VWVortex.com - Passat (B5) Do-It-Yourself, How-To and Frequently Asked Question Thread
    Results 1 to 16 of 16
    Thread: Passat (B5) Do-It-Yourself, How-To and Frequently Asked Question Thread
    1. Geriatric Member
      Mar 10th, 1999
      SoCal
      2003 Jetta GLI (Project car), 1957 Porsche Speedster (replica)
      02-16-2009 01:10 PM #1
      Welcome to the Passat (B5) Do-It-Yourself, How-To and Frequently Asked Question Thread.
      How to add something to the FAQ?
      If you have anything that you would like added to this list, or to report broken links, please use the report post to moderator function.
      Don't forget our Technical Forums that are broken down into more specific sections like interior, car audio and electronics, specific engines, transmissions etc.
      To search within this thread, please press Control+F or Command (Open Apple)+F on your keyboard. (Note: Just because nothing is returned does not mean that it is not here, your search term may not be used in the description). Many items and issues may fit into all categories, so it is best to spend a couple minutes looking through the whole thread.
      Sections
      01) Typical Problems & Questions
      02) Oil & Servicing
      03) Body & Exterior
      04) Interior
      05) Wheels & Tires
      06) Lighting
      07) Electrical
      08) Radio & Navigation System
      09) VAG-COM
      10) Suspension & Handling
      11) Motor & Transmission
      12) Brakes
      13) Racks & Carriers
      14) Misc.
    2. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:15 PM #2
      Which gas should I use in my Passat? - Forum Discussion
    3. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:16 PM #3
      Oil & Servicing
      TSBs and Recalls - luvail
      What OIL should I use? - Forum Discussion
      A special note...
      There are two tools that any VAG owner absolutely must have. Just like your torque wrench and your socket set, your toolbox is crippled without them:
      1) A VAG-COM cable/software from Ross-Tech in Lansdale, PA
      This cable will connect your laptop to the OBDII port on your car, and enable you to self-diagnose, pull the full code for your problem, and clear out that CEL so you can get on with your life. Having the cable around will also allow you to run software like Lemmiwinks to tweak your ECU a bit.
      2) The official factory repair manual, from Bentley Publishers in Cambridge, MA, available from the manufacturer or through many of our dedicated forum sponsors/banner advertisers.
      These manuals are comprehensive guides to your car, from wiring diagrams to engine cut-aways to torque specs. Not having one is like doing carpentry without a tape measure - it just won't work out well in the end.
      Chances are, many of the things you want to do, or want to know, can be understood by simply having these two things around. No need to post or even use the search - just hook up and scan, or open to the right section and get to work.
      So, pick these up, whether it be from the classifieds, ebay, or your favorite car parts source, and get familiar with them. Your ownership time will be much better for it.
    4. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:17 PM #4
      Body & Exterior
      Topic and link - contributer
    5. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:17 PM #5
      Interior
      Adding a Warning Triangle - parts, links, etc.
      For general interior questions, be sure to visit:
      The Interior Forum
      Modified by robbyb413 at 2:26 PM 3-5-2009
    6. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:18 PM #6
      Wheels & Tires
      Stock Bolt Battern/Offsets - Forum Discussion
      For general wheel info, be sure to visit:
      The Wheel and Tire Forum
      The offset/fitment thread: http://forums.vwvortex.com/showthrea...fitment-thread
    7. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:18 PM #7
      Lighting
      --- Exterior ---
      Disabling DRLs, all years - Forum Discussion
      Rear Fog - b5.5 - Forum Discussion
      Rear Fog - b5 - Forum Discussion
      For general lighting questions be sure to visit:
      The Lighting Forum
      --- Interior ---
    8. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:19 PM #8
      Electrical
    9. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:19 PM #9
    10. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:19 PM #10
      VAG-COM
      Vag-Com Locator Service - hoveraudi
    11. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:20 PM #11
      Upper control arm replacement - TDForNow
      For general suspension info, be sure to visit:
      The Suspension Tuning Forum
    12. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:20 PM #12
    13. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:21 PM #13
      Brakes
    14. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:21 PM #14
      Racks & Carriers
    15. Geriatric Member
      Mar 10th, 1999
      SoCal
      02-16-2009 01:21 PM #15
    « Back
