Monsoon single din head unit.
T8 black connector (car harness)
1 Brown/Blue (Alarm) or Blue/White (Vol Adj) *
2 Yellow (Telephone Mute)
3 White/Blue (AKTIV power signal) or Blue/White (K-wire) *
4 Brown/Red (Switched Power) *
5 White (Power Ant) or Black (Amplified Ant) (Power Antenna or SAFE) *
6 Gray/Blue (Illumination) *
7 Red/White (Constant Power) *
8 Brown (Ground) *
and if your oem T8 harness is all cut up.
T8 Black connector (OEM HU harness)
1 org/red - signal for anti-theft alarm system = Alarm dont need *
2 open
3 gry/wht - data link connector (DLC) K-wire = provide with an always on 12V source if no (DLC) K-wire from car *
4 yell/red stripe - ignition switch - S contact = Switched Power *
5 red/wht stripe - battery, positive (B+) supply terminal 30 (control input for "safe" display/anti-theft) = constant power *
6 blu/gry stripe - illumination, terminal 58b = illumination switch *
7 red/wht stripe - battery, positive (B+) supply terminal 30 = constant power *
8 brn - battery, negative(-) ground supply, terminal 31= ground *
The THREE POWER WIRES on the green(speaker out) connector ov the monsoon Amp. Pins are 18, 21 & 23. Which are constant or switched power lines? = was told they all get constant power since the amp is switched on & off through a speaker wire.
Modified by dworkz at 2:08 AM 3-23-2009
8 Brown (Ground) *
2 open
