Closed Thread
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 142
Thread: 020 Manual Swap FAQ/DIY
    Mar 12th, 2003
    Westchester County, NY
    1994 VW Jetta 5spd
    04-07-2007 09:28 AM #106
    Quote, originally posted by Cyclopath »
    When the bolts are removed, the engine sags. One of the bolts actually runs through the motor mount. Have you tried lifting the engine? Block of wood under the oil pan and then slowly lift while checking the alignment of the holes. Only other solution I can think of is use the motor mount from the vehicle the starter came from.
  2. Banned moder13's Avatar
    Jan 16th, 2005
    04-14-2007 06:53 PM #107
    ok what kind of tool do we use to remove the bolts holding the driveaxle together?
    Mar 12th, 2003
    1994 VW Jetta 5spd
    04-14-2007 08:02 PM #108
    its called a 12 point triple square (8mm) your local autozone should sell a pack of 3 for like $8 bucks (3 different sizes in the pack) 8mm being the one you need
    stick it in a socket 13mm or a 1/2 socket on a ratchet and crank away
  4. Banned moder13's Avatar
    Jan 16th, 2005
    04-14-2007 09:06 PM #109
    thanks so much\ ayton
  5. Member f.n.low's Avatar
    Jun 19th, 2006
    Alberta
    2002 Gti 24v VR6
    04-22-2007 09:09 PM #110
    is it required to replace the front motor mount??
    Psn: durtydubz
  6. Member
    Mar 12th, 2003
    1994 VW Jetta 5spd
    04-22-2007 09:32 PM #111
    Quote, originally posted by f.n.low »
    only if its bad
  7. Member f.n.low's Avatar
    Jun 19th, 2006
    Alberta
    2002 Gti 24v VR6
    04-23-2007 11:06 AM #112
    sorry another question. Can I use the shifter box assembly and the rod that goes from shifter to linkage from a mk2 to fit my mk3 and mk3 manual transmission and linkage? or will that need to be mk3 specific
    Psn: durtydubz
  8. 04-23-2007 12:31 PM #113
    shifter linkage I believe has to be mkIII. Thats what I used anyway.....
    Mar 12th, 2003
    1994 VW Jetta 5spd
    04-23-2007 05:05 PM #114
    having had both boxes "next" to each other...the MK3 box mounts differently and I believe the relay haft has a slightly different bend to it. BUT everything else is interchangeable, the rods, bushings etc.
  10. Member f.n.low's Avatar
    Jun 19th, 2006
    Alberta
    2002 Gti 24v VR6
    04-24-2007 07:18 PM #115
    so here's a question... On my 2.0 on the head there's the coolant flange... it's got a sensor in it.. how do i go around that??
    Psn: durtydubz
  11. Member f.n.low's Avatar
    Jun 19th, 2006
    Alberta
    2002 Gti 24v VR6
    04-24-2007 07:49 PM #116
    should i just try and plug the outlet on the back and keep using this coolant flange??
    Psn: durtydubz
    May 28th, 2000
    96 Jetta GLS, 92 Jetta GL
    04-24-2007 08:53 PM #117
    You can plug the outlet with the relevant stopper and o-ring (cheap dealer item). The correct outlet flange is pretty cheap - maybe $12.
  13. Member
    Mar 12th, 2003
    1994 VW Jetta 5spd
    04-24-2007 09:21 PM #118
    buy a manual specific coolant flange...it's like $10-12 as stated above
  14. Member f.n.low's Avatar
    Jun 19th, 2006
    Alberta
    2002 Gti 24v VR6
    04-25-2007 03:07 AM #119
    Does anyone know if you have to disconnect the tranny computer in an obd 1 car??
    Psn: durtydubz
  15. Member f.n.low's Avatar
    Jun 19th, 2006
    Alberta
    2002 Gti 24v VR6
    04-25-2007 01:59 PM #120
    Also does anyone know how to take the shaft for the brake pedal out??? I undid the clip and took off the plastic near the fuse pannel... am i missing something???
    Modified by f.n.low at 2:33 PM 4-25-2007
    Psn: durtydubz
  16. Banned moder13's Avatar
    Jan 16th, 2005
    04-26-2007 06:14 PM #121
    take clip out on right and slide left.
  17. Banned moder13's Avatar
    Jan 16th, 2005
    05-03-2007 03:28 PM #122
    yeah i looked and saw that diagram in my bentley but i dont have that tab apparently on my donor. weird.
  18. 05-03-2007 07:30 PM #123
    Quote, originally posted by moder13 »
    Sorry, I should correct myself.... The tab (triangular piece) isn't fastened to the firewall. It literally just sits in there and stays fastened from the pressure of the spring.
    I used a piece of gum to hold it in place while I put the spring in.
    Your donor should definitely have it, the tab might have just fallen off when you took the spring assembly out.
  19. 05-03-2007 07:34 PM #124
    this piece.
  20. 05-03-2007 07:35 PM #125
    beat me to it.
    Here's the P/N and diagram if you need to go buy it.
  21. 05-03-2007 10:06 PM #126
    Quote, originally posted by Jg022 »
    i never had #15?
    15 looks like the clip for the pedal shaft. I think my auto only had 1 and I had to get another clip because I forgot to get it with the swap.
