Results 1 to 20 of 20
Thread: DIY: Removing the lock cylinder from ignition housing.
  1. Member s-rocc's Avatar
    Nov 26th, 2001
    reassembled in a garage, pa
    bunch of old german junk
    03-05-2009 12:25 AM #1
    This is something that seems to come up fairly regularly,and the response is always "get a bentley" or "search." And, if you search, all the results say "get a bentley."
    Well, I have a Bentley, and frankly their description on how to do this sucks. It gives basic info and a very vaguely drawn "technical" drawing that you are instructed to follow. A rare miss as far as the manual is concerned.
    Anyway, I am currently swapping a 1987 gti to ce2 wiring, and thus have to swap the ignition housing to use the ce2 style turn signal stalks, but wanted to keep the same key. So, it was necessary to get the original lock tumbler out of the ce1 ignition housing and put it in the ce2 one that I got from the yard.
    Tools needed:
    -Drill
    -1/8" drill bit
    -Meauring device
    -Awl, or some sort of pointy device to push the retaining spring down
    -Vice is pretty useful
    First get the ignition housing out of your car, if you have trouble doing that, you may not want to attempt the rest of this Now pull off the black plastic surround by the key hole. It'll probably break, or, at least, mine did.
    Looking at the top of the housing (the top has two mounting screw holes for the turn signal stalks), find the end of the collar that goes halfway around the housing. Now, look for a seam line from where the piece was molded together.
    (picture was taken after I had the tumbler out)
    You want to find the point that is exactly half way between these two landmarks and draw or scribe a line here. This is going to be one of the dimensions you need to find out where to drill your hole.
    Now, you need to find the next dimension. This one is a bit easier, because it is about ~1/2" in from the edge of the housing. Measure from the edge of the housing, not the edge of the lock tumbler (it sticks out beyond the housing).
    (again, lock tumbler is already out in this pic., red dot is where you want to drill, ignore my scribed line, I estimated wrong on my first try )
    Now that you have your point marked, it's time to drill a hole. Use a 1/8" bit and go slowly. The metal you are drilling through is only about 1/8" thick and drills very easily (aluminum maybe?). If you drill too far, you will destroy your lock cylinder.
    When you feel the drill break through, stop and look in. You should be able to see a piece of steel inside the hole, this is the retaining clip.
    This clip fits into a small recessed area insde the ignition housing.
    Once you've spotted the retaining clip inside the hole, get your awl or whatever pointly implement you are going to use and push in the hole against the retaining clip. As you are doing this, pull out on the tumbler. With any luck, it will pull out of the housing while you hold down the clip.
    This took me two tries to get right. The first housing I used got destroyed. I then used a cutoff wheel to disect it and figure out how to do it so I wouldn't ruin my good lock cylinder. I'm not responsible if you mess up your car of hurt yourself in the process. Good luck.
    fixed some typos
    Modified by s-rocc at 10:42 AM 3-5-2009
  2. Senior Member Mr. Knappy's Avatar
    Oct 10th, 2006
    Levittown, PA
    1991 GTI 16v
    03-05-2009 01:00 AM #2
  3. Senior Member skidplate's Avatar
    May 4th, 2004
    Beaverton, OR
    89 GTI 90 Audi Coupe Quattro 06 Xterra
    03-05-2009 01:09 AM #3
    Nice write up.
    Flickr
    Quote Originally Posted by Mr. Knappy View Post
    We really need breeding standards like they have with dogs.
    Quote Originally Posted by pete@blackforest View Post
    I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
  4. Member 8V Fury's Avatar
    Jul 26th, 2003
    roseville, california
    2004 vw jetta wagon, 1990 vw jetta coupe
    03-05-2009 01:17 AM #4
    This should be a sticky.
    Quote Originally Posted by Ron@RMAMotorsport View Post
    real deal<p>After spending two months in the mk3 forum it drove into the woods and set fire to itself.
  5. Senior Member cyclops594's Avatar
    Sep 28th, 2005
    NorCal(Mudville)
    1991 Jetta GLI 16V
    03-05-2009 01:21 AM #5
    nice! this question does pop up a bit.
    good work man.
  6. 03-05-2009 04:45 AM #6
    Sorry for my bad english, but I hope that you fill me in with the missing words..
    Anyhow, some idiots decided to break in to my car, destroy the "wheel lock"? and drive it like 250 yards..
    So, they've also destroyed the plastic around it(no big deal) and the steering rack is a bit "skew", or out of place a bit.
    So, if I do this, and take the lock cylinder out, and get me another ignition housing, is it possible to remount my old lock cylinder, and will the "wheel lock" also be fixed?
    As it's now, I'm kinda scared to drive around like this, because the steering rack feels kinda loose, and the "wheel lock"(please what's the right name?) are broken, but makes clicky sounds when I drive...
    Asking because I've never done this before...
    Oh, I have a manual too, but the only thing I understood is where I should drill that hole..
    Thanks for help!
