Page 1 of 2 1 2 LastLast
Results 1 to 35 of 58
Thread: Serpentine Belt Conversion - KITS , AVAILABILITY & FAQ
  1. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-28-2009 12:37 PM #1
    Temporarily creating this thread for now so that I can update it later on this week when the belts arrive.I will be providing part #'s as well as a break down of every single kit avaialble for serpentine conversion.Will also include the pros and cons of each set up and what direction you should/could take.If you guys want anything in the thread please throw in your suggestions
    Quote Originally Posted by ABA Alternator kit
    Alternator OEM Part #:
    Alternator Aftermarket Part #:
    Alternator Bracket Part #: 037 903 143 G
    Alternator bracekt tensioing arm Part # : 028 903 308 C
    BELTS:
    If you are using a MKIV 1.8T/2.0 8V Crankshaft accessory pulley or an ABA unit then you will a 6PK-1153 Belt.
    If you are using an AAZ 1.9TDI Crankshaft accessory pulley (Part # 028 105 243T) then you need a 6PK-1185 Belt.
    Quote Originally Posted by ABA NON-AC Alternator kit
    Quote Originally Posted by AFN Alternator kit (preferred for Diesel's)
    Quote Originally Posted by ABF Alternator kit (preferred for Diesel's / ITB's and in general all fitments)
    • Alternator OEM Part #: 028 903 029 M
    • Alternator Aftermarket Part #: AL0185X
    • Alternator Bracket Part #: 029 803 143 AD
    • Bracket spring Part #: 028 903 329
    BELTS:
    If you are using a MKIV 1.8T/2.0 8V Crankshaft accessory pulley or an ABA unit then you will a 6PK-894 Belt.
    If you are using an AAZ 1.9TDI Crankshaft accessory pulley (Part # 028 105 243T) then you need a 6PK-923 Belt.
    Quote Originally Posted by European Alternator Kit
    BELTS:
    BOLTS:
    (1) 028 260 821 - M8 x 1.25 x 64mm doubled ended stud (upper left of water pump)
    (1) 028 260 821 D - M8 x 1.25 x 40mm bolt (upper right of the water pump)
    (2) 028 260 821 A - M8 x 1.25 x 92mm doubled ended stud (lower left & right of water pump)
    Difference in crank snout : 0.549 - 0.312 = 6.0198mm
  2. Member veector's Avatar
    Mar 1st, 2006
    Southern Onterrible
    81 Jetta 1.6D
    02-28-2009 01:16 PM #2
    16V with carbs serp, good idea BTW
    Peter Broggs - African Sister
    [ ][ ]====W==D=[ ][ ]
  3. 02-28-2009 02:23 PM #3
    1.6 Turbo Diesel w/ A/C
  4. Member tech9's Avatar
    Nov 26th, 2007
    Neffsville, PA
    03 Explorer 54 F100 00 golf (rallied out!)
    02-28-2009 03:32 PM #4
    awesome
  5. Member jaybonius's Avatar
    Apr 10th, 2007
    Dallas / Acworth
    91 Cabby
    03-03-2009 01:22 PM #5
    16V with all accessories on a single belt.
    Make the round parts round, and the flat parts flat, hopefully it won't fly apart!!!
  6. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    03-08-2009 08:16 PM #6
    Quote, originally posted by jaybonius »
    ac and power steering?
  7. Member jaybonius's Avatar
    Apr 10th, 2007
    Dallas / Acworth
    91 Cabby
    03-10-2009 12:43 AM #7
    yeppers
  8. 03-11-2009 06:32 PM #8
    Are you planning to build a kit for a 1992 Jetta with A/C and power steering? Thanks.
  9. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    03-11-2009 08:48 PM #9
    Quote, originally posted by runitonoil »
    Thats what the ABA kit is for.I will be showcasing that one.
  10. 03-11-2009 09:45 PM #10
    Thanks.
  11. 03-18-2009 06:48 PM #11
    More info for a 1.8L 16V PL block.
  12. 03-19-2009 09:26 PM #12
    Where can I see information on the AFN kit?
  13. Member pho's Avatar
    May 9th, 2007
    NAYARIT
    03-20-2009 02:09 AM #13
    really interested.
  14. Member vwpieces's Avatar
    Apr 20th, 2002
    Allentown, PA
    83 TD Jetta, 68 Bus, 83 2dr Jetta 16V, 1971 Kawasaki H1 500
    03-20-2009 08:03 AM #14
    Quote, originally posted by BioDieselVW »
    And another
  15. 03-20-2009 12:53 PM #15
    i have a 1988 16v scirocco that has a a/c elliminator kit on it and another one that is a/c , and a 3rd that will be a 2.0 91 jetta 16v into a 1986 scirocco with a turbo kit ,
    looking if u got the right kits , starting with the 88 , can post pic of the a/c eliminator kit current belt and pully's if needed
  16. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    03-28-2009 02:11 PM #16
    Quote, originally posted by vwdude2 »
    I will post all of that
    finishing it up now
  17. Member DarthGarry's Avatar
    Jul 24th, 2007
    Albany, NY
    1981 Pickup, 2009 Sportwagen
    03-28-2009 09:20 PM #17
    x2
  18. Member pho's Avatar
    May 9th, 2007
    NAYARIT
    04-08-2009 02:10 PM #18
    waddup?
  19. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-08-2009 05:42 PM #19
    Quote, originally posted by pho »
    waddup?
