VWVortex.com - The $1500 Miata -- does it really exist?
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 61
    Thread: The $1500 Miata -- does it really exist?
    1. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      02-17-2009 11:31 AM #1
      Every CL regular has heard of the $1500 Miata. It's something dozens of us have probably searched for in our spare time. But when the market for even 1.6L NA Miatas in any kind of decent condition is saturated with $4-$5,000 cars, the buyer must naturally ask himself one question – how much does a $1500 Miata really cost?
      Well, here's my answer.
      On January 9th, I shook hands on a Miata I found listed on the local D.C. Craigslist for $1500.
      The specs:
      1990 with 210k miles – original engine and three owners (me included)
      Working AC
      New top (glass window)
      New timing, accessory and alternator belts
      New water pump
      New valve cover gasket
      New PCV valve
      New battery
      New spark plugs/wires/boots
      New cone filter (airbox delete)
      Good clutch and shifter
      Smooth running, no strange noises or rattles.
      New brake pads and rotors (EBC Greenstuff + DBA drilled/slotted rotors)
      All suspension components in good shape
      New coolant and heater hoses
      Issues at purchase:
      Prior collision damage on front driver's side and rear passenger side – minor. Minor unit body damage was repaired prior to the P.O. purchasing the car.
      Small coolant leak from radiator
      Driver's side headlight droop
      Catalytic converter heat shield loose and rattling (cat was replaced and they re-used the heat shield – poorly)
      Oil leaks from CAS seal, front crank seal, drain plug and possibly rear main seal
      Trans leak from rear seal and possibly drain plug
      Torn inner tie rod boot – passenger side
      Hood prop hinge retention bracket missing
      Dipstick handle broken
      Missing HVAC/radio surround trim piece
      Crappy aftermarket head unit
      Carpet, seat belt guides and other various interior trim pieces were removed for new top installation and never replaced – all retention bolts and tabs missing
      Torn upper/lower shift boots
      Missing shifter/center console insulation
      Mismatched tires: 2 all-season, 2 summers, different sizes front and rear
      Minor rust in driver's side rocker panel and passenger side door window frame, and some superficial rust in other places.
      Spending history:
      $1350 – Purchase price
      $100 – OEM 14" Daisy wheels w/ good tires
      $100 – radiator
      $18 – radiator cap (preventative)
      $24 – upper shift boot
      $16 – rear main seal
      $8 – oil cap (preventative)
      $5 – cam angle sensor seal
      $18 – camshaft oil seals (two)
      $7 – crankshaft oil seal
      $4 – main crank bolt
      $4 – crank pulley Woodruff Key
      $12 – transmission front & rear seals
      $6 – hood prop retention clip assembly
      $28 – headlight retractor arms (two)
      $31 – valve cover gasket (preventative – valve cover had to come off for crank/cam seals)
      $19 – tie rod boot
      $27 – power steering pressure hose
      $14 – dipstick
      $100 – new head unit
      $60 – new HVAC/radio surround trim
      $20 – various interior and exterior trim clips and bolts
      So the total damage, not including excise tax, tags, registration and inspection costs so far -- $1977. $200 of that was purely optional (replacing wheels/tires and the head unit) and could have gone months without a fix. Realistically, the radiator could have too, but I didn't want to chance it.
      So that leaves us with a $1777 Miata that passes Maryland inspection and emissions, doesn't puke oil all over itself when you rev it past 3k RPM, and absolutely loves being treated like a Miata generally should – like a sports car.
      So what's the catch? Well, you can't be afraid to tear your motor half apart to fix 210k miles worth of neglected rubber. It doesn't take much more than simple hand tools, patience and an internet connection, but if you're not mechanically inclined, it's not going to be terribly fun for you. If you're counting on a shop to do this stuff, well, let me put it this way: I spent $18 for the inner tie rod boot and $27 for the power steering pressure hose. The shop that did my safety inspection wanted $800 after labor to replace these parts, and that's some of the easy stuff.
      So, if you have a couple torque wrenches (or maybe just a really nice one) and a few weekends to kill, then yes, there really are sub-$2k Miatas in this world. Good luck finding one -- I'm glad I did.