  7. Member s-rocc's Avatar
    Nov 26th, 2001
    03-05-2009 10:49 AM #7
    i believe the word you are looking for is "column lock," but i knew what you meant. the piece that actually locks the column in place is part of the ignition housing. it is locked and unlocked by turning the key.
    in your case, it sounds like you need to replace the entire housing. as long as they didn't destroy your lock cylinder you can use these directions to swap your cylinder into a new housing.
    not sure if that would solve your problems or no without knowing exactly what damage they did to your car.
  8. Member s-rocc's Avatar
    Nov 26th, 2001
    03-06-2009 04:53 PM #8
    did it again with my new (used) ce2 housing, and dropped my lock tumbler in it. i'm getting good at this now.
  9. 03-06-2009 04:57 PM #9
    Quote, originally posted by s-rocc »
    You still smell like cheese, but at least you cut your hair
  10. 03-10-2009 01:19 PM #10
    Thanks for the write-up, been looking at this for a few days...lost my key a week ago and steering was locked, tried taking off ignition housing without breaking it, no go. Bentley has the illustration as well, which is what i used for measuring. Took me all of 5 minutes to get it out, .
  11. 07-31-2009 03:45 AM #11
    This really came in handy. I busted my head for a while trying to figure out how to get this thing out. Thanks!
  12. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    07-31-2009 03:49 AM #12
    I used this thread to do mine a few months ago.
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
  13. Member Joel Goodson's Avatar
    Feb 24th, 2009
    North of Philly
    '92 4dr Golf - '01 A4Q - '12 Jetta SE
    07-31-2009 09:26 AM #13
    Quote, originally posted by fakeDE98 »
    What the hell do you know....
    NOTHING LEAVES STOCK
    ^^^General maintenance to high end custom builds.^^^
    ----COLLECTIVE EAST----
    ---Fifteen52---
  14. Member Breadfan5968's Avatar
    Mar 25th, 2007
    Holland, Europe
    1992 mk2 16v, 1986 mk2 1.6 auto
    11-18-2009 05:33 PM #14
    Subscribing to this one, cause I'll need it tomorrow.
    Thanks for the DIY!
    Note to self: http://www.4130-products.com/step/ign/index.htm
  15. Member MOTA BOY's Avatar
    Aug 21st, 2007
    Daruvar Croatia
    VW Golf MKII GTI KR(T) 1990
    03-27-2012 11:07 AM #15
    Great! Right on it!
  16. Junior Member mr.kyle.henderson's Avatar
    May 15th, 2012
    Cali
    1991 1.8L Volkswagen Fox, coupe.
    09-24-2012 11:40 PM #16
    good thread but quite frankly this whole procedure is bullsh*t
    what the hell was vw thinking when they made these ignition cylinders.
    At least they could have drilled the damn hole!
    good thread tho.
    best instruction so far.
    "Next time you have to go to work, why don't you try using a Volkswagen?"
    "The day you are done with it, Is the day you trade it for another."
  17. Member
    Aug 5th, 2003
    Northport, NY
    87 GTI, 01 GTI, 98 Ranger
    10-02-2012 11:40 AM #17
    Ive done this more times than i'd like to admit due to lost/mismatched keys...
    Never had to remove it from the car, i've always just removed the steering wheel an clamshell and had at it
    : Tornado Red '87 GTI 8vT, Toreador Red '98 Ranger XLT
    : Rave Green '01 GTI GLS
    '01 Catera, '90 GLI 16vT, '94 850 Turbo, '90 Golf, '89 Golf, '90 Mustang LX, '91 Jetta, '88 9000S, '86 Jetta, '91 Continental
  18. Member A2brb's Avatar
    May 29th, 2003
    Louisville, Ky
    91 GTi VR6-t, 91 Jetta Carrat
    10-07-2012 08:39 PM #18
    Quote Originally Posted by L33t A2 View Post
    My ignition tumblers are starting to fail as well. Sometimes it works and then other times I have to sit there and jiggle the key for 30 minutes. Like the aforementioned, I don't see why one has to remove the lock cylinder housing to remove the lock cylinder. There is enough clearance to drill the hole after the stalks and plastic column shell is removed.
    Thanks for making this threadn s-rocc. Much easier with the pictures you took the time to post.
  19. Member The Janitor's Avatar
    Jan 24th, 2011
    Vancouver BC
    1987 Jetta
    10-07-2012 09:05 PM #19
    Or you could use a thin strip of metal, and unlock the cylinder through the feed lip that's connected the retainer groove... just saying.
  20. Member A2brb's Avatar
    May 29th, 2003
    Louisville, Ky
    10-10-2012 01:04 PM #20
    I found these videos helpful on YouTube. For a Vanagon but same concept.
    Part 1 - Drilling the release access hole: How to remove the lock cylinder.
    http://www.youtube.com/watch?v=MpoLrbNFSl4&feature=plcp
    Part 2 - Removing the Lock Cylinder Housing: How to remove the lock cylinder
    http://www.youtube.com/watch?v=APAn9s1CdSM&feature=plcp
    Part 3 - Removing the Lock Cylinder: How to remove the lock cylinder
    http://www.youtube.com/watch?v=KWG5rclBHcw&feature=plcp
