Results 1 to 13 of 13
Thread: 90 cabriolet, 1.8 8V with Digifant no start problems - Pls Help
  1. 04-05-2009 12:38 AM #1
    HI ALL,
    I hope any of you with digifant f.i. experience can post helpful tips and tricks for this type as both Bentley and chiltons have failed to guide me in the right direction. I'm in the Lynnwood / Mill Creek area of Bothell,and could really use the assistance. Please read on:
    I'm working on a 90 Cabriolet with the 1.8 digifant It has new:
    T belt and tensioner, other belts, a couple of seals, etc. also, new
    ignition components - cap rotor and wires, and plugs
    is Extremely rich and will barely start when fuse for fuel pump is in
    Pull the fuse for fuel pump, and it will start and run for a short period and then stop.
    Once, I was able to apply a bit of throttle, say 2000 rpm, but once it used up " the residual " fuel, it stalled.
    Have double checked the timing, confirmed spark, confirmed Fuel ( Plenty! ), and can't figure it out.
    Please let me know if you have any suggestions, and thanks in advance!
    MSH
    Nov 17th, 2001
    Northern Wisconsin
    04-05-2009 07:05 PM #2
    Bad ECU. Check the ground wires that connect at the coolant flange -- transmission end of the engine. If those wires are not connected it will cause the ECU to go bad. FR
  3. 04-05-2009 11:58 PM #3
    Hi FR, Thanks for the tip. The ground wires all look good, clean, and tight. I've installed a new ECT sensor, blue one for the ecu. Same problem. this time, a "backfire" while cranking blew the air intake hose to the IM off of the airbox end of it's connection.
    Any other tips?
    TIA, MSH
  4. Member
    Nov 17th, 2001
    Northern Wisconsin
    04-06-2009 11:07 AM #4
    Get another ECU and switch it out. FR
  5. Member twinair's Avatar
    May 12th, 2008
    Nokesville VA
    90 triple white Cabriolet, 2005 BMW 530, 97 Ford Ranger Splash
    04-06-2009 11:35 AM #5
    x2 on the ecu
  6. 04-06-2009 01:58 PM #6
    FR and Twinair
    Thanks for the suggestion. Tomorrow night I'll have a known good ecu to install and try. Strange thing is that this one appears fine and shows good spark?
    Regarding ECU's, how far off of the part number's alphabetical suffix can you go before this digi 2 type of ECU would be wrong for the car? For example,
    ### ### ### es
    ### ### ### fa
    Does any of you know the correct ECU for the 90 Cab w/ 8V 1.8L?
    Thanks again,
    MSH
  7. Member twinair's Avatar
    May 12th, 2008
    Nokesville VA
    04-06-2009 02:34 PM #7
    I have a 90 and will check when I get home tonight.
  8. 04-06-2009 02:56 PM #8
    Thanks Twinair, I have just found some theoretical data on line that says that ANY Digifant 2 ECU can run any car? I'm not sure, but they are VW people, so maybe they know. Another thing I've found is that the main VW # is
    037 906 022
    Then, the suffix can be:
    AG
    BN
    AN
    BC
    BE
    FQ
    CS - this might poss be a special number on the BOSCH reman unit
    M
    This is all just various data points, so I don't know which goes with which.
    Thanks for looking for me, I really appreciate it.
    Best regards,
    MSH
    Nov 17th, 2001
    Northern Wisconsin
    04-06-2009 03:48 PM #9
    Any ECU probably can run any engine. But I always operated under the assumption that there were differences in the ECUs and have always replaced them by PN. However, no one I have been able to find has been able to tell me the specific differences in the units based on the letter suffix to the base PN. I have asked several times over the last 10 years.
    My '91 GTI took a CT or AT ECU and I never tried any other -- although I had them to try from time to time. There were also Bosch and TAN OEM ECU's. FR
  10. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    04-06-2009 09:12 PM #10
    Digifant Cabriolet ECU part #s:
    1990: 155998004*
    1991-1993: 037997022KX
    *Cabriolet-specific part
    Edit: Before condemning the ECU, test the fuel pumps and fuel pump relay and Digifant Control Unit relay, if you haven't already. Also, check, clean and, if necessary, replace the grounds.
    Modified by kamzcab86 at 7:16 PM 4-6-2009
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  11. 04-07-2009 10:51 AM #11
    Hi Kamz, Thanks for the info.
    I'm checking the Fuel pressure and that sides relays tonight. I know I've had good fueling, cause it is like it is flooded.
    To ALL,
    I've disconnected the connector for the o2 sensor, no change;
    I've disconnected the blue connector from the ECT sensor ( which has just 2 days ago been replaced, no change;
    I've confirmed timing marks yet again;
    I've confirmed all grounds, again;
    Tried to start with fuse #5 (fuel pump) pulled from fuse box, and it starts, a little bit, very herky jerky, and stalls within 30 seconds.
    Put the fuse back in for FP, no start at all.
    Very confounding, this lil Mk 1!!
    Kamz,
    I appreciate the Cabrio specific part # info, also. Do you know if that 155 998 004 equates to the 037 906 022 CE, where the 9 digit # is the common part, and the CE suffix seems to be for the cabrio? ( Mine appeared original, and was a CE suffix box )
    I'd been on the cab-info site, and it is excellent! Thanks for that.
    Anyone have any tips or suggestions ( other than pull motor and put in a new one ) ?
    Thanks again!
    MSH
  12. 04-08-2009 10:48 AM #12
    FR, Kammie, Twinair, et al,
    It's alive! Thanks to Mark K and his "test" digi ECU, It runs again! The known good ecu that I was relying on "wasn't".
    IM for details if you wish.
    Thanks to all for all of the helpful, insightful, and caring contributions!
    Best regards,
    MSH
  13. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    04-08-2009 06:24 PM #13
    Excellent! And, you have a PM.
