VWVortex.com - R19 -vs- R30 insulation.
    Results 1 to 24 of 24
    Thread: R19 -vs- R30 insulation.
    1. 03-28-2009 12:37 PM #1
      Insulation experts!
      I've been renovating parts of my home over the last year, and am finally rounding third base on my kitchen/dining room.
      Over the ajoined rooms is a vaulted ceiling. (No attic...just your ceiling joists with insulation between them, and your roof) The drywall was cracked and there were some leaks in the roof, so I went ahead and removed all the old drywall and fixed the leaks, etc. Now, before I replace the ceiling, I've got all the insulation exposed and I've noticed that it's R-19.
      Would it be worth replacing the R-19 with R-30? It's about 5-600 square feet of vaulted ceiling. So if my calculations are correct we're talking around 200 bucks and about a half days work?
      Am I wasting a Sunday and 200 bucks?
      Also, if I do go with the R-30, would it be worth taking all the old R-19 and layering it up in the attic over the existing insulation?
      Thanks in advance. I'll post pics in a mega renovation thread when I'm all done with everything.
    2. Member jerk's Avatar
      Aug 28th, 2000
      Idaho
      03-28-2009 01:15 PM #2
      I'm no insulation expert, but I think $200 sounds pretty cheap in the grand scheme of things. You're getting a much higher R value and you're there already. As far as re-using your R19 over existing insulation, I don't know.
    3. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      11 328i Touring, 16 Colorado Crew, Versys, 2017 Barracuda
      03-28-2009 04:24 PM #3
      Is the R-19 still in good shape; not crushed or collapsed? Would there still be enough space for both R-19 and R-30 in the same cavity, and leave space for air venting? I believe crushing the insulation together decreases it R value. So if R-19 is designed for 3 1/2" and R-30 is designed for 5 1/2", and you still need an inch or so for ventilation of the plywood, you need to have at least 10" rafters. Do you have that?
      Touareg Audio Accessories - Keyless Start - Paddle Shift
      If you use Tapatalk, you aren't seeing the whole message. Tapatalk shortens GIFs, cuts URLs and deletes signatures.
    4. 03-28-2009 05:24 PM #4
      Quote, originally posted by spockcat »
      the R-19 appears to be in *okay* shape. Some of the backing has become a little brittle and has peeled off, but overall, it's not too bad.
      I just got back from HD, and now I know why they went with R-19. The ceiling joists are only 2x6's with 1" ferring(sp?) strips....so 7" total depth. The R-19 is 6.5" thick, the R-30 is 9.5" thick.....so yeah, to your point, to get R-30 in there, you'd have to compress it, which could completely void any additional benefit?????
      I think I'll just patch up any strips of the R-19 that look bad, as long as I have easy access, and I'll live with it.
    5. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-28-2009 10:33 PM #5
      foam. worth it in the long run.
      2015 VW Jetta S
      *in need of second car.
    6. 03-28-2009 11:59 PM #6
      Quote, originally posted by InSaNeBoY »
      Might be, but if you're talking about the spray-in foam, it won't work in this application. I'm dealing with cathederal ceilings, not a traditional attic. I need something I can staple up and then cover with drywall or ceiling panels, etc.
    7. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-29-2009 09:30 AM #7
      this will be drywalled one day...
      2015 VW Jetta S
    8. 03-29-2009 10:17 AM #8
      Whoa...
      More details, please!
      Is it a DIY type project? How expensive is it? How is it installed, etc, etc, etc...
    9. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-29-2009 02:35 PM #9
      I had an insulation contractor put it in, it's not cheap and not a good DIY. doing my whole house was $5k *but* I used to burn 1200gal of oil a year, now we're down to 550gal. So it's well worth the cost [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      2015 VW Jetta S
    10. Member DiscoStu's Avatar
      May 8th, 2001
      MA
      2010/VW/Passat - 2014/VW/Touareg
      03-29-2009 02:39 PM #10
      That vaulted ceiling is apparently unvented with the spary foam. Did you use closed cell or open cell.
      I have a very similar application and I'm trying to dig through the information. I was quoted 2" of closed cell, then 4" of open cell to save money.
      The closed cell is really expensive, but it acts like a vapor barrier whereas the open cell does not.
      I wasn't sure if you could put open cell foam in an unvented application without some sort of a vapor barrier.
