Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 141 to 175 of 345
Thread: ***Big turbo Kit for TT225s? Do you want?***
  1. 03-21-2009 11:53 AM #141
    why isnt this thread working for me anymore....It keeps showing it as being updated but it is always the same responses ???
  2. Global Moderator
    Feb 22nd, 1999
    Cowtown
    2008 Cayman S, 2000 S4 & 2010 Touareg TDI
    03-21-2009 01:08 PM #142
    Quote, originally posted by sims159915 »
    Because it's being bumped by adding and then deleting the post.
  3. Member jasonknezo's Avatar
    May 16th, 2002
    Downingtown, PA
    B7 S4, Shovelhead FL, WCC 2 UP CFL
    03-21-2009 09:26 PM #143
    ahhh i thought i was going crazy!
  4. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    97 A4, 98 VRT, 01 S4, 02 996TT, 04 A4, 11 GTI, 12 Golf R, 13 ??
    03-22-2009 12:44 PM #144
    I'm going to try to get a few more pics early this week
  5. Global Moderator
    Feb 22nd, 1999
    Cowtown
    03-22-2009 08:20 PM #145
    Quote, originally posted by Clay @ CTS Turbo »
    I'm going to try to get a few more pics early this week <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/gnbeer.gif" BORDER="0">
    Pics of the downpipe please!!!!!!
  6. Member
    May 16th, 2006
    Regina/Calgary
    '02 TTQ (RIP); '06 3.2Q A3
    03-23-2009 02:24 AM #146
    Haha, I just came into the thread to ask if you had more pictures yet. Bring 'em on!
    Jeremy Brehm: Regina Wedding Photographer
    '02 Audi TT 225 Build Thread - 2.0L - PTE6262 Daily @ 30PSI - 10.0:1CR - AEB @ 9000RPM - Maestro - RIP
    '06 3.2Q A3 - Stay tuned!
  7. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    03-23-2009 10:37 AM #147
    Quote, originally posted by joe@vwvortex »
    I'm working on it Joe it uses the standard 02 pipe from the 1.8T kit, and an additional set that mounts to the after cat portion.
    Quote, originally posted by jbrehm »
    Working on it guys i need to track down the old camera
  8. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-18-2009 11:24 AM #148
    The test pipe is standard on the kit, the cat is an option.
  9. 04-18-2009 11:54 AM #149
    It's pretty...the whole thing looks top notch!
  10. Member
    Mar 3rd, 2008
    Green Bay
    01 TT 225
    04-18-2009 11:56 AM #150
    damn, this kit would have saved me so many headaches...a few months too late
    FS/FT 2001 TT (400 WHP) Roadster Wisconsin lots of extras http://forums.vwvortex.com/showthrea...lots-of-extras
  11. Member bvgoosedd's Avatar
    Mar 5th, 2009
    Raleigh NC
    mk1 Audi TT w/GT3076r Sold + mk4 2.8 VR6 Gli MINE 07 EOS 2.0t HERS
    04-18-2009 02:48 PM #151
    can't wait for mine to come in. no cat tho
  12. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-20-2009 01:27 AM #152
    Quote, originally posted by DnA-TT »
    Thanks
    Quote, originally posted by bvgoosedd »
    I think i'm more anxious than you ray
  13. Global Moderator
    Feb 22nd, 1999
    Cowtown
    04-20-2009 11:18 AM #153
    Looks good! Like the Vband connection. My only concern from the pics shown is the vibration on that hanger on the weld. I'd look at moving it off the weld a bit. Also - how accessible are the four bolts in the engine compartment on the DP? Could this be done with a Vband instead?
  14. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-20-2009 10:44 PM #154
    The 4 bolts holding the pipe to the turbo are easily accessed from the top if that's what you're getting at. Maybe i'm confused
  15. Global Moderator
    Feb 22nd, 1999
    Cowtown
    04-21-2009 09:16 AM #155
    Nope that's what I'm asking. The three bolts on my 42DD DP are a bitch to get at.
  16. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-21-2009 10:08 AM #156
    shouldn't be a problem, the exhaust portion of this kit has 3 pieces, piece one bolts to the turbo with 4 bolts, piece to connects to the mid pipe. The mid pipe has a vband on the lower section and a 4 bolt flange on the upper portion. The upper portion of the mid pipe is studded, so connecting them is pretty straight forward, wind on the nuts to near tight then tighten them down. The last portion has the optional cat or standard test pipe, which connects to the mid section with a v band as pictured.
    Hopefully that clears things up a bit
  17. Member
    Mar 3rd, 2008
    Green Bay
    01 TT 225
    04-21-2009 11:54 AM #157
    Out of curiousity since I already have a BT set up, can someone purchase just the DP? Say this person has a custom tubular mani that has a similar turbo configuration as the kinetics mani...If so, how much?
  18. Member
    May 17th, 2000
    Los Angeles
    2002 GT2871 TT Q coupe, 1969 RS Camaro
    04-21-2009 01:53 PM #158
    what kind of cat is that? i've already gone thru 1 stainless cat and am on my 2nd...........this is in 45k miles of ALOT of flow and heat....but still. that thing looks similar to a factory (non-225) cat.
  19. Member shottabwoy5's Avatar
    Oct 18th, 2006
    Central Jersey
    Four Rings, 2006 Passat 2.0t Sold, 2004.5 Jetta GLI (Sold)
    04-21-2009 07:14 PM #159
    do u recomend building the motor before putting the big turbo kit on i currently have a gli but in debating getting a TT 225 i would deff want your kit interested in either the 2871r or the 3071r will see what the funds are like ...but do u recommend building the motor before putting this kit on?