    2. Member strskatr05's Avatar
      May 24th, 2007
      Pittsburgh
      2013 Chevy Cruze
      02-17-2009 11:33 AM #2
      Good post [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. Member mad8vskillz's Avatar
      Aug 20th, 2001
      Philthadelphia
      '11 tundra, '03 sv1000, 14 grom
      02-17-2009 11:35 AM #3
      not a bad deal. 210k scares the carp out of me though
      Demokratikally Elekted Fist Lieutenant of the Outside Cavalry of the Independent People's Republik of Offtopikstan
      Quote Originally Posted by GodSquadMandrake View Post
      That's too bad but, VWVortex said so... so you have to do it now.
    4. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      02-17-2009 11:37 AM #4
      Quote, originally posted by mad8vskillz »
      A couple of guys I met when I had my Mazda6 are opening up a speed shop not too far away and I hope to get this car over there for some dyno time. I want to see what 20 years and 210k have done to its power output.
    5. Member Benjamin.'s Avatar
      Nov 12th, 2001
      Hanover, PA
      2016 Sportwagen, 2010 Prius, 2005 Grand Caravan, 2002 Accord
      02-17-2009 11:44 AM #5
      My $1500 Miata:
      1993 Miata - 63k miles, white w/ black top
      newer top w/ glass window
      new timing belt, water pump, misc. seals, fluids (coolant, oil, diff fluid IIRC), new front brakes, all with about 1k miles on them
      Minor dings/dents and typical light rocker rust in front of rear wheels, previous light unibody damage up front, body not clean, but car mechanically solid
      Purchase price, $1500
      1-way plane ticket to Massachusetts via Southwest Airlines: $63
      Gas/tolls/food for the trip back: $50 (probably wasn't that much)
      KYB GR-2 rear shocks to replace leaking originals - $115
      NAPA rear rotors and pads - roughly $30 total IIRC
      Sony 6.5" speakers to replace blown originals - $50
      2002 Miata 15" alloys w/ good tires - $90 (car came with good snows on steel wheels)
      Before tax, registration, and inspection (which it passed with flying colors after replacing shocks and rear brakes myself), I'm into the car for about $1900, including my travel costs and new wheels/tires that it did not need to pass inspection. I've put 15-16k on it since I got it in April '08, and I've driven the crap out of it.
      What it looked like before I started butchering it with flat green paint and a light bar:
    6. Member chuckwizowski's Avatar
      Feb 12th, 2007
      2009 Honda Fit, 1979 Rx7, 1969 Beetle, 1993 Miata
      02-17-2009 11:46 AM #6
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] Good read!
      I too am in the "Looking for a sub 1.5 stack miata" boat, in DC too nonetheless. Hopefully this summer i'll find "the one."
    7. Member Benjamin.'s Avatar
      Nov 12th, 2001
      Hanover, PA
      02-17-2009 11:50 AM #7
      Summer's the wrong time of year to be looking for cheap Miatas...
    8. Member chuckwizowski's Avatar
      Feb 12th, 2007
      02-17-2009 11:53 AM #8
      Quote, originally posted by mynameisphunk »
      I know I know, but I don't have a job during the school year (read:$16 to my name)
    9. Member Benjamin.'s Avatar
      Nov 12th, 2001
      Hanover, PA
      02-17-2009 11:55 AM #9
      I did get lucky with mine, buying it in mid-April - right at the beginning of convertible season and the associated price hike.
    10. Member Jetty!'s Avatar
      May 9th, 2006
      2007 VW GLI, 2004 Honda S2000
      02-17-2009 11:57 AM #10
      This one is $2500 but it might be worth it for those not mechanically inclined:
      http://hartford.craigslist.org/cto/1032737968.html
    11. 02-17-2009 11:58 AM #11
      Good read. Besides scamming Alzheimer's patients or getting one as a partial gift from a family friend there really is no such thing as a $1,500 Miata as they all will need some work at that price point. I know, I know, we've all heard the tale of that one guy buying a near mint BRG '91 with hardtop included for like $800 but those are "once in a lifetime" deals that fall far outside 6 standard deviations. The real question is how much crap not working/looking good are you willing to put up with and how much repair work can you do yourself. Most people can't or don't want to work on cars. Therefore, all the work you just performed would cost significantly more if you paid a dealer or a good independent mechanic to do the work.
