Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 172
Thread: **Official 24V 3.6L Engine (oil pump bolt) failure thread**
  1. 07-23-2010 12:14 AM #106
    im looking to buy an 06 passat i do alot of driving all over new england and the tri state area is this really something to worry about i have the vin#WVWBU73C06P161766 do we kno if there is a certain factory that it is happening to. is it still a good idea to buy this car
  2. Member VR6GURU's Avatar
    Dec 10th, 2002
    City of Angels CA
    93 Cali Style Corrado, 08 Honda Element SC
    08-12-2010 01:22 AM #107
    So I had never heard of this problem till I was on the Touareg forum. A guy posted about the oil pump bolts failing on the 3.6's
    Now that I am on this thread everyone here seems to own a Passat. Did the Touaregs suffer from this problem?
    Thank you, and Good Luck
  3. 08-24-2010 10:15 PM #108
    So at 50k I am unhappily a new member of the failed oil pump bolt club. I am trying to get VW to do the right thing and replace the engine. They have stated that the only course of action right now is to replace the pump, chain and tensioner. I cant see how the engine can be any good after the bolt sheered off. For those that did not have the engine replaced how is your car running now? Just feels like the car will be a ticking time bomb. Unless they do a compression test and rip the engine down to its core I wont feel comfortable. How off am I on that feeling?
    This is the second time this has happened with VW. First we lost a tdi engine and now this one. I have all but lost faith in VW. Minus a small miracle I will never buy another.
    I will work on getting the details and post the information out here...
  4. Junior Member
    Dec 16th, 2007
    Far eastern West Virginia
    2008 Passat 3.6
    10-30-2010 11:56 PM #109
    I've a '08 3.6 put together in Emden. Still going strong. Bought the car new and the oil's been changed fairly consistenly at 5k. Runs great, so far. It sounds like the problem could be related to early production. You would think they would get a hand on the source!
  5. 01-06-2011 03:18 PM #110
    Year: 2006
    Failure: Oil Pump sheered off, motor destroyed
    Mileage: 75k
  6. 01-06-2011 03:20 PM #111
    I was told that the bolt was inferior regardless of where purchased.
    A new one replaced it in '08.
  7. Semi-n00b
    Feb 14th, 2011
    09 A6 Quattro Sport 08 535XiT 07 4MotionPassat (when it's running)
    02-14-2011 12:33 AM #112
    I didn't post my first one, '06 Passat 4Motion, 30 K check oil pressure warning and noisy valve train. Dealer dissassembled, told by VWoA(c) to stop looking further when filing were found in oil pan. New long block installed under warranty. Latest 07' Passat Wagon 4Motion, 71 K. Same story, different book. Oil light came on while driving, car sounds like a diesel. Dealer assured me after first engine failure that this was *rare*. If all turns out good, post will stop, if VWoA(C) disavows themselves of this known problem will post further. I've taken stats, VW suggested that 1/1000 engines fail, probability of 2 is 1/1000000, maybe I should take up playing lotteries.
    If it helps anyone, the engine started to bog 2-3 days before catastrophic failure. Only had issues with engine performance below 3K rpm. Car would not hold cruise uphill after this started. CEL came on, but did not flash, suspected EGR error as light had previously been cleared due to EGR fault diagnosis.
    Oct 1st, 2006
    2009 CC Lux 3.6 4motion
    02-24-2011 12:06 PM #113
    Quote Originally Posted by twiceunlucky View Post
    On the second car, did you have an extended warranty or are you out of pocket? Interested in finding out how VW deals with this denied issue out of warranty.
    I couldn't take it anymore... I sold my B6 at 85k miles before my extended ran out.
