when you say "they" you mean? try another diagnostic device.
#1
When they plug into the car it say error it will not pull the code.
I dont know what to do sometimes the check engine light is on and sometimes its not. Is there some fuse that could make the port not work or something please help me thanks![]()
#2
#3
i took it to two different parts store and they said it is not connecting to the computer
#4
Check the fuse for ur cig lighter, it runs the dlc as well.
#5
ok i will check the cig fuse good isea bc my cig doesnt work
#6
Checked all fuses cant really check the big block fuses all fuses were good any other advice how do i make it flash codes i plug a paper clip into 4/15 and no flash![]()
#7
parts store only have obd2 scanners try a repair shop
#8
Quote » parts store only have obd2 scanners try a repair shop This would be my guess as well, an OBD-II scanner will not work on a 1995 you need to go to a dealer, a VW shop, or use VAG-COM which will be able to read the codes.
#9
i think your right guys i will try to take it to a repair shop do you how how to make it flash the code
#10
Pull your radio and check if you have a radio wiring harness (Metra, Scosche etc.).On the black connector, find pin 3, this a Blue wire, but may be Blue/white.
This is usually attached to pin1, cut the wire on the aftermarket harness and tape/ crimp a cap on.
The original Dub and Dubber.
Manche VWs sind einfach schneller als andere.
#11
Quote, originally posted by Nasia18 » ok i will check the cig fuse good isea bc my cig doesnt work Well let's go a little further. If the diagnostic link connector doesn't have power you will not be able to blink codes, because it has no power! Like I said, the power for it runs off the cig fuse. Find which fuse it is and replace it! You take it to a shop and they will most likely charge you too much to replace a fuse. Trust me, I work at a shop and see this happen too much!
Fuse position 22, pull it and replace it, 10amp
Modified by NoVAslc at 7:05 PM 1-25-2009
#12
i checked it and replaced it and it is good i am gonna try and remove the connector 3 wire![]()
#13
this is behind the cd player
#14
those BS parts-store scanners don't read 95 VW's even though you have an OBD2-style connector.You have to use a proper vagcom diagnostic tool & software. Post a thread in your regional forum asking to borrow one and I'm sure there will be people who can help you out.
Follow my MK1 build on Instagram. User name: jkrew or http://ink361.com/#/users/322773/photos
#15
oops reading>me
Modified by Roosky at 9:44 PM 1-25-2009
#16
the 95 jetta is hopeless right now. i plug the jumper in and it resets the CEL light every time i did it correct it treats me so bad right now![]()
#17
You are going to need to check for power and your going the worng way about it..http://forums.vwvortex.com/zerothread?id=3976902
At the end of the plug #16 is power take a test light and see if you get power. Make sure you get ground as well. Then if you are, check behind the fuse box that this wire is connected, its the yellow and gray wire..
#18
i need some help wanna wire the power source to the rear defroster what wire is hot on the defroster![]()
#19
When you push your deforst button does it light up????? And whats going on with obd data link do you get that sorted?????
#20
defroster button works well my friends![]()
#21
On the side of your rear glass will be to clips one on the left side and one on the right test them and see if you have power.....Whats going on with the data link do you see if it is getting power...
Modified by brian500 at 9:06 PM 1-26-2009
#22
well thats all thats left when they plugged into it. with there machine it did flash so i think it isnt getting power bc the cigarette lighter isnt working![]()
#23
keep in mind that obd data link powers up the scanner. Listen just stick a test light at the of the obd port slot 16 im tellin you have power....
#24
ok i will get a tester light tommorrow and see if it has power for sure. but the cig lighter doesnt work and i think it powers the obd tool as well![]()
#25
#26
tested the little sum b#$%^ and guess what it is getting power very nice why must the vw wanna end my life![]()
#27
Now you need to check behind the fuse box to see if the k line is connected...
#28
I wanna thank everyone for there help. Eric D you are a good vw friend. I am such a noob all i had to do is have the car running to check the engine codes![]()
1 week and 5 days later car was pulling code 2113. This code really doesnt affect the drive quality so screw it hehe
#29
Glad I could help via IM.Lots of info back and forth.
Now you have to tools and info for any future issue.
That is what we do here, help others out.
#30
how about putting the answer to your problem here so it will help somebody else with a 95![]()
"Public transportation......because you're poor"
done everything that's cheap....broke the most expensive parts....
having cooling problems? check this out http://the-corrado.net/forum/viewtopic.php?f=1&t=68720
#31
Quote, originally posted by ricardo » how about putting the answer to your problem here so it will help somebody else with a 95 ![]()
It says 2.5 seconds, but do it for 5 seconds.
http://www.gti-vr6.net/library....html
#32
yes also make sure the car is running when you try to pull the codes![]()
#33
I'm having a similar problem, can't get the cel code(s). I have power in the cig plug, but none on plug 16. I originally thought I couldn't get them because I've read that if you have an aftermarket radio, it wasn't doable. Do I need to check behind the fuse panel, and where would I look? oh, also, it's a obd1 2.0. but this is the closest thread I could find about the problem I have.
Modified by Tyrian at 6:42 PM 2-21-2009
#34
guys look in the bently 95s dont have k-wires its only 97's and up.
#35
but I should still be able to get a cel code shouldn't I?
