VWVortex.com - EPC and CEL lights came on. Limp mode
    Results 1 to 5 of 5
    Thread: EPC and CEL lights came on. Limp mode
    1. Member BenficaVW1's Avatar
      Sep 14th, 2007
      Ft. Bragg, NC
      MK2 GTI (SOLD), MK3 GTI VR6, MK4 GTI (RIP), MK5 GTI (sold), MK6 Jetta TDI, MK6 Golf TDI, 2002 E46 M3
      02-19-2009 11:56 PM #1
      I barely ever beat on this thing. It's babied for the most part. I am chipped stage 2, apr downpipe, AWE DV, A3 pipe, and i have a K&N drop in filter. I havent had a single problem with this car for awhile. it's up to date on most recalls i believe. so everything has been cool for awhile. today i leave my gf's house to go to a gtg and what happens, my car throws a CEL and EPC light and im throw into limp mode. i have vag com too so here are my results...
      ps. i also checked my cam follower about 2k miles ago and it seemed fine. i have an extra just incase but it really didnt need to be replaced
      VIN: WVWEV71K97W015071 Mileage: 40320km/25053miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: Malfunction 0010
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      0F-Digital Radio -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      1C-Position Sensing -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: Malfunction 0010
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      65-Tire Pressure -- Status: OK 0000
      Address 01: Engine Labels: 06F-907-115-AXX.lbl
      Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
      Component: 2.0l R4/4V TFSI 0030
      Revision: 5BH14--- Serial number: VWZ7Z0F4068246
      Coding: 0403010A18070160
      Shop #: WSC 06461 444 53430
      1 Fault Found:
      008854 - Fuel Pressure Regulator Valve (N276): Short to Plus
      P2296 - 001 - Upper Limit Exceeded - MIL ON
      Freeze Frame:
      Fault Status: 11100001
      Fault Priority: 0
      Fault Frequency: 2
      Mileage: 40325 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 20:56:49
      Freeze Frame:
      RPM: 1224 /min
      Load: 14.9 %
      Speed: 0.0 km/h
      Temperature: 63.0∞C
      Temperature: 22.0∞C
      Absolute Pres.: 1000.0 mbar
      Voltage: 11.430 V
      Readiness: 0100 0101
      Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
      Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
      Component: ESP FRONT MK60 0101
      Revision: 00H11001
      Coding: 0021122
      Shop #: WSC 01279 785 00200
      No fault code found.
      Address 08: Auto HVAC Labels: 1K0-907-044.lbl
      Part No SW: 1K0 907 044 BN HW: 1K0 907 044 BN
      Component: ClimatronicPQ35 110 1010
      Revision: 00110021 Serial number: 00000000000000
      Shop #: WSC 00000 000 00000
      Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
      Part No SW: 3C0 937 049 AA HW: 3C0 937 049 AA
      Component: Bordnetz-SG H45 1402
      Revision: 00H45000 Serial number: 00000002289720
      Coding: A78F8F014104150000140000001400000009770B5C0000
      Shop #: WSC 06461 444 84264
      Part No: 1K1 955 119 E
      Component: Wischer 220506 020 0501
      Coding: 00038805
      Shop #: WSC 06461
      Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
      Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
      Component: SDAR SIRIUS H03 0060
      Revision: 00000000 Serial number: AUZ4Z7E7017170
      Address 15: Airbags Labels: 1K0-909-605.lbl
      Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
      Component: 5L AIRBAG VW8R 034 8000
      Revision: 05034000 Serial number: 003B6D09SCMI
      Coding: 0013644
      Shop #: WSC 08212 444 84654
      Part No: 1K0 959 339 D
      Component: BF-Gewichtsens. 006 0006
      Address 16: Steering wheel Labels: None
      Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
      Component: J0527 034 0070
      Coding: 0002022
      Part No: XXXXXXXXXXX
      Component: E0221 002 0010
      Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
      Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
      Component: KOMBIINSTRUMENT VDD 1610
      Revision: V0003000 Serial number: VWZ7Z0F4068246
      Coding: 0007103
      Shop #: WSC 08212 444 54130
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Part No SW: 1K0 907 530 H HW: 1K0 907 951
      Component: J533__Gateway H12 0150
      Revision: H12 Serial number: 31001065180769
      Coding: 7D8F03600F000000
      Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
      Part No SW: 1K6 919 879 HW: 1K6 919 879
      Component: Kompass 001 0002
      Revision: 00001000 Serial number: 1225223T1DVE02
      Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
      Component: IMMO VDD 1610
      End ---------------------------------------------------------------------
      Modified by BenficaVW1 at 11:01 PM 2-19-2009
      Modified by BenficaVW1 at 11:23 PM 2-19-2009
    2. Member BenficaVW1's Avatar
      Sep 14th, 2007
      Ft. Bragg, NC
      02-20-2009 08:57 PM #2
      anyone have any ideas?
    3. Member BenficaVW1's Avatar
      Sep 14th, 2007
      Ft. Bragg, NC
      02-24-2009 08:11 AM #3
      For anyone's future reference..Turned out the fuel pump went bad. Warranty [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member BenficaVW1's Avatar
      Sep 14th, 2007
      Ft. Bragg, NC
      02-24-2009 06:19 PM #4
      Update. they replaced the fuel pump under warranty but it ended up not being the problem at all...turns out they ecu/ecm is fried...its putting out 14+ volts when it should only be doing 2.4 volts and i will be needing to replace it (not under warranty)...ill continue to keep this updated for anyone's future reference
    5. Member BenficaVW1's Avatar
      Sep 14th, 2007
      Ft. Bragg, NC
      02-26-2009 09:05 PM #5
      opened up the ECU/ECM, looked like some kind of moisture got inside and caused a short in the ecm.
