Page 5 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 684
Thread: Ford Coil Pack on VR6 with Pics.
  1. Member XMB's Avatar
    Apr 9th, 2008
    Wisconsin
    1996 VRT Passat Wagon
    10-14-2009 08:54 PM #141
    make sure the wires from the ICM go to the correct ones to the coil pack, I had this problem after taking a closer look at the wiring I had 2/3 and 4/5 switched.
    Good Luck.
  2. Member manfredwerner's Avatar
    Jan 29th, 2007
    staten island/brooklyn
    all gone, looking for another one
    10-15-2009 12:52 PM #142
    Quote, originally posted by Eric D »
    How about the 2001-03 Windstar coil pack?
    Looks like the coil towers might fit with the VR6 wire ends.
    Here is a Windstar wireset. Looks like Bremi/Beru etc ends, but I can't really tell from the small pic.
    i got all the parts for coil repair with exactly this kind of coil from a mustang 3.8l. i hope this will work out.
  3. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    Mk3 VRT, Mk4 VRT, Mk4 VR
    10-16-2009 09:46 AM #143
    I love coilpack threads.
    "OP sounds like a MKIV guy"
  4. 10-16-2009 10:23 AM #144
    Quote, originally posted by manfredwerner »
    Keep us informed on this coil. Should work, I was looking at one the other day, and all you would have to do is cut the connection point on the coil down to match a VR6 coil , hoop up the wires like said before and you should be set. Now for mounting you might have to get creative.
    "I admit that I'm often...vexed by the behavior of my own people..." - Huey Freeman (The Boondocks)
  5. Member manfredwerner's Avatar
    Jan 29th, 2007
    10-16-2009 10:16 PM #145
    I did this conversion today! this is the best thing i did to my b4! this coil came of a 2003 mustang, 3.8l. the plugs for the coil fit right on, no trimming of the towers was needed, i didn't have to swap the ends! but don't forget to lube the towers with special grease. the order of the firing is the same as in the old style coil in the beginning of the post. the coil cost me 35 with pigtale and the ign wires shipped of the junkyard. GL!
    here http://www.car-part.com
    Modified by manfredwerner at 10:36 PM 10-16-2009
  6. Junior Member oggenator's Avatar
    Sep 21st, 2008
    South Shore, MA
    01 VR6 Jetta, 81 Tdi rabbit
    10-17-2009 01:44 PM #146
    Quote, originally posted by zcalibur »
    I've been looking at options.
    I think i'm going to build new wires, custom length because i don't want to take a chance with a set.
    http://www.autopartsway.com/au...40801
    http://www.boostengineering.ne...r.htm
    http://www.summitracing.com/parts/TAY-35281/
    If you don't like that wire, many other options.
    http://www.summitracing.com/se...Wire/
    If anyone finds any other options or better prices.
    Post it and give us all the benefit please.
    Modified by zcalibur at 10:07 AM 9-28-2009
    Modified by zcalibur at 10:20 AM 9-28-2009
    I picked up the wires and ends for my 'build.' i got a duralast c925 coil for it. has anyone else done this in a mk4? not looking for advice, just curious. hopefully this will be done today and i can drive my car around.....in the rain! ill keep you guys posted
  7. Member jmaddocks's Avatar
    Jan 31st, 2004
    SOMD
    91 Corrado 16vt, 97 Lexus LX450, 11 Subaru LGT, 89 Jetta 1.6d
    10-17-2009 02:24 PM #147
    OEM coil pack died yesterday after a long trip in the rain. Just did this swap w/ a coil from an Explorer. Incidentally, there were a ton of pristine ones in the salvage yard from the Cash for Clunkers program, so finding a coil was a piece of cake.
    I can't remember the last time my B4 Passat ran this smoothly. Thanks for the write up!.
  8. Member piran21's Avatar
    Jul 28th, 2004
    GTA
    BRM, LS1
    10-19-2009 09:19 AM #148
    This conversion is quite straight forward... makes a lot of sense. Why bother with the MSD and/or stock issues?
    On another note,
    What spark plug are you guys using with this setup? If any other than stock NGK's.
