VWVortex.com - my 16v rebuild thread
    Page 1 of 27 1234511 ... LastLast
    Results 1 to 25 of 659
    Thread: my 16v rebuild thread
    1. 02-20-2009 03:33 PM #1
      i cant seem to be happy with what i have
      as of now
      stock 9a bottom end
      p&p 2.0 16v head
      euro intake cam
      brospeed header
      brospeed 2.5 cat back
      lightened flywheel
      p&p intake
      gsxr 1000 itb's
      ms v3mrunning ms2e for fuel and spark
      im looking to make a bit more power NA
      i got my hands on a 1.8 16v head that i p&ped a good deal more than i did the last one.
      the idea with this head is to make the valvetrain as light as i can. i am going with a .5 oversized valve, ti retainers, high rev springs, light weight lifters. i want to cut as much weight as possible from the valvetrain and any other rotating mass.
      i am going to put a rather large cam in, probably a cat 275 or 279/268 set
      to cut more weight i will be going with a light weight cam gear, itr shaft gear and, underdrive crank pully.
      with this setup i hope to make about 200 at the crank ? may happen
      i am also thinking of building the bottom end
      but not sure what to do
      i will most likely go with a forged rod probably IE rods or scat
      but im not sure if i should buy pistons or just boost compression with a shorter head gasket
      Modified by vwjunkie42 at 7:03 AM 2-21-2009
    2. Awaiting Email Confirmation tomdooley's Avatar
      Feb 6th, 2007
      Rip City
      16v
      02-20-2009 04:43 PM #2
      i love powerful NA 16v's, exterior pics?
    3. 02-20-2009 04:48 PM #3
      befor
      after
      Modified by vwjunkie42 at 8:50 PM 2-20-2009
    4. Member veedubman91's Avatar
      Apr 5th, 2002
      PA
      1980 rabbit/ B8 a4
      02-20-2009 05:30 PM #4
      hell yes for itb's
      DCI
      contact Paul (need_a_vr6) for all your megasquirt needs
      PVW June 2010
    5. Geriatric Member VegasJetta's Avatar
      Jan 26th, 2003
      SoPo, Maine
      01 XJ 4.0, 13 TCH, 87 Honda TRX250, 82 Honda UrbEx, 85 Honda ATC70, 91 Yamaha YSR50
      02-20-2009 06:54 PM #5
      Is that chart Wheel HP or crank?
      Quote Originally Posted by JacksSenseOfRejection
      Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
    6. Member Ghost''s Avatar
      Aug 6th, 2008
      KTM
      02-20-2009 07:02 PM #6
      woow ! Happich and Westy at same time is POrno
      it need some wide wheels
      .:Let no man who is not a VAG owner judge the elements of my ride:.
    7. Senior Member ratdub's Avatar
      Jan 16th, 2005
      hamilton township, nj
      stock TSI & stage 2 FSI
      02-20-2009 08:30 PM #7
      if that graph is whp, i'm very impressed w/ the euro intake cam on itb's...
    8. Member PinkFloydPerson's Avatar
      Feb 3rd, 2003
      Quakertown PA 18951
      1999.5 Jetta 2.0, 1992 Corrado SLC, 76' CB360T, 07 TRX450R, The Sex Panther Sled.
      02-20-2009 09:05 PM #8
      very nice [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I'll be watching this
    9. 02-20-2009 09:19 PM #9
      just my opnion but I think your car would look amazing with ats classics [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Banned
      Jan 8th, 2009
      02-20-2009 09:22 PM #10
      run some 288 cat cams or TT cams for the hyrdo head. Awesome set up. more power then a stock VR and less money you have in that. I'ld wager to say it probably sounds better too... yes, I just went there
    11. Member mrbatavus's Avatar
      Nov 29th, 2008
      Ewing NJ
      2002 Chevy Trailblazer, 2002 Saturn L300, 2003 Saab 9-3 Linear
      02-20-2009 09:39 PM #11
      SWEEEEEET setup man, nice and clean [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      You could get some lighter wheels, lighter clutch (no idea how you would find out the weight of all the aftermarket clutches, unless you are happy with yours). Knife edged crank then balance everything. Thats all I can think of, good luck dude.
    12. 02-21-2009 02:55 AM #12
      that chart is wheel hp.
      and i have some wide wheels going on this spring
      i also have a set of 15in steels for dyno and track day, as the dials are a bit heavy.