    2009 CC Lux 3.6 4mo
    Interlagos, Euro corners, Bilstein Sports, H&R Sport springs, H&R swaybar, H&R 10mm wheel spacers, Suitcase resonator delete, 20% tint Suspension for sale: Click-----> http://forums.vwvortex.com/showthrea...bo-for-4motion
  9. Semi-n00b
    Feb 14th, 2011
    02-27-2011 10:41 AM #114
    Well, VWoC came back, told me that was what warranty was for, denied all responsibility. Dealer recommended replacing engine. Quoted $17,000 for replacment, knocked it down to $16,000. Not the dealer's fault, but definitely VW's fault. I'm sending it to a third party to have the engine replaced or redone, I will never deal with VW again, that is my last VW product. The only time my A6 will see an Audi dealership is when the CEL comes on and I have a warranty claim. Looks like I'm moving over to BMW.
  10. Junior Member
    Mar 16th, 2004
    Toledo OH
    06 Passat 4motion Sedan
    03-23-2011 01:33 PM #115
    06 4motion. Bolt failure at 19k miles. Bought it used and work was done before I purchased. Now at 92k. Figured I'd add to the list so VW might admit to the defect and cover it for those out of warranty.
  11. 04-16-2011 01:17 PM #116
    2006 3.6 VW Passast
    Purchased 12-05
    60,600 miles when engine failed
    2 months and 600 miles out of warranty
    Aug 26th, 2010
    Brooklyn NY
    07 3.6 Passat Wagon
    06-06-2011 02:01 PM #117
    Wanted to post this to inform that we may have some gold at the end of the rainbow....finally.
    http://forums.vwvortex.com/showthrea...rom-3.6-Owners!
  13. Junior Member
    Jan 2nd, 2010
    1999 1.8T Beetle, 2009 2.5 Rabbit/Golf
    09-07-2011 10:51 AM #118
    Quote Originally Posted by 8606 View Post
    More than likely it will happen before warranty, even before 10k miles. Lemon Law is tricky (vague) on state website. Now we know specifics. Sister-in-laws car unable to use lemon law , but VW agreed to replace car (due to all the other problems). Hopefully the new car will be trouble free. Hey you have to be optimistic.
    It usually has to be the same problem over and over again. There is a reason that lemon law attorneys advertise on TV. No one really uses them. Companies very rarely produce lemons. It does happen. But not very often. The 3.6 and 2.0 are decent engines, they're just newer engines that need the kinks worked out. All cars from all manufacturers are like this. It sounds like the 3.6 is a little worse off. I got a 2.5 and I think it is one of the most solid engines VW has ever made. 65,000 miles and only one problem. It was my fault though. I got some bad gas with water in it and it threw the knock sensor. I went into limp mode.
  14. Semi-n00b
    Feb 14th, 2011
    09-16-2011 01:09 AM #119
    Quote Originally Posted by rags2riches View Post
    Everyone screws up, I can't count the number of times that I have. When I do screw up though, I fess up to it, apologize and make it right. I don't think anyone could say that VW didn't screw up with the 3.6. First year, stuff happens. So, all they needed to do was make it right. We blew it, bring your engines in and we will fix it, or; we blew it, the recall costs too much but don't worry we'll extend the warranty. In the last 7 years I have patronized VW with an '03 Jetta TDI wagon, an 06' 4Motion Sedan, an 07' 4Motion Wagon and an 09'A6. After this episode I've switched over to BMW, must admit they screw up as much or more than VW, but at least they own up to it and are fixing stuff. To be honest this German junk has me looking at domestics again, maybe the CTS wagon AWD.
  15. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-22-2011 08:48 AM #120
    Good luck! If you thought Germans built junk the Japanese and Domestics are not better! This is 2012 where cars are built by bean counters.If you want a solid car that was built like a tank then you have to go back in time, not switch platforms. Volkswagen stopped building reliable cars in 1992. Family member has a CTS and from day one has had nothing but issues (and issues that will make your hair stand up i.e. merging onto a highway and power shuts off...no throttle control ).
