tq but that could be canadian i think its more and it was about 85*
    So in the coming months i plan on vr clutch and 14lb flywheel, brakes, turbo rebuild then hopefully have it dynoed again in april-may
    was this hard to do?
  9. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-10-2012 08:22 PM #114
    Mk3 jetta silver arrow
    I was going to build the 8v head but changed my mind and plan on going 16v in the future. Getting a Dyno done tomorrow and I will post my numbers once done.
    228hp 271tq 14psi
    Motor:
    Stock Aba head
    Stock Aba block
    Delphi 440cc injectors
    C2 stage 2 chip
    BFI Stage 1 motor mounts
    Walbro 255lb in tank fuel pump
    Ecs fuel pressure regulator
    Innovate wide band
    Hks ssqv
    ATP manifold
    Precision sc61 gt35 ( has a story behind it )
    Transmission:
    Stock gears
    Peloquin LSD
    Clutch net 6 puck unsprung clutch
    Mt90 redline fluid.
    ABA Turbo Club
    228hp 271tq at 14psi with pte GT3561E
  10. Member the_q_jet's Avatar
    Mar 19th, 2005
    DC
    QUINTIN@USRT
    02-15-2012 11:01 PM #115
    Quote Originally Posted by papo98jetta View Post
    228hp 271tq
    Motor:
    Stock Aba head
    Stock Aba block
    C2 stage 2 chip
    Innovate wide band
    Hks ssqv
    ATP manifold
    Transmission:
    Stock gears
    Peloquin LSD
    Mt90 redline fluid.
    boost level? that turbo doesnt even begin to wake up til 20psi+
    DONT PM THIS ACCOUNT!! I RARELY CHECK IT!
    IF YOU HAVE QUESTIONS/CONCERNS/ISSUESWITHZOMBIES PLEASE IM MY OTHER ACCOUNT BELOW:
    Quintin@USRT
  11. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-18-2012 12:12 AM #116
    14psi no head spacer.
    ABA Turbo Club
  12. Member groundupjetta's Avatar
    Feb 1st, 2010
    Rhode Island
    MkIV VR6
    02-18-2012 01:14 AM #117
    Get a cam and say hello to 250whp
  13. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-18-2012 12:47 PM #118
    Gonna get parts to go 16v, I'm going to the dark side.
    ABA Turbo Club
  14. Member the_q_jet's Avatar
    Mar 19th, 2005
    DC
    QUINTIN@USRT
    02-20-2012 09:26 PM #119
    or just get that custom 276 cam i got, a headspacer, and turn the boost up
    Quintin@USRT
  15. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    02-21-2012 02:52 AM #120
    listen to q, his car was a FUKN BEAST
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  16. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-21-2012 11:29 AM #121
    I know it was, me and him have talked a lot in the past. I'm happy with the numbers, they are really good for an all stock block. I just can't deal with the max flow of an 8v head, I want big power. But I just might do that q just until I finish my new motor.
    ABA Turbo Club
  17. Member the_q_jet's Avatar
    Mar 19th, 2005
    DC
    QUINTIN@USRT
    02-22-2012 11:54 PM #122
    how big? 500whp is pretty easy. 600whp though...it's been to 540ish with a regular 35r so i imagine a larger say 6262 could do it.
    Quintin@USRT
  18. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-23-2012 08:03 AM #123
    I have never seen that done, and specs? I was looking for a 600whp daily.
    ABA Turbo Club
  19. Member the_q_jet's Avatar
    Mar 19th, 2005
    DC
    QUINTIN@USRT
    02-23-2012 08:37 AM #124
    Find JakRabit on here...he ran BlackSheep Performance outta Vegas that i heard he was trying to reopen. He had a build/dyno thread a long time ago. But IIRC a custom cam some port and polish, a twinscroll equal length, rods/piston, and a t4 .68a/r GT3582 at like 35psi.
    That's a 61mm turbo and i was making 420whp at 30psi on a 54mm turbo at 30psi. I was gonna upgrade to a new billet PTE 62mm before i sold it and shoot for 550+
    REALIZE THIS 400FWHP is plenty on a daily and never hooks below 50degrees til 90~100mph...jus sayin
    Quintin@USRT
  20. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-23-2012 11:18 AM #125
    Thanks a lot q I have to make my mind up on this.
    ABA Turbo Club
  21. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-23-2012 02:45 PM #126
    Just got beat by a srt-4 because of it died on me at the end of 3rd. I need more power, and fast.
    ABA Turbo Club
  22. Member
    Jan 16th, 2002
    02-23-2012 04:02 PM #127
    turn up the boost
    Caddy ABA-t holset hx35 :-) GLX VR-T.... TDI daily
    DCI
  23. Member the_q_jet's Avatar
    Mar 19th, 2005
    DC
    QUINTIN@USRT
    02-23-2012 07:43 PM #128
    You better, the 8v is plenty capable of 500whp+
    really....please see below...
    Quote Originally Posted by fastrabbit View Post
    turn up the boost
    That easy.
    Quintin@USRT
  24. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    02-23-2012 08:32 PM #129
    Need to get everything first.