      Quote, originally posted by chuckwizowski »
      They're all over the place you just have to look. My friend in Alexandria just sold a red '90 for $1,500 but it didn't look that great (mismatched red paint dented in places) and it had a cracked windshield but it ran fine.
      Current: 2016 Volvo XC90 - 2010 Volvo XC70 - 1991 Mazda Miata :: 2000 Aprilia RS50 - 1972 Honda CB350
      Past: 2013 Mercedes-Benz GLK350 - 2013 Volkswagen GTI - 2007 BMW 335i - 1988 BMW 635CSi - 1987 Volkswagen Jetta GLI - 1987 Suzuki Samurai - 1984 BMW 633CSi :: 1992 Kawasaki KDX200 - 1983 Yamaha YZ80
    12. 02-17-2009 11:58 AM #12
      Great Post!
      I'm pretty close to getting 100% debt free and I've decided the first thing I'm going to save for after I'm done is either a 1500$ Miata to tinker with next summer or a new Motor for my Gokart.. which is also about 2000$ said and done.
      Unfortunately I've noticed quite an abundance of the 4-5K NA Miata(s?i?). Not nearly as many of the 1500$ unwrecked examples.
      Someone here wanted 1000$ for a wrecked one. mashed up hood and two fenders. Probably needed a radiator too.
      On the other hand I saw an R with a new clutch and a hard top for 4500...
      Modified by citat3962 at 10:00 AM 2-17-2009
    13. 02-17-2009 12:00 PM #13
      $1500??? Over priced.
      this guys was $250
      http://forums.vwvortex.com/zerothread?id=4248076
    14. Member Art Vandelay's Avatar
      Dec 20th, 2005
      STL
      SVO
      02-17-2009 12:02 PM #14
      $4k - $5k is cheap where I live. There is a '96 M local to me with 145,000 miles on it, asking $6,900. He will probably get close to that.
      JSW TDI, Mustang SVO, et al.
    15. 02-17-2009 12:12 PM #15
      good score (i saw your car when it was on CL as well)
      i know where therfe is a 1700 miata with a simple relay issue for 1700, with a hardtop and flyin miata turbo kit as well the hardtop does have the glass shot out via bb gun though
    16. 02-17-2009 12:18 PM #16
      How about 1 grand?
      http://forums.vwvortex.com/zer...age=1
      This was a fun project while it lasted. I had to let it go, mostly due to garage space.....the house underwent a major renovation this past year and I needed to store tools, lumber, kitchen cabinets, etc, etc....
      I found a buyer *instantly* for the car, and besides labor, broke even.
      I think he was from Flint.....said he was turning it into a track car.
      Thanks again to everyone that helped out, and to Juniper for those mirrors!
    17. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      02-17-2009 12:19 PM #17
      Quote, originally posted by purplejettahondaeater »
      I'd consider that an investment, shot out window and relay issues or not.
    18. 02-17-2009 12:23 PM #18
      ive been talking to the owner about it (cool guy has auto-x'ed a few times and taken it to summit pre turbo and coilover install, i forgot to mention the coilovers didnt i )
      hopefully my job situation will be better shortly and i'll be able to take it off his hands
      (in fact by this time next week i may have a monthly car allowance)
    19. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      02-17-2009 12:28 PM #19
      Good luck!
    20. 02-19-2009 11:00 PM #20
      Those are great stories! Here's mine.
      I got lucky over Christmas break. I was looking for a car in the $3-4K range on craigslist, and looked at a few dozen cars. On a whim, I looked on Jacksonville, FL craigslist, since my brother-in-law lives down there. I saw a 93 for $1300. I called my brother-in-law to go look, thinking it would be nothing like described. He called me five minutes after he got there, and said "buy this car!" I went and got a cashier's check and express mailed it. Two weeks later, a guy in my car club going home to FL over Christmas brought it back to NC for me. I gave $1200 for the car, paid my friend $100 to bring it back, and took delivery of of a '93 with 107k on the odo, a cracked rear finish panel, some pealing clearcoat on the trunk and a rough idle. I had my old wrecked miata (which I'm parting, BTW) so I switched the AFM, and it runs perfect. I threw in a roll bar I had purchased for my other car but hadn't put it in before it was wrecked, bolted on the 6ULs from the old car, and the headrest speakers, some wet-sanding and polishing, and here's what I've got:
      Modified by Gazornan at 11:04 PM 2-19-2009
    21. Member racer_41's Avatar
      Aug 27th, 2003
      Chicago, IL
      2016 Golf SE T. Red, 06 GTI 170Km!
      02-19-2009 11:34 PM #21
      Quote, originally posted by Gazornan »
      WOW. Brings back the memories. I had a red 90 for ten years and had only 78K on it when I sold it.