    I'll confess that I never put the second clip on, but it is on my list of things to do.
    vwman - what program is that that shows you everything - i've always wondered. And also where could you get all those parts apart from the vw dealer in person?
    (Back to swap topic)
    Program is ETKA, it's what the dealer uses for VW/Audi. There are various file-sharing methods for where you can get it. But the Tex doesn't allow this to be discussed.
    Aside from the dealership, you can order directly from
    http://www.worldimpex.com (input the P/N in the search box)
    http://www.1stvwparts.com (go to the part lookup)
    Only problem is that your going to get raped for shipping. This is probably a 1 or 2 dollar piece.
    Modified by vwman099 at 10:07 PM 5-3-2007
  22. Banned moder13's Avatar
    Jan 16th, 2005
    05-04-2007 03:14 PM #127
    and second is how the heck do i wire this thing?! hha.
  23. 06-18-2007 10:27 PM #128
    Quote, originally posted by Fuzzlet »
    Where is a place to order the stamped metal plate? I bent mine a bit so I want to get a new one.
    I don't have the P/N for it handy, but you can order it from http://www.worldimpex.com
    as well as http://www.1stvwparts.com
    You might want to check the price from the dealer as well. I think I priced them out to be around 35 dollars?
  24. Member
    Mar 12th, 2003
    1994 VW Jetta 5spd
    06-20-2007 04:14 PM #129
    did you check to make sure the ECU is working properly?
  25. 07-25-2007 11:27 PM #130
    Trans swap is DONE! Today i wired up the reverse lights. I had a little bit of trouble finding the yellow/white pair, so i just spliced in at the TCM connector. I ran two wires up to the 150 relay for the switch, and tied them into the two yellow backup light wires- works perfectly! ...now for some driving...
  26. Banned moder13's Avatar
    Jan 16th, 2005
    09-12-2007 10:19 PM #131
    did your inner tails work after the swap? i havent wired the reverse lights yet. butttt ive been driving my car around for a week now and i love it!
  27. 09-13-2007 06:31 PM #132
    so the trans is an 020, will everything from an 85 golf transfer over?
  28. Member
    Mar 12th, 2003
    1994 VW Jetta 5spd
    09-14-2007 04:38 PM #133
    you have to get a3 manual axles and mk3 clutch pedal and mk3 shifter box
  29. 09-14-2007 08:10 PM #134
    MK2 axles are 1/2" shorter than MK3 axles so they wont work, and the MK2 shift box is slightly different than the MK3 shift box. You cannot use your auto axles either they have a different flange on the ends.
  30. 05-30-2008 04:02 PM #135
    Quote, originally posted by Yo_Delprad »
    im about to pick up my donor car and was wondering about the vss i know there is one on the auto tranny but waht about the manual? how can you tell how fast you are going without it?and the auto cluster will work with the manual tranny like the tachometer and speedo?
    Idk about about 2.0l engines and their trannys, but when i did my swap (vr6), i kept my auto cluster and everything works just fine, and both vr auto and manual trannys share the same VSS, not sure about 2.0 though
  31. 06-01-2008 10:18 PM #136
    I wish I could say the swap in my 96 Cabrio was going easy.
    I can't get the clutch cable hooked up and when I try to start it I am only getting a "click".
  32. Member Skot53's Avatar
    May 15th, 2005
    R53 BRG MCS JCW
    06-03-2008 10:32 AM #137
    Quote, originally posted by TampaLinc »
    I am at a loss with the starting problem.
    Double check all of the fuse box wires... when I was in there messing with all of the clutch things, I accidentally loosened one of the thick red ignition wires, and that caused it to not turn over... Could be the source of your problem...
    Quote, originally posted by CanadianCabby »
    just wondering if there was an easier way to line them up...
    Another idea...
    ...Use a widowmaker to shift the engine into the proper position... just not too far, though or you'll crack a motor mount
  33. 06-05-2008 01:34 PM #138
    I checked all the connections at the fuse box and they look fine. I had a mechanic take a look at it and he said the engine and flywheel turn fine by hand, and the starter is contacting the flywheel.
    Am I missing something simple?
  34. 06-05-2008 09:51 PM #139
    Set the emergency brake. Put the vehicle in neutral. Turn the ignition to the ON position. Then short the large and small post on the starter. Make sure to keep your hair and clothing away from moving parts. If the starter is good, the engine will turn and hopefully start. Then you can work backwards from there.
    Andrew I Johnson May 25, 1985 - September 30, 2011
    Permanently banned from MVWS. And CGW says I don’t play well with others.
    Auto to manual transmittion swap. http://forums.vwvortex.com/showthrea...l-Swap-FAQ-DIYhttp://forums.vwvortex.com/showthrea...ight=cyclopath
  35. 06-06-2008 01:05 PM #140
    I checked for codes and I am only getting a couple of Airbag Codes.
    00588 - Airbag Igniter; Driver Side (N95)
    32-10 - Resistance too High - Intermittent
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    By connect the two terminals of the starter, do you mean run a wire from the power plug to the ground?
    I did find one big red wire under the dash that is not plugged in. It says AMP 1-929603 -1 on one side and has a 1 in a box and 191972751 on the other side. It this suppose to be plugged in someplace?
Closed Thread
