So how much is it exactly?
#71
Quote, originally posted by Charisma » Clay; I think I may just man-up and go through and get this kit despite my spending habits lately.
i/m me; acurarsxman52
Pics for clicks, as you can see the engine cover fits, that turbo is a Garrett GT3582R, the basic kit will come with a Garrett T3T4E 50trim.
#73
Quote, originally posted by kclax44 » So how much is it exactly? All IM's replied
#74
Yeah i'd like to know the same. Also what do you have fueling it?
#75
Quote, originally posted by everydayparadise »
Yeah i'd like to know the same. Also what do you have fueling it?The basic hardware kit with Garrett T3/T4E 50trim, TiAL 38mm wastegate, 3" stainless downpipe to bolt up to your stock cat back, oil feed, oil return, turbo inlet pipe, AFE high flow air filter, charge piping to connect to the stock dual SMICs, heat wrap for the downpipe, heat shield, alll the misc hardware/nuts/studs etc. will retail for 2795. The first 3 kits will go for an introductory price of 2595 shipped. If you want to upgrade to a dual ball bearing turbo ie GT3076R drop me an IM because they cost more.
Fueling will depend, all of the options are up to the client, we can put any turbo in there you'd like all the way up to a GT3582R and larger.
We sell unitronic software, and we have the injectors 630, 830, 870, 1200cc in stock.
#76
what kind of wheel hp are we talking with the basic kit? I know you said 350-400 but that is crank hp I'm assuming.
#77
This is a sexy looking setup! I am interested to know what is the perfect size on a stock motor looking to make 300 whp+....Eddie
#78
Wow - that looks great!Any pics of the DP by itself?
#79
sounds like you guys have got a great thing going- finally someone is doing it![]()
#80
Quote, originally posted by joe@vwvortex » Wow - that looks great! Any pics of the DP by itself?
I will try to get some of those shortly Joe, its a 3 piece design, one uses the top 02 pipe from our 1.8T kit, the other 2 pieces connect it to the stock placed cat back system.
Power will range from 300awhp range to 500awhp range, depends on turbo/software choices. On a side note we will also have a FMIC setup for this kit, it will be priced at 795USD, and requires no trimming/cutting to anything.
We're taking orders on our secure website:http://www.ctsturbo.com/produc....html
The first 3 will be 2595 shipped, following that the price will increase to 2795 + ship for the basic hardware kit, and prices vary with options listed in the drop down menu.
#81
what about removal of the headlight washers for the fmic?
#82
couldn't you of run the oil feed line round the back of the turbo instead of at the front?also that coolant line running over the coil packs
Quote, originally posted by Clay @ CTS Turbo »
the way you've positioned the oil and coolant lines doesn't seem very well thought out to me
#83
how long/ hard would you say the instillation of this kit is?
#84
Quote, originally posted by steve(nostt) » couldn't you of run the oil feed line round the back of the turbo instead of at the front?also that coolant line running over the coil packs the way you've positioned the oil and coolant lines doesn't seem very well thought out to me
Steve, there are not very many options with a top mounted turbo manifold, and the routing of the oil/coolant lines work fine on our VW 1.8T kits.
Quote, originally posted by Vdub 2.0 » how long/ hard would you say the instillation of this kit is? If you couldn't do it in 8-12 hours with a 12 pack and a couple pizzas I would be very suprised.
#85
Quote, originally posted by cincyTT » what about removal of the headlight washers for the fmic? I will post a spy shot of the FMIC later today.
#87
I have the money....just trying to figure out how the hell I'm going to hide this from my girlfriend![]()
#88
Quote, originally posted by sims159915 » I have the money....just trying to figure out how the hell I'm going to hide this from my girlfriend ship to my house, ill bring it to the shop, car needed clutch and a new turbo at same time
#90
This kit going to be available for a while? Really interested but my funds are a little limited atm because I know I'll need rods and clutch aswell. Maybe by late spring things will be looking better.
Modified by SteveCJr at 12:55 PM 2/27/2009
#91
Quote, originally posted by SteveCJr » This kit going to be available for a while? Really interested but my funds are a little limited atm because I know I'll need rods aswell. Maybe by late spring things will be looking better. The kit will be readily available for quite some time
#92
Clay, was going to send you a PM but i figure i let you answer this as i'm sure others will ask you anyway.i have forge front mount already and relocated the DV as well. basically i have most of the supporting mod and REvo chip without the big turbo in the engine. i know that i have to choose the injectors and the software from unitronic but can/will your kit work with the Forge front mount? the $2600 price is only for the turbo and dp along with all mounting hardwares right? it does not include injectors, software, fuel pump and the front mount. those will be additional correct?
