Results 1 to 33 of 33
Thread: Blowing T3 Gaskets? here's the solution!
  1. 03-13-2009 01:14 PM #1
    In a previous thread, Silvercar suggested the Nissan OEM t3 gasket. I Went down to the dealership and picked one up, and its freakin awesome. Super super thick, looks strong, cheap ($14) and best part, re-usable! That's right, they are meant to be re-used!
    Beats the thin ATP steel ones.
    Here's a picture:
    It's for a Turbo Z31 300zx I believe, part number : 14415-4P200
    [img][/img]
  2. Member LightSwitch's Avatar
    May 8th, 2008
    Seattle
    2001.5 A4QTM
    03-13-2009 01:20 PM #2
    Nice find.
    2001.5 A4 1.8TQM Stage 2
    034/Apikol Mounts throughout the car/Neuspeed RSB
    AWE DTS/JHM SS/JHM solid linkage/JHM Delrin Stabilizer Bushings/034 weighted knob
    ST Coilovers/cayenne BBK/ V710's /Thor Skid Plate
    9.5:1 2.1L stroker/built AEB/Pag Billet 3071R .72 A/R... under construction
  3. 03-13-2009 01:23 PM #3
    There's also a T25 version from the Z32's. But the easiest solution is to not run a gasket.
  4. 03-13-2009 01:29 PM #4
    You think I trust ATP's casting? I don't have time to deck the turbine housing inlet.
  5. 03-13-2009 01:29 PM #5
    vband my man...only way
  6. Member Durbo20vT's Avatar
    Apr 30th, 2006
    Shkodra, CT
    1989 Mercedes 300SEL 1986 Chrysler Laser XT
    03-13-2009 01:31 PM #6
    i went through 2 of the nissan gaskets before going gasketless. now i am a believer
    the nissan gaskets are strong as hell though! withstand a beating and work quite well if the turbo is supported.
  7. 03-13-2009 02:11 PM #7
    Quote, originally posted by infinityman »
    Machining you mean?
  8. 03-13-2009 02:12 PM #8
    Quote, originally posted by Adam@Unitronic.ca »
    Machining you mean?
    Whatever.
  9. Member iae21's Avatar
    Feb 7th, 2002
    Staten Island, New York
    03-13-2009 02:29 PM #9
    Quote, originally posted by Durbo20vT »
    what do you mean by "supported"?
  10. Member Durbo20vT's Avatar
    Apr 30th, 2006
    Shkodra, CT
    03-13-2009 02:29 PM #10
    meaning if the turbo is braced.
  11. Member NOLA_VDubber's Avatar
    May 23rd, 2007
    New Orleans
    98 M3
    03-13-2009 02:37 PM #11
    I have a question, were you blowing gaskets or were your studs backing out then blowing gaskets?
    I ask cause I have yet to have a problem with blown gaskets *knock on wood* and i hope its because i have nordlocks on everything
    Oh, and i'm gonna go check for those plugs right now
  12. 03-13-2009 02:39 PM #12
    I've been running one the atp one are POS and it cracks causing major leakeage! This thing is thick and pretty much indestructible..
    01' BT Jetta
    Disco Potato Club
  13. 03-13-2009 02:39 PM #13
    Quote, originally posted by NOLA_VDubber »
    Thanks man!
    Studs backing out then blowing gaskets, but I think i have the stud/situation figured out now.
    I also use nordlocks, since then I havn't had a problem. But I am swapping turbos next week, so I picked up this gasket to use instead of the cheap ATP one.
  14. 03-13-2009 02:42 PM #14
    Here is the part # part # 14415-17M00 for the T25 people mani crew.. Its from 94-95 300zx twin turbo..
    01' BT Jetta
    Disco Potato Club
  15. Member vdubguy97's Avatar
    Sep 13th, 2003
    Sunshine State
    20th
    03-13-2009 05:46 PM #15
    x2
    Speed Kills.Save Your Life.Drive a Honda.
    Shearer Fabrications.Garrett/HTA.Southbend.INA Engineering. Integrated Engineering.JE Pistons.Gonzo Tuning.Precision.Autotech cam.
  16. 03-13-2009 06:02 PM #16
    lol i did. was tired of stuff leaking took a day out and sorted some stuff out. happy i did
    http://www.pagparts.com/
    # 1 in the business PAG-PARTS!!!!!!!!!!!
  17. Member
    May 27th, 2004
    Long Island, NY
    04.5 PG GLI
    03-13-2009 07:08 PM #17
    same here. no gasket but had the ATP flanges milled flat. clark did you go to colvin or w/e its called??
  18. 03-13-2009 07:13 PM #18
    yep.it was off by A LOT!.both turbo(4bolt) turbo (5 bolt) 5 bolt-vband and atp mani both head side and turbo side were off alot! but it fixed my problem and i have a leak free system.
  19. 03-13-2009 07:19 PM #19
    Added to FAQ
  20. 03-13-2009 07:27 PM #20
  21. Member 16plus4v's Avatar
    May 3rd, 2006
    Toronto
    '12 GTI
    03-13-2009 07:29 PM #21
    Hi temp silicone with milled flanges, 20k on this setup no problems. But a great alternative none the less. Good stuff !
    '12 CSG GTI - |DSG|LUX|TECH|SERRON|STG 2 APR|
  22. 03-13-2009 10:34 PM #22
    Nord Locks vs Locking Tabs?
  23. 03-13-2009 10:41 PM #23
    Quote, originally posted by cincyTT »
    Where can you find locking tabs? N
  24. 03-13-2009 10:43 PM #24
    034/INA
  25. Member Black Ice's Avatar
    Apr 26th, 2006
    Reston, VA
    02 Mk4 GTI
    03-13-2009 11:55 PM #25
    is this top secret or do we get to know what turbo? lol
  26. 03-14-2009 03:22 AM #26
    Quote, originally posted by krazygti »
    42r.
    3076r.
  27. 03-14-2009 05:46 AM #27
    I have been running Nissan OEM one off Z32 I think on apr stage 3+ for a few months...it blew up, i replaced it again with another Nissam OEM gasket (same piece) and I tightened bolts a bit more...have been fine since.
  28. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    04-22-2009 12:23 AM #28
    gonna snag one of these..i was using permatec copper on the turbo...got me 12k and 5 months with LOTS of driving
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  29. 04-22-2009 01:02 AM #29
    can you guys really hear it when you rip a gasket? I decided to run gasketless, but my idle is sort of funky, and i'm thinking it might have a small leak. I can't hear anything though, I'll try some seafoam...
    There are a handful of people on this forum keeping it real and are intelligent enough to build proper cars. Everyone else, keep wasting your money and time running around in circles following the herd.
  30. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    04-22-2009 01:05 AM #30
    i can deeff hear mine..but i have no sound deading properties to my car so i hear EVERYTHING ALL THE TIME lol
  31. 04-22-2009 02:55 AM #31
    anybody know where I can get this in the US and they do mail order to overseas..?
    thanks
  32. 04-22-2009 10:05 AM #32
    Quote, originally posted by robingohtt »
    thanks
    Nissan dealership! If you can't get one, i can go get you one and mail it to you.
  33. 04-22-2009 10:31 AM #33
    cool, can u help to get me 2?
    what is your paypal?
    Modified by robingohtt at 7:37 AM 4-22-2009