    Still one of the most reliable volkswagen's I have ever owned has been the B6 3.6 the last one being a MKII Gti.Other than a failed coil pack and 2 sets of control arm bushings , it has been pretty sound.
  16. Semi-n00b
    Feb 14th, 2011
    09-24-2011 03:08 AM #121
    You make your living on parts for these cars and you admit they are junk since 1992. Awesome, thanks for proving my point. Yep, the CTS is junk with a much smaller price tag. S*** smells better when it doesn't cost as much.
  17. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-25-2011 01:51 AM #122
    Not sure how you got junk from this....
    Quote Originally Posted by Issam Abed View Post
    Volkswagen stopped building reliable cars in 1992..
    Let me define what reliable means. Starting everyday in the winter , costing peanuts to repair and all around no major repairs.
    MKIV 1.8T's were plagued with faulty coil packs and PCV failures
    MKV's - fuel pump followers & camshafts
    MKVI's - dual mass flywheels - pcv issues.
    When Volkswagen introduced the MKII's the only issues I could even remember the tech's @ our garage complain about was CIS and G60 failures. This is straying off topic but all in all compared to other brands , VW's are still very well built and if you would like to sample another non-german brand then by all means go right ahead but dont expect miracles.
  18. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    2008 Passat 4Mo 3.6L Wagon, 98 VRt, 2010 Routan/Caravan :)
    10-03-2011 12:45 PM #123
    Guys,
    Take your argument to PM or a more suitable thread as this is definitely not the place for it.
    Thanks,
  19. 10-29-2011 06:58 PM #124
    I just did the bolt on my wife's 07 passat 4mo wagon . Had 150358 kms @ 90000 miles or so . Bolt had walked out about 20mm of thread . Gears were wobbling around . Actually had damage on teeth and keyway areas . I changed the bolt , gears , oil pump , chains and all guides/tensioners . The car did give me warning though , I had a cam sensor code . I tried a sensor cause it was cheap but of course as I had assumed not the issue . I couldn't have been that lucky . It's been up and running for two weeks since the repair . All seems good except idle is a bit rough . Had a misfire code cyl3 swapped coil with cyl1 , disappeared .
    Did the control arm bushings and subframe shims and an alignment while all was apart . Hope the car behaves itself now . Next money going on it some hankooks with studs.
  20. Member 2.0tdi's Avatar
    Jan 8th, 2006
    Vancouver,BC Canada
    11-22-2011 03:00 PM #125
    hi
    did anyone had issue with this on the car made in April '07
    VIN # is WVWFU93C37E227110
    i found car with 74000km and wondering if this failure is covered by bumper to bumper or power train waranty
    thanks for your help
  21. 12-02-2011 04:21 PM #126
    I have an 06' Passat with 57K. The ECP and CEL lights came on. The vehicle went into it's safe mode. My mechanic read the codes as a G40 and G28 sensor. Sounds like I may have the same issue. What is the easiest way to tell if the bolt has backed out.
  22. 12-14-2011 07:26 AM #127
    My wife had the same codes, yanked the trans. Two weeks after I did the bolt and chains I ended up having to pull the head as well. two every so slightly tweaked valves. spotted it on the leak down test. Looking back on my issue I would have proceeded slightly differently once I saw my codes. Step one leak down test. would have let me know exactly what was going on before I took it apart. What ever you do don't start that motor again until it's checked out properly. Tow/push whatever, do NOT start it!
  23. 12-14-2011 07:29 AM #128
    Also did a client's 06 sedan 4MO about three weeks ago, 118,949 kms on it. Bolt was tight had early version bolt. Although his bolt was green coloured, mine was black. Both 8.8 grade.
  24. 12-22-2011 09:40 PM #129
    Quote Originally Posted by 2.0tdi View Post
    hi
    You should be fine with that VIN/date.