    13. Senior Member skidplate's Avatar
      May 4th, 2004
      Beaverton, OR
      2012 Golf R 1990 Audi Coupe Quattro
      02-21-2009 05:39 AM #13
      I would go for the Cat 279/283 cams. Its looking pretty good so far.
      Flickr
      Quote Originally Posted by Mr. Knappy View Post
      We really need breeding standards like they have with dogs.
      Quote Originally Posted by pete@blackforest View Post
      I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
    14. 02-21-2009 06:22 PM #14
      so it looks like i am getting a new block. price too low to pass up. this is good cause i can build the bottom end without taking the car off the road.
      the new block will probably go .04 over. im am looking at je 11.3:1 83.5 pistons. i found some rods on ebay that i am thinking of getting? not sure but from the pic and almost word for word description they sound like IE rods but without the IE stamp. but about 100 bucks less. not sure what to do thats a pretty critical part to trust to ebay. they clam to be good up 650hp as i am only looking for 250 at the very most , it may be ok
    15. 02-25-2009 12:23 AM #15
      pistons on order i went with the weisco 11.3:1
      will be picking up the new block this week, gunna send the inter. shaft to be turned down
      tires and wheels on
    16. Member Broduski's Avatar
      Nov 18th, 2008
      Central NC
      87 Bronco, E34 525i, 78 W200, 91 LX 5.0
      02-25-2009 12:33 AM #16
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] for no stretch
      Quote Originally Posted by Crimping Is Easy View Post
      People always like to throw around words like "no" and "title" or "illegal" or "feds", but at the end of the day, they're just words.
    17. Member sixteenvalve's Avatar
      Jun 13th, 2002
      McMinnville, OR
      '11 JSW, '99 Passat, '80 Caddy 16V
      02-25-2009 12:54 AM #17
      Looking good!
      Volkswagen of Salem Parts
      /\/\/\ Ask me about 20% off all VW parts and accessories to Vortex members /\/\/\
      Flashover!!
    18. Member Road Boss's Avatar
      Jul 15th, 2004
      Crossville, TN
      84 VW Rabbit GTI, 84 VW Jetta Coupe
      02-25-2009 01:13 AM #18
      Looks real good! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member secondgen's Avatar
      Jan 9th, 2004
      Stuff with wheels
      02-25-2009 01:18 AM #19
      Yawn, but sweet coupe in the background.
      Proud Customer of Phenix Engineering
    20. Member drewmk2's Avatar
      Jul 22nd, 2008
      West Seattle/ Pullman, Wa
      ly3d mk2 gti 16v (gone) e36 m3
      02-25-2009 01:27 AM #20
      I'd be happy with that motor ^ but thats just me.
    21. Member vwbeaner's Avatar
      Jun 4th, 2007
      N/E WI
      '01 Tahoe, '08 STi
      02-26-2009 04:54 AM #21
      what adapters are you running for those phonedials?
      -Ben
    22. Member secondgen's Avatar
      Jan 9th, 2004
      Stuff with wheels
      02-26-2009 10:07 AM #22
      Quote, originally posted by vw****** »
      Custom offset ones from Alloys-R-Us. He'll chime back in on the exact offsets, as I don't remember. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Member Kritter's Avatar
      Jun 7th, 2001
      Toronto, ON
      '06 Passat B6 Sedan 2.0T 6MT | '01.5 PAssat B5.5 4Motion Wagon | '92 MK2 GTI VR6T (WIP)
      02-26-2009 10:55 AM #23
      Quote, originally posted by vwjunkie42 »
      <img title="This image has been resized. Original size: 1024x768" style="border: 1px solid rgb(95, 95, 95); max-width: 800px;" src="http://i306.photobucket.com/albums/nn243/luvmygti/P2240083.jpg" border="0" height="600" width="800">
      15's or 16's ? Looks great [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      VAGKRAFT
      2006 VW Passat 2.0T 6MT | 2001.5 VW Passat V6 4Motion Wagon | 1992 VW GTI VR6T 5MT
      R.I.P. John Di Battista1979-2014
    24. Member secondgen's Avatar
      Jan 9th, 2004
      Stuff with wheels
      02-26-2009 11:12 AM #24
      16" w/ ECSTA AST KU25 205-40 tires front and rear.
    25. 02-26-2009 01:41 PM #25
      the wheels are 16x7 fronts et53.7 and 16x8 rears et53.7. adapters are, as jer said from alloys-r-us. the guy there was pretty cool. the fronts are 22mm and the rears are 24mm. so et31.7 and et29.7
