VWVortex.com - HELP! Cylinder 1 Misfire on 02 Jetta
    Results 1 to 6 of 6
    Thread: HELP! Cylinder 1 Misfire on 02 Jetta
    1. 01-25-2009 10:36 PM #1
      Hello all,
      Today I started up my jetta (automatic, AZG engine) and it idled extremely rough. The check engine light came on within the first minute and started blinking. It then changed from a blinking light toa solid light. That prompted me to have it scanned at AutoZone where i got this code: P0301: Cylinder 1 Misfire. The car has 84k on it. What's going on? What can I do to fix it?
      BTW...the car ran out of gas one this summer due to a mass area shortage, and this morning the car's gas light was on (I was going to fill it up).
    2. 01-25-2009 10:39 PM #2
      Was it raining? Could be a bad plug, wire, coil pack. Do you know the mileage on the current plugs/wires?
      The running out of gas issue would not have caused this.
      Modified by jdl2001 at 7:40 PM 1-25-2009
    3. 01-25-2009 10:43 PM #3
      Nah...it wasn't raining. I had the plugs done at 40k. I also notice that sometimes the car sputters when I get off the freeway as well, and the RPMs jump a little....does this make it a little more specific?
    4. 01-25-2009 11:05 PM #4
      if it is one cylinder only it will not be your coilpack. DO NOT REPLACE IT. check you plugs and your plug wires, just because you changed them doesnt mean they cant be bad, would you rather find out its a plug that you just changed now or after you spend $300.
      Modified by Mr.Pickles at 8:06 PM 1-25-2009
    5. 01-25-2009 11:21 PM #5
      Thanks! Can I change these plugs and wires myself if I buy them from the VW dealer? If so, what tools do I need for the process? I'd rather change them all.
    6. Member
      Jul 31st, 2002
      '74 Bug (yard), '96 Jetta 255K (yard), '02 Cabrio 104K (sold), '06 Rabbit 127K BGP, '08 Jetta 55K
      01-26-2009 07:14 PM #6
      What plugs were put in it 40K ago. I'd start with the plugs. Use the OEM plug. Be gentle removing and replacing the wires. You'll need a 3/8" ratchet, the correct spark plug socket, and a 6" extension. Search about pulling plug wires without the "special tool."
      http://forums.vwvortex.com/zerothread?id=1931981
      ^That might help.^
      Modified by FL 2.0L at 7:17 PM 1-26-2009