#93
Quote, originally posted by cruzad3r » Clay, was going to send you a PM but i figure i let you answer this as i'm sure others will ask you anyway. i have forge front mount already and relocated the DV as well. basically i have most of the supporting mod and REvo chip without the big turbo in the engine. i know that i have to choose the injectors and the software from unitronic but can/will your kit work with the Forge front mount? the $2600 price is only for the turbo and dp along with all mounting hardwares right? it does not include injectors, software, fuel pump and the front mount. those will be additional correct?
If your forge FMIC connects to the stainless steel pipe on the left of this picture then it should be a breeze. Basically this kit was designed to bolt up to the stock SMIC setup. I would be very suprised if your FMIC didn't bolt up to our hardware kit with ease. You're correct, 2595 includes all hardware, no fueling (injectors or software), and the FMIC is additional.
#94
Quote, originally posted by Clay @ CTS Turbo » If your forge FMIC connects to the stainless steel pipe on the left of this picture then it should be a breeze. Basically this kit was designed to bolt up to the stock SMIC setup. I would be very suprised if your FMIC didn't bolt up to our hardware kit with ease. You're correct, 2595 includes all hardware, no fueling (injectors or software), and the FMIC is additional.
The forge FMIC connects to the hose that connects to that pipe and the pipe with the map sensor so it should fit fine.
#95
Quote, originally posted by joe@vwvortex » The forge FMIC connects to the hose that connects to that pipe and the pipe with the map sensor so it should fit fine.
Thanks for clearing that up Joe
#96
Does the charge pipe have a bung for the DV and n75 or is it intended for a relocated DV?Also if someone wanted an additional o2 bung welded into the downpipe for wideband sensor is that possible?
Modified by jwalker1.8 at 6:30 PM 2-26-2009
FS/FT 2001 TT (400 WHP) Roadster Wisconsin lots of extras http://forums.vwvortex.com/showthrea...lots-of-extras
#97
Quote, originally posted by jwalker1.8 » Does the charge pipe have a bung for the DV and n75 or is it intended for a relocated DV? You can see the DV in the photo and it is attached in the OEM position.
#98
Quote, originally posted by jwalker1.8 » Does the charge pipe have a bung for the DV and n75 or is it intended for a relocated DV? top of page, first pic you can see the dv in the top right corner, then 2 pics down you can see the 90* for the dv just after the 90* blue connector off the turbo
#99
OMG lol dam you CTS for making it so easy for me to buy this frikin kit LOL... about 4k for all the parts and probably another 1k for installation. big turbo does come cheap for the TT now LOL
question about reliability and driveability. how is this compare to the apr stage3? i know you said it's a plug and play system but am i going to have to spend endless hours, effort and money in getting this BigTurbo kit works right.
also i have to send you my ECU for the software right? how is the support on that IF i have problem with the software and my car is not running properly?
Do you have any partner vendor somewhere in the Northeast area? Like NY, MA, CT?
Modified by cruzad3r at 11:24 AM 2/27/2009
Modified by cruzad3r at 11:28 AM 2/27/2009
#100
The APR stg3 kits us a gt28r-gt2871r depending on model. These use a T3 based turbo which gives you tons more options on turbo selection, not just 28r to gt3076r with a T25 housing.The price he is posting is for a garrett 50trim turbo which will make 300-350fwhp on pump depending on psi.
Clay sells unitronic which gets tons of support on this forum. You will have to send the ecu out, but after that, a local rep will be able to take car of you. Just search the unitronic.ca site for local dealers.
#101
Quote, originally posted by cruzad3r » OMG lol dam you CTS for making it so easy for me to buy this frikin kit LOL ... about 4k for all the parts and probably another 1k for installation. big turbo does come cheap for the TT now LOL
Forcefed could do the install and supply the kit, or you could get it from us.http://www.forcefedengineering.com/
Ed can help you out, he does unitronic software, and he's well versed in installing our kits.
If you have any questions feel free to email me: clay@ctsturbo.com
on a side note, thanks Cincy
#104
Quote, originally posted by Clay @ CTS Turbo » Pics for clicks, as you can see the engine cover fits, that turbo is a Garrett GT3582R, the basic kit will come with a Garrett T3T4E 50trim.
#105
Quote, originally posted by cincyTT » ^ I thought that was on the kit he already listed; he said there is a 550hp kit coming out soon.
I could just be reading over it; I figured a GT3582R would translate to roughly 550hp.