  25. Member MUG318's Avatar
    Nov 13th, 2003
    SoCal
    2013 VW Passat TDI SEL, 2010 VW Jetta TDI
    01-13-2012 05:31 PM #130
    Quote Originally Posted by tdec View Post
    Year: 2006
    Mileage: 75k
    I was hoping I dodged the bullet and escaped w/o having to endure the oil pump bolt issue since I now have 60K miles on my car. Crap. Good thing I opted for the extended 7/85K warranty .
  26. 01-18-2012 12:01 PM #131
    It was confirmed that my car had the broken cam bolt. Car had 57,949 miles. "EPC" and "Check Engine Light" came on. Car went into "safe" mode. Towed the car to City Volkswagen in San Diego. (Service Rep. Peter Beck) Car was covered by warranty. They replaced timing chains, oil pump, sprockets, tensioners, chain cover, new software. The cover held the system together just long enough to prevent complete failure. They had to remove transmission to repair. I was lucky, car was 2000 miles and 3 weeks inside warranty period. I found very detailed information, including pictures on "passat world". I took this information with me and showed it to the dealer. No problems or issues with the dealer or VWOA. Repairs took 4 weeks due to parts availability. I reported the issue to the NHTSA on their website. Anyone with the same issue should do the same. Hopefully this will help with a future recall.
  27. Semi-n00b
    Feb 14th, 2011
    01-28-2012 03:47 AM #132
    If they are the pics of the timing chain scoring the timing chain cover, those are courtesy of me, glad they helped you. Of course I'm still at the point where VW claims they are unaware of the problem. Sorry Nater if I'm ruining your thread, this engine is junk.
    Cheers,
    TWU
  28. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    01-28-2012 07:21 PM #133
    Cheers,
    TWU
    it's not my thread. But thanks for your cool pictures though.
    Nate
  29. 03-09-2012 01:25 PM #134
    My wife owns a 2007 3.6 Sedan (FWD) that currently has 40,000 miles on the clock. Unlike many of the 3.6s in the US this particular car was built in the Mosel factory according to the VIN. Does anyone know whether the oil bolt problem is isolated to a particular assembly plant. Most of the VINs that have been posted appear to be cars assembled in the Emden plant.
    I'm trying to decide whether to pay for an extended warranty or have the bolt checked/replaced since we like the car and would like to hang onto it for a few more years.
  30. Member
    Oct 14th, 2008
    '07 Passat 3.6 4mo wagon; '05 GLS 4mo wagon
    03-14-2012 10:04 PM #135
    Quote Originally Posted by uhrgenau View Post
    Not sure if the problem is isolated to a particular plant. If you're thinking of an extended warranty just for the bolt issue, you'd spend less money to have the bolt replaced as a preventative.
  31. Member
    Aug 26th, 2010
    Brooklyn NY
    07 3.6 Passat Wagon
    03-15-2012 01:28 AM #136
    Curious to know how much you guys have paid to swap the bolt?
  32. Member MDAce15's Avatar
    Aug 10th, 2010
    NYC
    07 3.6 4Motion Wagon
    03-26-2012 11:02 PM #137
    Quote Originally Posted by 3.6awdwagon View Post
    Me too!
  33. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    03-27-2012 09:40 AM #138
    This is basically R&R transmission and timing chain.
    I've got no personal experience. I'll pull up Mitchell labor rate when I get to work for you.
  34. Semi-n00b cueboat's Avatar
    Jun 1st, 2007
    NYC
    '06 Passat 3.6 4mo
    03-27-2012 03:07 PM #139
    I have an 2006 3.6 4mo passat. with 85k on the clock. I bought the car used and its not a CPO. It runs great, love the car. But I can't seem to figure out if the oil pump bolt has been replaced, i have an external warranty till december if it does fail. I called my local dealer, they say there isn't a nationwide data base of services done that they can access. Any ideas/recommendations? I was thinking about trading up for a Q7 in the near future any idea what years should be avoided with the same engine.
  35. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    03-27-2012 04:46 PM #140
    06,07 motors are affected.