    11. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-29-2009 05:25 PM #11
      Mine is icynene foam, most climates you don't need a vapor barrier, and a low vapor permeable paint is enough for northern climates (Canada). [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I did want to do closed cell, but the cost was a bit more than i could handle, and found the icynene was more air quality friendly. got a toddler in the house, didn't need to be putting something in that would give off nasty fumes for a while. If I were building new or doing a full rehab and not moving in for a while than I'd do closed cell as it would have time outgas fully before I moved in
      2015 VW Jetta S
    12. 03-29-2009 05:48 PM #12
      It's probably not going to fall within my budget, but thankyou for sharing. I didn't even know that this option existed.
      I think if this was the home I planned on living the rest of my years in, I'd definitely consider it, though.
    13. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-29-2009 05:57 PM #13
      I look at it this way, at the time oil was over $4/gal (it'll end up there again in the not too distant future I'll bet) so I'm saving $2,400/yr at that rate so it'll pay for its self in just over two years... at the current $2/gal figure little over 4 years. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      and it can only be put in when the ceiling is opened so now is your chance.
      2015 VW Jetta S
    14. 03-29-2009 08:14 PM #14
      I would do whatever you can do to get a R30 or even a R40 up there. I live very close to your latitude and just made the jump from 20 to 40 (R) and it is incredible. Warmer in the winter...cooler in the summer. The payback will be there as long as you own the house.
    15. 03-29-2009 08:33 PM #15
      Do you remember what they charged per sq. foot??
    16. Member Phrost's Avatar
      Mar 8th, 2004
      Green Bay, WI
      '11 Audi S4, '77 VW Westfalia
      03-29-2009 11:43 PM #16
      You do not want compress fiberglass if you only have 7" of space to work with. The air pockets in the insulation is needed for the fiberglass to do it's job, so if you push 9.5" rolls into a 7" space your end result will not be R-30. I'm not sure how much insulating value you lose (since 2.5" extra is not that much), but I think the cost/time of replacing all of it compared to the energy savings will not be worth it.
      Modified by Phrost at 10:44 PM 3-29-2009
    17. 03-30-2009 08:36 AM #17
      Quote, originally posted by Phrost »
      It would definitely be more convenient to go with this philosophy....
      I wonder if there's anyone on here that would know if this theory is valid?
      Anyone?
      I'm probably not going to realistically start with hanging a ceiling for another week or two, so I've got time.
    18. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-30-2009 10:00 AM #18
      Quote, originally posted by thesteve »
      go online, search 'foam insulation + your area' call a few places and get estimates. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      given the state of the economy I bet you'll get it cheaper than i did (plus prices will vary by area, I know I paid a bit more than one of our clients did in upstate NY)
      Modified by InSaNeBoY at 10:01 AM 3-30-2009
      2015 VW Jetta S
    19. Member peecee's Avatar
      Sep 28th, 2005
      Davidsonville, MD
      03-30-2009 11:57 AM #19
      Anyone?
      Insulation is designed to fit a specific joist space. Insulation relies as much on air pockets as the small flecks of glass to prevent air movement. Your best bet is to go perpendicular to the current insulation with as thick you can as possible, leaving the existing R-19 in place. You definitely do not want to stack insulation, and if you can't do the new insulation perpendicular, you should remove the R-19, and add furring strips to bring the current joists out to the full 9.5" R-30 depth.
      If I were you, I'd sister 2x4's onto the existing ceiling joists and put R-30 in. Remove the R-19 and put it somewhere else.
      Modified by peecee at 11:59 AM 3-30-2009
    20. 03-30-2009 02:30 PM #20
      For a frame of reference, could you give me an idea of what you had to pay per sq foot? feel free to IM me.
    21. Member DiscoStu's Avatar
      May 8th, 2001
      MA
      03-30-2009 02:57 PM #21
      I had quotes of $2 to $2.25 per sq. ft. for 6" of open cell foam.
    22. Member InSaNeBoY's Avatar
      Feb 16th, 1999
      Topsham, ME
      VW
      03-30-2009 02:57 PM #22
      sorry, I'm a lazy bastard. don't feel like measuring my house and calculating the square footage of the insulated areas to find out the cost.
      2015 VW Jetta S
    23. 03-30-2009 03:20 PM #23
      Quote, originally posted by DiscoStu »
      Okay. That gives me somewhere to start.
    24. 03-30-2009 03:20 PM #24
      Totally understand.