    ABA Turbo Club
  25. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    03-16-2012 09:18 PM #130
    mine was posted above but i will give you the spec list still need to be dyno'd but hopeing to be in the 300whp club
    95 jetta obd1 2.0
    kinetic stage 3 turbo kit
    precision t3/t4e 60trim turbo
    42# injectors
    90mm maf housing
    c2 software
    kinetic front mount intercooler
    tial 38mm wastegate (dumped)
    baileys dv
    02A trans with vr clutch and g60 flywheel
    2.5 inch exhaust no res or cat one magnaflow muffler
    walbro 255 fuel pump
    bbm fuel rail
    bbm fpr housing and regulator
    port and polished 3 angle valve job head work
    autotech sport tuned valves
    autotech sport tuned valve springs
    tit. retainers
    tt light weight lifters
    arp head studs
    autotech 270 cam
    autotech adj. cam gear
    autotech light weight intermidate shaft pulley
    euorsport under drive pulley
    bottom end cleaned and cylinders honed
    kinetic head spacer
    I.E connecting rods
    stock forged pistons
    balanced obd1 forged crank
    a/c delete
    p/s delete
    kinetic mbc (25psi)
    couple more pics...need to get it dyno'd after i install the wideband and some other little things hopeing for 300+
    OG suede
  26. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    03-22-2012 09:12 PM #131
    Quote Originally Posted by the_q_jet View Post
    Who do I need to talk to about the cam?
    ABA Turbo Club
  27. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    03-22-2012 10:55 PM #132
    Nobody, it's production now.
  28. Member papo98jetta's Avatar
    Dec 10th, 2008
    Homestead, Florida
    98 Jetta 2.0T
    03-23-2012 06:49 AM #133
    Thanks, just blew my head gasket.
    ABA Turbo Club
  29. Member rawk's Avatar
    Jul 29th, 2000
    Eastern CT
    91 GTI ABA-T, 01 GTI VR6
    03-26-2012 09:16 AM #134
    Figured I would add my car since its finally running...
    OBD1 ABA
    9:1 Compression w/ Metal Headspacer
    Rotomaster T3/T4 Turbo
    Port & Polished Head
    HD Valve Springs w/ Titanium Retainers
    Autotech 270 Cam
    Autotech Adjustable Cam Gear
    GruvenParts Billet Pulley Set
    42# Injectors
    Short Runner Intake Manifold
    Ross Fuel Rail w/ FPR Adapter
    C2 Custom Chip
    Air/Water Intercooler
    Eurojet DV
    Tial 38mm External Wastegate
    Walbro Inline Fuel Pump
    HDi Digital Boost Controller
    Innovate LC-1 Wideband
    6-Speed 02M w/ Peloquin LSD
    Lightened Flywheel
    I haven't dyno'd it yet so nothing on that end, still need to work out some of the kinks!
    ** VW/Audi Mechanic - Mods, Maintenance, etc. - Reasonable Rates - PM for Info **
    91 GTI ABA Turbo Build Thread
    G Guitars - Effects Pedals for the Masses!
  30. Junior Member 8-VALVER's Avatar
    Jan 11th, 2012
    Cape Town, South-Africa
    2003 MK1 CITI GOLF, Land Rover Disco 2 4.0l V8
    04-01-2012 02:08 PM #135
    Its not quite finished yet but the idea is there.
    Stock ADY block bored to 83.5mm
    APK head with lots of work. Especially on the exhaust side.
    Custom larger forged billet stainless valves.
    Standad APK inlet manifold
    ARP rod bolts
    Hydro-HP water and meth injection
    Fidanza Aluminum fly wheel
    CutchNet pressure plate
    VR clutch plate
    83.5mm NURAL KOMBI pistons puts CR at +- 8.2:1
    t4 dash 2 turbine wheel in a t3 housing
    t60-1 ar.50
    Xcell DV
    Turbo mani and exhaust system as well as boost pipes made by myself
    NO NAME inter-cooler
    Chinese waste-gate 38mm
    DICKTATOR management
    440cc RC Engineering injectors
    S-MAX rising rate fuel regulator
    CTI fuels pump
    Stock ADY cam.
    Custom 3 core full aluminum radiator.
    AIR to OIL cooler
    Tranny
    G4 gti box with mk2 16v slave and vr6 master.
    EIBACH 35mm drop with front and rear anti roll bars and strut braces.
    Hoping for around 270whp
    8vT 187kW 361Nm
  31. Member jettatech's Avatar
    Oct 25th, 2001
    NJ
    85 ABAT,10 CCTA Tigger
    04-01-2012 02:51 PM #136
    brake booster and wipers have me all confused... hahah
  32. Junior Member 8-VALVER's Avatar
    Jan 11th, 2012
    04-02-2012 06:51 AM #137
    Please explain.
    8vT 187kW 361Nm
  33. Member
    Dec 14th, 2001
    Greensburg, PA
    04-02-2012 09:57 AM #138
    Quote Originally Posted by 8-VALVER View Post
    Please explain.
    He was confused by the right-hand-drive configuration when first looking at your photos.
    Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
  34. Junior Member 8-VALVER's Avatar
    Jan 11th, 2012
    04-02-2012 04:50 PM #139
    Cool beans. He sent me a pm.
    8vT 187kW 361Nm
  35. Member
    Sep 20th, 2004
    se pdx
    87abat drag gti, 95 jetta beater
    04-18-2012 01:04 AM #140
    got mine on the dyno this last weekend in slc utah, elevation 4200 ft nice cool day around 70 in the shop.
    running
    duel headgaskets with arp studs, stock bottom end obd1 aba
    stock aba obd1 head with mild port to exhaust side, and tt 268 cam, and short runner intake with phenolic gasket.
    t3t4 .57trim
    full custom 3 in exhaust with cat and straight threw flow master muffler
    full 3in intake, awic with vr after run pump along with radiator running washer fluid threw it to help cool it.
    running c2 #44 point obd1 tune. with 4 bar fpr
    ran at 20 psi,
    pulled 260 hp and 272 tq, fuel trims were a little low at full boost they sat at 11 to 1 at full boost i would like to see them around 12-12.5.
    i did just move to portland oregon the day after and car feels much much stronger im pretty sure the more air helped fuel trims, im wanting to dyno it here now.
    also wondering if stock bottom end and stacked head gaskets will handle 23-25 psi just at the strip to get me over 300 whp.
