Here is the correct definition and test plan from VWP1287 Turbocharger divert air valve -N249- open circuit
Turbocharger Recirculating Valve, Checking
Valve opens between connection to intake manifold and connection to deceleration shut-off valve with no voltage. Connection to vacuum reservoir is closed.
Test sequence
– Switch ignition off.
– Disconnect connector from Recirculating valve for turbocharger -N249-.
– Measure resistance between terminals of valve.
Specified value: 25 to 35 Ω
If specified value is not obtained:
– Replace Recirculating valve for turbocharger -N249-.
t Vehicles with engine code ATW → Item
t Vehicles with engine code AUG, AWM → Item
If specified values are obtained:
– Connect Test box to control module wiring harness → Chapter, connect Test box for wiring test.– Check wire between Test box socket 105 + 2 pin connector terminal 2 for open circuit according to wiring diagram.
Wire resistance: max: 1.5 Ω
– Check the wire for short circuit to B+ and Ground (GND).
If no malfunctions are found in wire:
– Check wire between 2-pin connector terminal 1 and the Fuel Pump (FP) Relay -J17- for open circuit according to wiring diagram.
If no malfunctions are found in wires:
– Replace Engine Control Module (ECM) → Chapter.
For 1 week, the acceleration is pretty bad and linear. I made some chrono and it's definitely bad. So i tried to run vag com on it and here is the default :
The error was then :