    Modified by piran21 at 2:03 PM 10-19-2009
    P
    GTADeal.ca
    your one stop for group deals of the day
  9. Member ricardo's Avatar
    Feb 19th, 1999
    CA Bay Area
    1995 mulberry GTi VR6 RIP, 1988 BMW E30 SETA, 2004 A4 B6
    10-19-2009 06:35 PM #149
    I believe mine are autolite (champion?) 3923
    "Public transportation......because you're poor"
    done everything that's cheap....broke the most expensive parts....
    having cooling problems? check this out http://the-corrado.net/forum/viewtopic.php?f=1&t=68720
  10. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    96 GTI VR6 08 Hyundai Santa Fe SE
    10-19-2009 08:18 PM #150
    I would still like too see someone compare the stock coils voltage output vs this setup. No one has a spark plug voltage tester?
    98 GTI - Mustard Mayhem - 1/4 - 11.679@117.58mph - .8 bar - parted Timeslip
    96 GTI - Turbo Panda - 1/8 - 7.63@97mph - 1.1 bar of turbo fun!
    89 325is - New turbo project
    www.lugtronic.com
  11. 10-19-2009 10:24 PM #151
    Its good to know the newer ford version works.
  12. Member manfredwerner's Avatar
    Jan 29th, 2007
    10-20-2009 10:46 PM #152
    ttt
  13. Member piran21's Avatar
    Jul 28th, 2004
    GTA
    BRM, LS1
    10-21-2009 09:34 AM #153
    Quote, originally posted by ricardo »
    gapped at what?
    P
    GTADeal.ca
  14. Member UmbroVR6's Avatar
    May 23rd, 2000
    Miami, FL.
    98 GTI VR6, 01 Jetta 1.8T
    10-21-2009 10:13 AM #154
    i bought a set of ngk bkr5e, but dont know what to gap them at now.
    i used to gap these at like .28 and had great results w/ oem coilpack.
    i think they come at .35 out of the box.
    LEASE THIS SPACE
  15. 10-23-2009 12:12 PM #155
    Quote, originally posted by UmbroVR6 »
    I gapped two different cars with the ford coilpack @ .028" w/o any problems. But I see you might have a problem if you gap them @ .28"
  16. Member UmbroVR6's Avatar
    May 23rd, 2000
    Miami, FL.
    10-23-2009 05:17 PM #156
    Quote, originally posted by Nevaeh_Speed »
    yeah, i meant .028"
    LEASE THIS SPACE
  17. Member ricardo's Avatar
    Feb 19th, 1999
    CA Bay Area
    10-24-2009 11:00 PM #157
    Quote, originally posted by piran21 »
    gapped at what?
    stock gap .028
  18. 10-27-2009 10:57 AM #158
    Probably a stupid question, but did you re-use the stock VW plug wires, or did you you Ford wires? If you used Ford wires, what year/make/model did you use? Sorry for my stupid question, I just want to make one stop for parts.
  19. Member ricardo's Avatar
    Feb 19th, 1999
    CA Bay Area
    10-27-2009 02:36 PM #159
    since I had to change sparkplugs I gapped them at .033 and they work great... Ford guys gapped them at 0.42 so technically so can we?
  20. Member UmbroVR6's Avatar
    May 23rd, 2000
    Miami, FL.
    10-28-2009 11:22 AM #160
    thats what i meant, that we no longer have to gap at .028
    thanks for the insight, i'm gonna gap them at .033 as well or leave them at their out of the box gap.
    LEASE THIS SPACE
  21. 10-28-2009 05:47 PM #161
    Quote, originally posted by slefain »
    Stock wires converted to ford ends on the coil pack side... It's a Hybrid wire...
    Unless you go with the new ford style coil pack pictured above...
  22. Member bent_metal's Avatar
    Feb 17th, 2009
    92 gti monty green
    10-29-2009 02:19 PM #162
    still have some of these set ups for sale if any body is intrested
  23. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    10-31-2009 01:38 AM #163
    Quote, originally posted by bent_metal »
    you got IM, eh?
    Quote Originally Posted by Arin@APR
    I'm outta here... you guys are idiots. You can quote me on that and throw it in all of your sigs.
  24. Member SR-71's Avatar
    Mar 31st, 2004
    Vancouver, BC
    B5, 8P
    11-13-2009 01:59 PM #164
    NICE!
