VWVortex.com - P0117... bad coolant sensor?
    Results 1 to 6 of 6
    Thread: P0117... bad coolant sensor?
    1. 03-11-2009 12:27 PM #1
      I recently got a CEL and scanned it with a buddy's OBDII reader. The code it gave me was P0117 which according to the book is "coolant temp circuit low" So I take it the coolant sensor needs to be replaced. Car drove fine while the light was on for the last few days, but this morning it would not start. It would crank, but wouldn't catch and if I gave it gas it died. It would also idle really rough and would sputter if I gave it gas. Is there anything else that could cause the problem or is it the coolant sensor that is bad?
    2. Member 96vwgtiracer's Avatar
      Mar 5th, 2004
      mk3 vw gti 2.0, b5 audi S4
      03-12-2009 12:20 PM #2
      definitely the sensor happened to me about 3 months ago i changed the sensor myself and everything is fine. here is a link to the part your gonna need.
      http://www.ecstuning.com/stage...=1484
    3. Member PZWOGIV's Avatar
      Nov 3rd, 2001
      South Jersey
      mk3 VR6 Jetta, 04 S4 avant, 00 S4, too many vw's
      03-19-2009 05:29 AM #3
      or you can save a couple of bucks and get the coolant temp sensor from Germanautoparts.com.....
    4. 03-19-2009 01:45 PM #4
      got it from JHM overnight for $20. car is all good now.
      Modified by knvs at 6:46 PM 3-19-2009
    5. Member vrbwoy's Avatar
      Aug 8th, 2011
      bridgeport, ct
      99 lexus es300, GMC yukon, MK3 jetta vr6
      12-06-2012 05:37 PM #5
      Thank God for this thread.... Ive been searhing for this answer for months.... I have the same problem as the op...
    6. Member vrbwoy's Avatar
      Aug 8th, 2011
      bridgeport, ct
      12-11-2012 10:11 AM #6
      I cant believe how important a frigin coolant temperature sensor is...
