VWVortex.com - Catalytic Converter Warranty
    Results 1 to 23 of 23
    Thread: Catalytic Converter Warranty
    1. 02-03-2009 09:41 AM #1
      Local muffler shop says I need a new catalytic converter/downpipe for my '03 1.8T - $975 installed. Might this be covered by the VW emissions systems warranty? Anybody have experience replacing this part?
    2. Moderator Mr. Rictus's Avatar
      Sep 24th, 2004
      NY
      2.9L 24v twin turbo VR6 on a stand, 2002 S6 Avant with a Tial 770R 2.7T swap and O1E manual swap
      02-03-2009 09:42 AM #2
      Yes, it's covered by a law. Take it to the dealer as long as it has less than 70,000 miles and they have to replace it for free.
      Driversport Will Never Die|| Dub Cult PM me for all your Fragola Fittings and Billy Boat Exhaust Needs!!!
      The Elite 24v VR6 Club: Member #4
      My Dead Build Thread
    3. Member Tofik's Avatar
      May 6th, 2007
      908 - Jersey
      Bagged Galactic Blue Wolfsburg
      02-03-2009 11:00 AM #3
      or you can get a dp with a high flow cat for much less and get a small power increase at the same time :thumbup" and you can do it your self since its only 6 bolts..
      | !!For Sale!! : 2001 BAGGED GALACTIC BLUE PEARL JETTA 1.8T| AccuAir | Air Zenith | Airlift | Bag Riders |
    4. Moderator Mr. Rictus's Avatar
      Sep 24th, 2004
      NY
      02-03-2009 11:01 AM #4
      Quote, originally posted by GTINC »
      Only if it is, in fact, defective.
      Also, if it is defective, they may need to determine how it failed. If from improperly adjusted mixture or from impact, it should not be covered by the warranty, IMO.
      True, forgot to mention that.
    5. 02-03-2009 11:03 AM #5
      Quote, originally posted by tofik0 »
      will a high flow cat pass emissions? I've heard it MIGHT not
    6. 02-03-2009 11:05 AM #6
      Quote, originally posted by ali baba »
      as long as you can find obd2 for california.
    7. Member LOW36's Avatar
      Jan 17th, 2008
      SL,UT
      Bagged E36 Beast
      02-03-2009 11:13 AM #7
      I am running a Magnaflow high flow catalytic converter on my car and it passes with flying colors. [IMG]http://*****************.com/smile/emthup.gif[/IMG] (plus they are a lot cheaper)
      ***Bagged E36 ***
      FACEBOOK
      flickr
    8. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      02-03-2009 11:16 AM #8
      if your catalytic converter is not throwing an actual fault code then the dealership wont cover it. mine rattles like a MOFO and its still not throwing a code, so of course they keep telling me its fine, even tho if i tap it with a hammer you can hear all the pieces jumping around inside
      on some cars i believe there is an extended warranty to 100,000 miles or 10 years, so may wanna look that up as well.
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    9. Member LOW36's Avatar
      Jan 17th, 2008
      SL,UT
      Bagged E36 Beast
      02-03-2009 11:18 AM #9
      Quote, originally posted by Clean PG »
      Just pay the $250 for a Magnaflow and be done with it. I had the same issue.
      ***Bagged E36 ***
      FACEBOOK
      flickr
    10. 02-03-2009 01:28 PM #10
      Well there is an exhaust leak - I don't know if it is in the catalytic converter itself or in the piping - I suspect the latter. Sounds like the dealer won't replace it under warranty even though it's all one piece?
    11. Member LOW36's Avatar
      Jan 17th, 2008
      SL,UT
      Bagged E36 Beast
      02-03-2009 01:36 PM #11
      Its easy to tell where the leak is coming from.
      1. Jack the car up enough to get under it.
      2. Start car.
      3. Get under there and listen for the "fart sound" follow it with your hand along the piping and you should feel air puffing out.
      4. Fix it.
      ***Bagged E36 ***
      FACEBOOK
      flickr
    12. 02-03-2009 02:47 PM #12
      I went into the dealership with my 2000 2.slow with 160,000 kms, told them I hear a noise coming from the muffler. Cat was replaced under warranty
      Granted, I knew one of the techs there
    13. 02-03-2009 05:24 PM #13
      Quote, originally posted by skateman190 »
      2. Start car.
      It's 30F and snowing in Boston - you're welcome to come by and crawl under my car if you'd like.
      4. Fix it.
      What do you prefer - orange juice can and bailing wire? Or a tube of muffler weld from the auto parts store?
    14. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      02-03-2009 05:42 PM #14
      Quote, originally posted by ricas_gti »
      The AEG 2.0 has an extended warranty program on, it's good for 10 years 120K miles, I had mine done as well free of charge @ ~170,000 kms.
      I think all the others are 70 or 80K miles.
      I read this in Samuel L. Jackson's voice to make it more interesting. That's all I got.
      Current: 2004 Golf TDI 5MT
      Previous: 2003 VW Jetta TDI 5MT | 2002 Audi A4 1.8T Quattro 5MT | 2005 VW Passat Wagon 1.8T 4Motion 5MT | 2007 A4 Avant 2.0T Q/6MT | 2000 VW Golf 2.0 5MT
    15. 02-13-2009 12:51 PM #15
      Replaced by the dealer under the 8yr/80km warranty. The leak was in the flex joint on the downpipe.
    16. 02-13-2009 04:18 PM #16
      My GHL downpipe just barely passed CA smog testing a year ago. Pipe was purchased brand new. Car runs like a champ and gets awesome mpg. Previous smog test was done with factory DP and cat and it passed with flying colors. In my limited experience (with this and one other car), aftermarket cats just don't work as well as OEM cats. I'll be nervous when the next smog test rolls around next year.
      With my other car, the aftermarket cat just barely caused me to fail. Swapping the oem pipe back on the following week let me pass with a huge margin. The tech said my original test would have been passing not too long ago, but they recently lowered the amount of acceptable emissions.
    17. 02-13-2009 05:58 PM #17
      Just for completeness...
      1J0-254-506-SX Catalyst $605.00
      Plus gasket, nuts, washers, and labor.
    18. 02-13-2009 06:23 PM #18
      Got some needed advice here! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member ryanj's Avatar
      Sep 15th, 2008
      Earth
      02-13-2009 07:02 PM #19
      You are correct vw extended the warranty on the cat system I cant remember if its 100k or 120k. But It must fail readiness on the cat in order for them to replace it
    20. Member BassNotes's Avatar
      Mar 15th, 2005
      Costa Mesa, Calif., USA
      2002 VW GTI 1.8t
      02-13-2009 07:39 PM #20
      What's the stud size and thread on the turbo flange end of the DP?
      Bob Lee
      2002 GTI 1.8t 262,000+ miles
      VCDS 15.7.3 with KEY-USB interface
    21. Member
      Jul 17th, 2006
      FWD & RWD
      06-29-2009 06:28 PM #21
      Just had car serviced at an VW indy shop and told me I need a new CC, CEL confirms code. It is a 2003, 2.0 Jetta. I know someone has already mentioned some details, but if someone can confirm if VW did extend warranty and up to how many miles, I would appreciate it.
      Thank you!
    22. 04-04-2012 08:51 PM #22
      I'm finding some info says 2.0 10 years or 120,000 miles and some that say 10 years and 100,000.
      One local dealership of course says 10 years or 100,000. I have a 2003 2.0 and 113k of course
      Anyone have written info that shows 120,000 extended warranty?
