Results 1 to 11 of 11
Thread: MkV Xenon Range -- Rear Level Sensor
  1. Member staulkor's Avatar
    May 21st, 2007
    Phoenix, Arizona
    2007 Fahrenheit GTI #776
    03-23-2009 06:00 PM #1
    Monday,23,March,2009,17:59:35:04256
    VCDS Version: Beta 812.4
    Address 55: Xenon Range
    Control Module Part Number: 1T0 907 357
    Component and/or Version: Dynamische LWR 0003
    Software Coding: 0000003
    Work Shop Code: WSC 01269
    2 Faults Found:
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation
    00497 - Sensor for Vehicle Leveling; Rear
    010 - Open or Short to Plus
    If I clear them, they come back. A few days ago my headlights were pointed at the ground. The next day they were pointed very high. They are still high, but atleast I can still see
    I just replaced the sensor and nothing changed!
    Please advise???
  2. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    03-23-2009 09:28 PM #2
    Assuming the sensor is fine, have you checked its wiring, connectors and installation yet?
  3. Member staulkor's Avatar
    May 21st, 2007
    Phoenix, Arizona
    03-24-2009 01:31 AM #3
    Yea, I checked the connector and it looks fine. No damage and its plugged in all the way. I replaced the sensor with a brand new one and the codes wont go away :/
  4. Member
    Jun 1st, 2003
    Dearborn Heights, MI
    2005.5 MKV TDI
    03-24-2009 06:51 AM #4
    Have you had any Suspension maintennance, or changes?
    If so, the leveling arm may hve been re-installed incorrectly.
    Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
  5. Member staulkor's Avatar
    May 21st, 2007
    Phoenix, Arizona
    03-24-2009 12:33 PM #5
    They are both pointing away from the car.
  6. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    03-24-2009 04:29 PM #6
    You don't check wiring and connectors just by looking at them. Grab a multimeter and perform proper testing. You also didn't answer the question if there had been suspension work done.
  7. Member staulkor's Avatar
    May 21st, 2007
    Phoenix, Arizona
    03-24-2009 05:18 PM #7
    Yes, different coils swapped on. We disconnected the sensors from the control arms.
    And by check wires, I thought you meant just visual check Ill grab my multimeter and bentley manual.
    Jun 1st, 2003
    2005.5 MKV TDI
    03-24-2009 08:39 PM #8
    Please read this, and cruise the MKV Forums for more information.
    http://forums.vwvortex.com/zerothread?id=4306095
  9. Member staulkor's Avatar
    May 21st, 2007
    Phoenix, Arizona
    03-24-2009 09:04 PM #9
    Both the front and rear sensors are pointed in the correct direction. Away from the car towards the driver door. Codes still remain and they cant be cleared. If I remember correctly, the measuring blocks say the front sensor is ~18% while the rear is a 0.0% since it doesnt see it.
    I haven't tested the wiring with a multimeter yet. I plan on doing that tomorrow afternoon.
    Modified by staulkor at 9:05 PM 3-24-2009
  10. 04-27-2012 12:26 AM #10
    Any solution for this issue? Was it wire harness issue?
  11. 04-27-2012 02:47 AM #11
    Open or Short tu PLUS is usually when is not connected correct.
    Activate needle illumination in ALL MICRONAS cluster since 2004 up to 2010. Activate STAGING for all NEC cluster since 2008 even if not availabe in adaptation chanel.
