VWVortex.com - turbo flutter/surge
    Results 1 to 23 of 23
    Thread: turbo flutter/surge
    1. 01-21-2009 02:31 PM #1
      my GTI has turbo flutter, surge what ever you wanna call it, i know its not good for the turbo i was told that the Forge DV would fix the problem but it has not, does anyone know how to fix this problem??
      i have a mkv gti so far it has a custom cat back exhaust, GIAC chip, EVOMS cold air intake, PCV block off, and a forge DV (the one that replaces the OEM unit
      Modified by ryangti at 1:13 PM 1-31-2009
    2. 01-21-2009 02:35 PM #2
      Check to make sure that the cap on the Forge Dv is tight. I ran into a ton of flutter when the cap was just a tiny bit loose. Thanks to the boys at forge it is all fixed!
    3. 01-21-2009 02:42 PM #3
      Quote, originally posted by ryangti »
      i have a mkv gti so far it has a custom cat back exhaust, GIAC chip, EVOMS cold air intake, PCV block off, and a forge DV (the one that replaces the OEM unit.
      What does turbo surge feel like?
      Sold the VAG COM
    4. 01-21-2009 07:39 PM #4
      it doesnt feel like anything idk if turbo flutter is the same as surge but when i give it gas and let off some times it makes a noise like, cha cha cha cha. ive seen vids on youtube where people have the same problems. im just not trying to fry my K03 the car only has 9,000 miles on it
    5. Awaiting Email Confirmation mrbikle's Avatar
      Jul 2nd, 2005
      Hagerstown, MD
      current: 09 CTSV 1khp, 15 passat SE past: 06 GTI and Jetta BT, 95 BMW 740i
      01-21-2009 08:24 PM #5
      mine does it too, only very light throttle
    6. 01-21-2009 09:49 PM #6
      so whats the fix for it??? i just took my car out for a little bit and it seems like its starting to do it more, it all started after i put the evoms intake on. what do you have done to yours?
    7. 01-22-2009 09:07 AM #7
      You may just be hearing the DV - actual turbo flutter sounds violent and nasty. How long has the Forge DV been on your car? Do you have a boost gauge?
    8. 01-22-2009 10:59 AM #8
      I think its our intakes in the cold weather...... I guess im going to put the OEM Intake back on soon and see if that helps
    9. Member zoidmk5's Avatar
      Sep 16th, 2006
      SoMD
      4.6L 44V 10 Cylinder Turbo
      01-22-2009 11:19 AM #9
      that cha cha cha cha noise is normal. it is just the intake
      ***PM me for VAGCOM services, parts installs and repair, and light fabrication work in the SOMD/VA area***
      Quote Originally Posted by lugnuts View Post
      And I'm just letting you know that you don't know entirely what you are talking about.
    10. 01-22-2009 04:46 PM #10
      yea its been doing it since i put the intake on, its getting on my nerves cause nobody seems to know how to fix it, i turned off my chip the other day to see if it still did it as much and it did. idk
    11. 01-22-2009 04:48 PM #11
      i just got the DV put on like a week ago, i was told that it would fix the problem but it didnt big waste of 250 bucks
    12. 01-22-2009 04:50 PM #12
      yea well i tore my apart getting it off and now the silver part is hanging on my wall. as a freaking ornament.
    13. Member
      Aug 20th, 2008
      07' BMP GTI / 10' DGM STI 400awhp on 93oct and counting!
      01-22-2009 04:54 PM #13
      Quote, originally posted by zoidmk5 »
      Perks of having the loudest intake on the market. Its actually louder then my BOV
      But yes OP the sound is normal
    14. Member gefunden's Avatar
      Jan 18th, 2009
      Long Island
      2012 LC9X GTI / 2016 PGM Jetta 1.4T / 86 Scirocco PARTING! / 80 Scirocco S
      01-22-2009 08:43 PM #14
      Is it your DV that is making the repetitive fluttering sound coming through your intake? If so, it may be your MAF that is busted as well. Dealer replaced mine under warranty when I was having the same problems as described. Flutter is not normal. GL.
      http://forums.vwvortex.com/zerothread?id=3812168
    15. 01-22-2009 09:46 PM #15
      that sounds like a likely reason because the sound IS coming from my intake but i highly doubt the dealer will cover me under any warrantee since my car is modified. how did you pull it off?
    16. Member gefunden's Avatar
      Jan 18th, 2009
      Long Island
      01-23-2009 07:24 PM #16
      Just brought it in and said my car is making a funny sound. Had a stored fault code on it too I guess. So they looked into it and just replaced them both. Plus the car just felt slow too.
    17. 01-24-2009 10:39 AM #17
      id take mine to the dealer but i cant stand the one by my house
    18. Member Dub Ken's Avatar
      Dec 24th, 2004
      Vail, CO
      '03 VW 20th Anniv. GTI
      01-31-2009 12:56 PM #18
      The excess boost is being released into your intake via the DV, and there's some sound reverberation. What's the problem here? Most people love the noise.
    19. 01-31-2009 04:12 PM #19
      aha!! finally someone gives me a logical answer that makes perfect sense! now my mind is at ease. thanks
      oh and yes i do like the noise. sounds like an external waste gate. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 12-24-2010 01:46 AM #20
      Quote Originally Posted by gefunden View Post
      hey what do you mean by replaced them both??? my 98 a4 had bad flutter and my stock dv nor the aftermarket bov i installed will blow off instead i just get crazy flutter wich at first some might hear as slight bov action but no its the cha cha cha sound im stuck
    21. Member
      Aug 26th, 2009
      so cal
      12-28-2010 12:01 AM #21
      this thread is pretty old,
      but im barely experiencing this myself.
      i did a google search and it brought me to this thread.
      well i am experiencing this flutter/surging on my 1.8t gti.
      never had that fluttering noise on my last 1.8t,
      but on my current one, its fluttering.
      it started to flutter right after i chipped it.
      then i installed a CAI, forge turbo inlet and a samco DV, and its still fluttering.
      im not sure whether the noise is harmless or if its a problem.
      i searched and read that someone had success solving the fluttering by replacing the PCV (positive crank ventilation)
      now im trying to learn how the PCV works,
      and how i would fix that if its blown or whatever
    22. 12-28-2010 02:41 AM #22
      im going to check into that again thanks for the info as many people decide to view and not post and most of them have seen and know whats wrong but decide not to share
    23. Member
      Mar 26th, 2009
      Lancaster Pa
      08 A4 3.2 S-line 03 JB 20th 00 Passat wagon
      12-28-2010 05:35 PM #23
      this post is irrelevant to the topic and is for aknickintyme I recieved the ECU and have not been able to PM you back. Your inbox is full!