      Those wheels are some of the best looking ones I've seen on a Miata...
      except my old 15 x 8 Panasports
      damn I miss that car. One of these days.
    22. 02-20-2009 02:01 AM #22
      My story:
      I had been looking for a 1.6L Miata for four or five months. I looked at AutoTarder, Cars.com, Craigslist and KSL Cars (a local site) at least every other day... literally. Finally in November 2006, I found an AutoTrader ad in Los Angeles for a 126k '91 stripper in my preferred color for $1800. I sent a local friend to inspect it, and he gave it a glowing review. So I negotiated a $1600 price with the seller, then mailed my money to my friend and had him buy it and park it in his garage. Two weeks later I flew down and drove it back home.
      How it looked on the trip home:
      Its flaws were few:
      -the OEM top was severely sun-worn (LA car its whole 2-owner life) and had a few small rips. When I sent my money to my friend, I ordered a new Robbins replacement top and had it drop-shipped to my friend's house. We installed it together in his garage before I left.
      -all four tires matched and had lots of tread, but one of the fronts had a substantial chunk missing from its outer sidewall thanks to a curb incident. Rather than just replace that tire with an identical new one, I phoned the Tire Rack and had them drop ship a set of Michelin X-Ice tires to my friend's house; we installed them before I left. I was planning to use the Miata as my daily driver through the winter, so I would have had to do this eventually anyway.
      -the rear camshaft seal was weeping oil. A classic weakness, I didn't bother to do anything about it since I knew the engine was just going to come out eventually anyway.
      Everything else mechanically was in perfect condition. The paint and all body panels are original. It passed our emissions and safety inspections with ease.
      And now it's sitting on jackstands in my garage. A not-quite-up-to-date photo:
      Modified by TurboMinivan at 12:03 AM 2-20-2009
      Dempsey Bowling
      Sales Consultant at Doug Smith Dodge/Chrysler/Jeep/Ram/Subaru/Kia/used
      My fleet: 91 Miata, 98 Wrangler Sport, 01 Suburban 2500 8.1L, 14 Impreza Limited, 80 Grand Prix LJ 454
    23. Member Phil Pugliese's Avatar
      May 18th, 2000
      Reno, NV
      17 Golf Alltrack S, 92 Miata SBY, 08 Yukon XL
      02-20-2009 03:23 AM #23
      in 99 I paid 1000 for a 90B w a HT. It had 122K on it and every panel was a different shade of red. Gave it some TLC then sold it 6 mo later for 3800.00. That was the first of 6 Miatas
      CLICK * POINT * CHUTE
    24. Member digiddy's Avatar
      Aug 30th, 2006
      Baltimore,MD
      '04 Subaru Impreza Wagon
      02-20-2009 07:22 AM #24
      I bought my first car which was a miata for 1500 bucks...
      Heres my spending history...
      Crank pulley "rebuild"- $280
      Fresh Radiator off miata.net classifieds- $40
      ____________________________________________
      thats all the cash I spend on making it run besides the tags and inspection and oil changes...
      Bought it with 162k on the clock and sold it with 168k
      guess it just comes down to luck
      Modified by Theoffspring99us at 7:24 AM 2-20-2009
      I survived the great vB transition of 2010....
    25. Geriatric Member AKADriver's Avatar
      Nov 20th, 2001
      Unreal VA
      '12 Mazda2, '09 Forester
      02-20-2009 10:38 AM #25
      There's a $1300 Miata in our area on CL now:
      http://washingtondc.craigslist....html
      it has a new top (looks like a normal zippered plastic window OE replacement) and battery (probably non-AGM), that's conservatively worth $400 right there.
      I don't practice llanteria
