Page 256 of 432 FirstFirst ... 156 206 246 252 253 254 255 256 257 258 259 260 266 306 356 ... LastLast
Results 8,926 to 8,960 of 15116
Thread: Eau Claire, Chippewa Falls, W.Central Wisconsin Unite
  1. Member Gyntry's Avatar
    Nov 17th, 2009
    EauC, Wisconsin
    '12 Golf R
    02-01-2012 12:13 PM #8926
    Quote Originally Posted by clarkson View Post
    Cleared all codes last night but no codes ever come back... It won't give me anything! I even tried causing a code by unplugging the cts... Then the cts code popped up but that's all... The car doesn't think anything is wrong
    Computer hosed? FYI - I don't know sh!t about fixing cars, just a shot in the dark.
    edit: ooo, a page to pwn. Taking the easy road and quoting previous post by a new R owner (jonkerns). His driveway now:
    [/QUOTE]
    ClearWaterDubs Web -- CWD on Vortex
    2012 CW 4Dr Golf R - | APR Stage 2+ (93) | APR HPFP | Scorpion TBE | DXD Stg2 Endur Clutch | EVOMS V-Flow | BSH PCV Fix | Diesel Geek SS | HPA Dogbone |
    | NewSouth Boost Gauge | H&R FSB | H&R Sport Springs | Bistein Sport Rear Struts | LED Tails | Misc "Moar Better" Mods |
  2. Member GTIsteffen98's Avatar
    Jun 16th, 2011
    Chippy Waffles, WI
    '01 Jetta GLS (susy) '98 GTI VR6 (Lucy)
    02-01-2012 12:27 PM #8927
    Quote Originally Posted by keegers View Post
    ordering the extension today!!!!
    Finally realized what he needs to do to get the ladies. Sorry that was lame. Two hours of sleep and 3 red bulls dont help either.
    Clear Water Dubs VWvortex
    Clear Water Dubs Website
    |42 DD 3" downpipe|BFI stage 2 dogbone mount|TT short shift kit|ECS stage 2 clutch kit|
    |IE goodies|Poly bushings all around|Unitronics stage 2 tune|
  3. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    02-01-2012 12:30 PM #8928
    going with a speedtech?
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  4. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 01:01 PM #8929
    Props to progress!
    Growing old is mandatory - Growing up is optional
    -ClearWaterDubs- ~~~Good judgment comes from experience and experience comes from bad judgment!!!~~~
  5. Member keegers's Avatar
    Jun 20th, 2011
    Chippewa Falls
    2003 VW Jetta GLI
    02-01-2012 01:11 PM #8930
    Quote Originally Posted by Clean PG View Post
    Yes sir!
  6. Member keegers's Avatar
    Jun 20th, 2011
    Chippewa Falls
    2003 VW Jetta GLI
    02-01-2012 01:32 PM #8931
    Photobucket Pictures, Images and Photos
    Eric found the video of his mom and Ryan....
  7. Member Gyntry's Avatar
    Nov 17th, 2009
    EauC, Wisconsin
    '12 Golf R
    02-01-2012 02:20 PM #8932
    Owned.
  8. Member keegers's Avatar
    Jun 20th, 2011
    Chippewa Falls
    2003 VW Jetta GLI
    02-01-2012 02:52 PM #8933
    "DAMN DUDE! Why does keegan's car look so fricken sexy!"
  9. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 04:16 PM #8934
  10. Member SpoonerS's Avatar
    Jan 28th, 2011
    Chippewa Falls
    MK4 .:R32
    02-01-2012 06:33 PM #8935
    Guys, I'm looking for affordable low. Can a brotha get a little help?
    Clear Water Dubs
  11. Member keegers's Avatar
    Jun 20th, 2011
    Chippewa Falls
    2003 VW Jetta GLI
    02-01-2012 08:07 PM #8936
    Quote Originally Posted by SpoonerS View Post
    It depends on what you're definition of cheap is
    1.) coils from raceland are $360 last time I check for my car
    2.) go to menards or farm and fleet and load your trunk with bags of sand around $50 I would guess
  12. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 08:21 PM #8937
    Rechecked timing and unplugged MAF. Also changed cam position sensor. Sill no luck. Plugged MAF back in and still no luck. Getting frustrated... Also added another 5 gallons of gas just in case it was to low. Anybody have an idea?
  13. Member Soup Guy's Avatar
    Jul 5th, 2002
    earth
    02-01-2012 08:29 PM #8938
    Quote Originally Posted by zwiefe View Post
    I have nothing to do with this... We should blame @Joel Riley. Ohhhhh WAIT! This isn't facebook.
    *thumbs nose and returns to the shadows to lurk*
  14. Member Soup Guy's Avatar
    Jul 5th, 2002
    earth
    02-01-2012 08:31 PM #8939
    @ Tyler, does it backfire or anything at all like that when it's cranking?