  20. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-22-2009 01:14 AM #160
    Quote, originally posted by jwalker1.8 »
    The DP is really involved, and with the clearances I don't think it would fit if you had a custom exhaust manifold. obviously from the pics you can tell that the downpipe could hit the tunnel pretty easily so if the manifold/turbo placement is off 1/8" then it would be much further off since the downpipe is quite far down the line. Think if a gear shifter, when you shift a gear the pivot point of the shifter moves very little, but the knob has to go quite far, same deal with a slight change in the manifold placement.
    Quote, originally posted by M this 1! »
    I can't remember at this time, i'll try to dig it up for you.
    Quote, originally posted by shottabwoy5 »
    There are a lot of 1.8T guys making 325whp on stock blocks, for much more than that I would get rods. Most of the people that buy this kit will likely want something along the lines of a GT3071R or GT3076R, most of our sales come from those turbos, because they make good power and give you a good spool up. To take full advantage of these turbos you'll want to get drop in rods at a minimum. For a 3071R drop ins would work nicely, I've seen 420+whp on those, with 20psi coming before 4000rpm.
    JC @ Douglas ran a 3071R on his 20V a few years back, and was one of the first into the 11's now he's one of the first into the 11's with a 2.0FSI.
    If you guys have any q's feel free to IM me, or email
  21. Member bvgoosedd's Avatar
    Mar 5th, 2009
    Raleigh NC
    04-22-2009 09:37 AM #161
    This kit so far from what i've gotton is f**king sweet. i will be posting pics as i go along. i'am def gonna do rods, just that right now my turbo blew so i had to do something, i didn't want to waste 700 on a stock ko4. so i went with a gt3076r. i'm gonna run about 15psi till i can do rods. just to be on the safe side i am not gonna put a boost controller in. i would wanna turn up the boost soooo bad. I can def say clay has been great to deal with. always answers his emails and is very quik with it. thank god for blackberry. lol. i just dropped the car off yesterday to get the kit installed. so i told the shop to take as many pics as possible.
  22. Member bvgoosedd's Avatar
    Mar 5th, 2009
    Raleigh NC
    04-22-2009 09:49 AM #162
    here's some more for you guys. if you guys have any questions about clay or anything i'll be more then happy to back him up. even the people at the shop said it's a very nice looking kit. i hope it's a smooth install and i did tell them to take lots of pics. i will let you guys know how it comes along.
  23. Global Moderator
    Feb 22nd, 1999
    Cowtown
    04-22-2009 11:03 AM #163
    Looks great - thanks for the pics!
    Let us know how many hours your shop takes for the install.
  24. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-23-2009 12:57 AM #164
    Thanks Joe
  25. Member bvgoosedd's Avatar
    Mar 5th, 2009
    Raleigh NC
    04-24-2009 08:46 PM #165
    so far install is smooth!!!! I got the test pipe today bought it to the shop.
    look at the lil ko4. OMG it was F**KED up. the lil shaft was beyond destroyed.
    test pipe.
    sorry about crappy pics used my cell. didn't have a nicer camera
  26. Member pchon's Avatar
    Mar 9th, 2007
    2001 TT 225(Sold) 2001 S4 Avant
    04-25-2009 03:21 AM #166
    Hey Clay, Just ordered your intercooler kit for my 225. Not quite ready for the BT kit yet but hopefully soon... Any idea when you guys will ship my order? Thanks.
    Pakin
  27. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-25-2009 11:14 AM #167
    Looks good Ray, don't forget to clock the turbo and make sure the drain is positioned correctly
    Quote, originally posted by pchon »
    Pakin
    Check your email/IM
  28. Member bvgoosedd's Avatar
    Mar 5th, 2009
    Raleigh NC
    04-25-2009 04:23 PM #168
    yea shop is taking their time to make sure everything is done rite. lol. so far they told me looks good and pretty straight forward. only consern is the wastegate dump pipe back to the dp. is it gonna leak? that is the only thing he is concerned with. you know how it connects and there is no gasket or anything?
  29. Member SlowVRT's Avatar
    Jan 3rd, 2009
    Jacksonville, Florida
    96 GTI VRT & 92 Corrado VRT & 99 Ford SPL Vehicle & 95 VR6 MK3 Daily
    04-25-2009 11:33 PM #169
    run that bitch open dump... sounds better.
    oh and clay has a small *****
  30. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-26-2009 11:16 AM #170
    Ray, we've never had a problem with them leaking, I wouldn't worry about it.
    Quote, originally posted by SlowVRT »
    haha, thats why they send me all those emails about pills and pumps
  31. 04-26-2009 05:53 PM #171
    We've had nothing but good luck with all the CTS kits, very nice pieces.
  32. Member SlowVRT's Avatar
    Jan 3rd, 2009
    04-26-2009 08:55 PM #172
    i secretly submitted your email to them... ruh roh
  33. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-26-2009 11:02 PM #173
    Quote, originally posted by Steve@ForceFed »
    Thanks Steve
  34. Member SlowVRT's Avatar
    Jan 3rd, 2009
    04-28-2009 05:49 PM #174
    its ok clay...
    btw did you get those things made we were talking about?
  35. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-29-2009 12:15 AM #175
    its ok clay...
    I got them done, and shipped em to ya