    Modified by SR-71 at 5:32 PM 11-15-2009
  25. 11-18-2009 05:14 PM #165
    Funny you did the Ford coilpack. We were actually going to use this back in the day .. but decided to blow it out of the water and do something that had never been done. When we orig. put the MSD boxes in with the individual coils ... they blew. MSD never even ran the type of setup we had. They replaced our boxes, and we tweek some things. I like this setup you have, its marketable, and easy. I guess I should have patented JBE's idea back in the day. DOH! Good Luck.
  26. Banned nobody...'s Avatar
    Jul 17th, 2009
    98 gti vr6 daily (RIP), 89 gti vr6 project car, 99 B5 Passat 1.8T daily
    11-18-2009 06:39 PM #166
    very cool thread
  27. Member ricardo's Avatar
    Feb 19th, 1999
    CA Bay Area
    11-18-2009 07:45 PM #167
    Quote, originally posted by nobody... »
    very cool thread
    yeah and we are not having trouble blowing up the coils like in the MSD forum
  28. Member Rob@Darkside's Avatar
    Mar 12th, 2008
    Edmonton, AB.
    97 VEEARRTEE
    11-18-2009 09:50 PM #168
    Did this on my vrt and it works flawlessly. I would recommend it to anyone.
    Rob
    I'm so euro my last name is " .de"
  29. Banned nobody...'s Avatar
    Jul 17th, 2009
    11-19-2009 01:11 AM #169
    i asked the same question of him over PM and he says yes on the VW wires
  30. Member Rob@Darkside's Avatar
    Mar 12th, 2008
    Edmonton, AB.
    97 VEEARRTEE
    11-19-2009 01:22 AM #170
    What I did was get a set of wires off of a ford thunderbird at the wreckers just for the ends that attach to the coil....you have to remove the ends off of the vr6 wires that attach to the coil and then put these ford ones on. very easy. Just take your time. I basically cut the vr end off to keep it as long as possible, cut back the insulation about .5 inch being careful not to cut into the conductor strand...then you remove the end from the ford wire, cut pry, pry, pry and then it popps off and then you install it. Pay special attention to how it attaches to the ford wire and how the conductor strip is running and just do it the same way. make sure you slide the bracket and boot over first before you finish it cause it wont slide past once you get the 90 degree connector mounted, trust me.
    Anybody with questions can IM me
  31. 11-19-2009 12:55 PM #171
    Went with this set . Works great. Upgraded wires at a fraction of the cost.
    Brand Mallory Ignition
    Manufacturer's Part Number 776
    Part Type Spark Plug Wire Sets
    Product Line Mallory Pro Wire Spark Plug Wire Sets
    Summit Racing Part Number MAA-776
    Assembled No
    Diameter (mm) 8.00mm
    RFI Suppression Yes
    Wire Color Black
    Distributor Terminal Ends Female/Socket
    Distributor Boot Color Black
    Distributor Boot Material Silicone
    Spark Plug Boot Ends Eight straight
    Spark Plug Boot Color Red
    Spark Plug Boot Material Silicone
    Coil Wire Included Yes
    Conductor Style Spiro-wound
    Quantity Sold as a set.
    Modified by Nevaeh_Speed at 1:00 PM 12-8-2009
  32. Member Boost112's Avatar
    May 7th, 2002
    Miami/ Orlando
    1995 VW : 2010 VW : 2013 VW
    11-19-2009 01:25 PM #172
    but they dont have the same ends as the ford edis... could you just get a set of junk ford wires and cut those ends off and attach them to these wires to get a better custom fit?
    --- SPACE FOR RENT---
    Quote Originally Posted by schwartzmagic View Post
    Those VRTs are so full of win :-D
    www.dubcartel.net
  33. Banned nobody...'s Avatar
    Jul 17th, 2009
    11-19-2009 05:32 PM #173
    the 2003 ford v6 3.8l coil pack needs no special wires, the vw wires slip right on.
  34. 11-19-2009 11:58 PM #174
    True but I already have the early ford coil pack.
    That's why I went with the custom setup.
  35. 11-25-2009 11:23 PM #175
    I did my mkIV. The wires were a pain but I did it and it worked fine but it didn't solve my problem.