  15. Member SpoonerS's Avatar
    Jan 28th, 2011
    Chippewa Falls
    MK4 .:R32
    02-01-2012 08:35 PM #8940
    While this is really funny, I asked for help from the guys...
    And for the record, affordable and cheap are not to same thing in the auto parts world.
    Clear Water Dubs
  16. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 08:36 PM #8941
    occasionally it sounds like intake pop but i could be hearing things
  17. Member SB_GLI's Avatar
    Oct 17th, 2005
    Stevens Point, WI
    10 Wolfsburg Tiguan, 04.5 TR GLI, 90 Cabriolet
    02-01-2012 08:36 PM #8942
    So you're saying you have spark correct? And you've done a compression check. Is it getting fuel? Make sure the fuel pump is working. Jump the battery to the fuse for the pump and listen for the pump.
  18. Member keegers's Avatar
    Jun 20th, 2011
    Chippewa Falls
    2003 VW Jetta GLI
    02-01-2012 08:39 PM #8943
    its car care day for this guy
    spark plugs
    fresh oil and filter
    sea foam injector cleaner
    it got pretty expensive, wasnt planning on spending $100+ today
    my car better not break down like erics and tylers jetta
  19. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 08:45 PM #8944
    I can hear the pump when I turn the key the first time but if I turn the key off and back on it does not kick on (idk if that wrong or working correctly) but i can hear it when trying to start the car. Im getting around 38psi of pressure when i "t" in my fuel pressure gauge at the end of the fuel rail. I pulled the coil pack off the plug removed the plug and inserted it into the end of the coil pack and set that by the cowl. i then got in the car and cranked the key and it sparks at the plug. i set up all four coil and plugs the same way and they all spark seamingly in proper firing order but i could be wrong
    also when i pull the plugs they are soaked and the tops of the pistons are wet
  20. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:01 PM #8945
    I still think its related to you crank position sensor down by the oil cooler.. You need to find out what pins on the ecu are for the sensor and ohm them out to make sure that you have continuity down the whole wire path to make sure you don't have any more breaks...
    Did you actually replace the sensor or how did you test it????
    Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTS Clear Water Dubs
  21. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 09:07 PM #8946
    New sensor... purchased last night fronm advance auto parts
  22. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:07 PM #8947
    But that was the sensor that had a broken wire correct???
  23. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 09:10 PM #8948
    Correct... the sensor side of the connector had a probobly 2mm cut into the insulate around the 3 wires and one wire was cut in half
  24. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:14 PM #8949
    Maybe run through all the fuses and make sure there good, maybe the wire that was rubbed threw grounded the circuit out or something????? It sounds like you have all your bases covered as far as checks to do, and you already replaced alot of parts so I don't know what it could be... I'll keep thinking but if its possible to find the pin #'s and ohm stuff out that would be a good idea
  25. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 09:17 PM #8950
    Checked all fuses last night and i agree with you in the "pin out" ohm tests. I just wish i had a starting place to start checking
  26. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:18 PM #8951
    Does your TACH move when you crank the car over???
  27. Member uNLeaSHeD.'s Avatar
    Aug 28th, 2010
    A Ditch in Wisconsin
    Bagged B5.5, MKV Jetta
    02-01-2012 09:19 PM #8952
    FK streetline are pretty nice, they run like 450 maybe a little more. They can go super low and I personally haven't had any issues with mine and I have had them on for almost a year.
  28. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 09:20 PM #8953
    Quote Originally Posted by One-Eight GTI View Post
    Yes
  29. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:21 PM #8954
    What engine code are you, I have my bently handy
  30. Member clarkson's Avatar
    May 1st, 2009
    Eau Claire WI
    01 Wolfsburg on air
    02-01-2012 09:25 PM #8955
    aww and if it helps my cell number is 7158675309 and it will stay that way for about 5 min
  31. Member uNLeaSHeD.'s Avatar
    Aug 28th, 2010
    02-01-2012 09:27 PM #8956
    Spooner also check the Midwest classified I notice some guy was selling fks and koni
  32. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:30 PM #8957
    ok well there are 3 wires... brown white and black... remove the smaller of the two connectors on the ECU and that is your engine bay side... Find pin 82 which is white and ohm from that wire to the white wire on the connector feeding the CPS.... Then pin 90 is the brown wire do the same... then put ohm meter on theblack wire at the end of connector and go to ground, you should have cont
  33. Member SpoonerS's Avatar
    Jan 28th, 2011
    Chippewa Falls
    MK4 .:R32
    02-01-2012 09:35 PM #8958
    Quote Originally Posted by uNLeaSHeD. View Post
    I'll check it out. Thanks!
    Clear Water Dubs
  34. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    02-01-2012 09:36 PM #8959
    No luck trying to call you
  35. Member keegers's Avatar
    Jun 20th, 2011
    Chippewa Falls
    2003 VW Jetta GLI
    02-01-2012 10:25 PM #8960
    Sorry I don't know your financial situation Sam... Jeez take a joke.
    And thanks for informing me I'm not a guy??
    Real mature
