i gotta say your front motor mount is pretty narly, nice work cant wait to see this thing done.![]()
#71
Just got my hands on a pair of adapters for 256 mm. rear discs for Syncro, fit S3/TT Quattro/R32 discs and calipers. They're not a shelf item but a prototype.
#72
Drive a VW they said, it'll be fun they said...
#73
those brackets are wicked , nice work. With that rotor size the 4 bolt guys might be able to use that bracket with a 256x20 mm MKIII 2.0L ft rotor, but I guess offset will be wrong . spacer on bracket maybe? very cool.
#74
#75
I'd like to see the clearance between trans. mounting cup and axle, with your axles installed. I've installed an o2m in my car, I did the cup relocation when I had stock 02m axles. Since I replaced the axles with ones that have a large inner end the clearance is f*cking tight !
