VWVortex.com - fuel pump reset switch
    Results 1 to 9 of 9
    Thread: fuel pump reset switch
    1. 02-28-2009 02:53 PM #1
      is there a fuel pump reset switch on a 92 jetta gl? if there is, where is it?
    2. Member Burnitwithfire's Avatar
      May 14th, 2005
      Quebec, Canada
      2005 Legacy GT LTD 1992 Miata sunburst yellow
      02-28-2009 03:05 PM #2
      Wait, what?
      Quote Originally Posted by SAV912 View Post
      Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
    3. Geriatric Member VegasJetta's Avatar
      Jan 26th, 2003
      SoPo, Maine
      01 XJ 4.0, 13 TCH, 87 Honda TRX250, 82 Honda UrbEx, 85 Honda ATC70, 91 Yamaha YSR50
      02-28-2009 04:50 PM #3
      Wait, what?
      Quote Originally Posted by JacksSenseOfRejection
      Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
    4. Senior Member Mr. Knappy's Avatar
      Oct 10th, 2006
      Levittown, PA
      1991 GTI 16v
      02-28-2009 04:58 PM #4
      Yea, the key.
    5. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      02-28-2009 05:17 PM #5
      People around here don't get around much...
      Both my Fords have had this. it's a rollover/crash sensor switch that cuts the pump. Mk2s don't have this though. The fuel pump relay switches off when the engine stops turning as a safety feature.
      If your fuel pump isn't running, the relay, wiring, or pump itself is bad. In some cars, the ECU switches the pump on so the ECU might be at fault as well.
      Modified by VDub2625 at 5:19 PM 2-28-2009
    6. Geriatric Member VegasJetta's Avatar
      Jan 26th, 2003
      SoPo, Maine
      02-28-2009 05:21 PM #6
      Quote, originally posted by VDub2625 »
      I remember some jock *******s in high school that had 5.0 mustangs, we would walk through the parking lot and punch the area where that kill switch was when they were in class, then sit and wait to see how long it would talke them to figure it out
    7. Senior Member ratdub's Avatar
      Jan 16th, 2005
      hamilton township, nj
      stock TSI & stage 2 FSI
      02-28-2009 05:39 PM #7
      Quote, originally posted by VegasJetta »
      so you were the mother f'er!
      Jun 1st, 2007
      Not Present.
      Newest, 92 GTi half-swap plus
      02-28-2009 06:45 PM #8
      That's a new one on me... Fails have them so they must be good and every car has the same.
      Welp, you read my signature line.... that's enough social interaction for me today. Thanks for participating.
    9. Member 86roccophoenix's Avatar
      Jul 6th, 2007
      North Canton, Ohio 44720
      02-28-2009 07:49 PM #9
      It's an inertia switch that kills the fuel pump and coil in an accident (basically a ball bearing hitting a t lever). Some are located up on the passenger side foot well (All this refers to older Fords). Our cars do not have these.
      CHECK OUT MY 91 CORRADO G60 PART OUT THREAD http://forums.vwvortex.com/showthrea...Northeast-Ohio