    Making the adapters and such as well as waiting for some belts to come in from contitech
  20. 04-08-2009 06:15 PM #20
    So, are you going to list what kits will be available and some pricing to go with it?
    Or, have I missed that some where?
  21. 04-18-2009 05:32 AM #21
    1.8L 8v JH motor with a/c, but no power steering... are you creating any kits for these engines?
  22. Member
    Jun 28th, 2004
    Centre Hall, PA
    '12 GLI Autobahn, 81 Rabbit 1.6TD, Dodge Ram (400hp, 14mpg)
    04-24-2009 06:25 AM #22
    ...And w/o a/c
    Its hard to source salvage yard alternator brackets and the needed pulleys when your in a no v-dub town. If i have to order them from the dealer, i'd rather go your route
  23. 04-28-2009 02:32 PM #23
    ABA with A/C but no PS in a MK1
  24. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-28-2009 04:23 PM #24
    Quote, originally posted by ifUcantBEAT’m.... »
    So all on 1 belt
    doable with an idler pulley in there.
  25. 04-28-2009 07:31 PM #25
    Quote, originally posted by Issam Abed »
    So all on 1 belt
    Do you sell said set-up? what parts would I have to source?
  26. 04-28-2009 07:32 PM #26
    Ok,
    I need the serpentine setup NOW, or I have to find another serpentine alternative. Mine snapped a bolt and has ruined V-Belt hardware . It is a daily driver (150 m per day) and I am losing money driving other cars . Can you deliver soon, or do I look for another serpentine source?
    1.9 TD AAZ with AC, powersteering in a 1981 VW MK1 pickup.
    Wayne
  27. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-28-2009 07:46 PM #27
    Just an idler pulley and place it on the lower alternator bolt.That should create the loop you need
  28. Member deepgrooves74's Avatar
    Aug 2nd, 2006
    Rockland County, NY
    1984 VW Rabbit 1.6 GTD, Now Buying 2013 JSW TDI, Sold my 2004 WRX Wagon
    05-03-2009 07:57 PM #28
    Ok I guess this makes x3 on this request as well
    Modified by deepgrooves74 at 6:33 AM 8-27-2009
    Never once go back and add up the amount you spent to finish your car...
    will you still think it is worth it? Is it ever done?? Then once it breaks down again???
    http://forums.vwvortex.com/showthrea...t-TD-SVO-Build
  29. Member deathhare.'s Avatar
    Apr 1st, 2008
    TN
    06-03-2009 10:01 AM #29
    Quote, originally posted by deepgrooves74 »
    except w/o the a/c.
    Mine is bare bones, but is a 1.6 TD...
    Is it possible to put this together?
    Thanks!
    Apparently you can use the ABF bracket and alt but you can also use the TDI stuff.
    The latter being the cheaper option as you can probably get it used as opposed to the ABF parts.
  30. Member PoVolks's Avatar
    Oct 2nd, 2003
    Atlanta
    2000 S4, 1981 _________________Scirocco
    06-29-2009 01:19 PM #30
    I got my ABA ready for a JH head. No a/c, no pwr steering. Men don't need these things anyways!
    So i will use a
    -Mk3 alternator (with harness...?) 90amp i believe
    -VR6 waterpump pulley
    -stock ABA crank pulley
    I am confused on the belt size. My wholesale source only has no a/c with pwr steering, and one for both. Not one available for neither?
    Any ideas? Or changes I could make to make it more better>?
  31. 06-29-2009 01:28 PM #31
    mk1 16v no a/c or ps.
  32. Member
    Nov 21st, 2006
    84 Diesel Rabbit - daily driver
    06-29-2009 04:32 PM #32
    1.6L diesel w/ AC and no power steering. (normally aspirated, non-turbo)
    84 Rabbit. Possible ?
  33. Member
    Jun 26th, 2004
    Conn.
    '93 cabriolet/'94 Jetta/'02 Audi A4
    07-10-2009 09:38 PM #33
    Okay, so what is the status of this project? Have created your desired stock of products? I'm looking to keep all my accessories(e.g. P/S & A/C) and would like to use a serpentine belt. Do you offer a package, do I source an ABA set-up or a combination of both?
  34. Member nick526's Avatar
    Sep 29th, 2006
    Los Angeles, CA
    78 Rabbit ABF, 96 GTI VR6, 89 BMW 325i, 91 Mitsubishi Mighty Max
    07-15-2009 05:50 PM #34
    Hey, can someone help me out? I'm trying to figure out where the spring "tension clip" part goes on the non AC ABF setup. I've got the bracket and alternator but I haven't sourced the spring part yet because I'm not sure I'll need it.
    The parts explosion diagrams I've seen make me think the lower bolt goes through the spring, maybe Anyone have a picture?
    EDIT
    Nevermind, figured it out
    Modified by nick526 at 10:01 PM 7-15-2009
    RIP: Mk2 jetta (stolen ), Mk4 jetta (side-swiped, totaled ), Mk4 GTI (totaled by teenage girl )
  35. Member g60vw's Avatar
    Oct 3rd, 2002
    Anchorage, AK
    83/4 Rabbit w/ 2067cc 16v, 75 4dr ST, 85 4kQ for DD'n, F-350 haulrig, and Richard Pryor
    08-03-2009 06:22 PM #35
    Quote, originally posted by NA 8v for life »
    This.
    Quote Originally Posted by wilm13 View Post
    I refuse to say anything but A1, A2 and A3. As far as I am concerned VW stopped making cars after that.
